Question about AEG 24 in. Favorit 80800 Free-standing Dishwasher
?ko favorit 60860 i dont work but the motor is runnung.C3 problem
The kitchen sink overfleedid and we cleened the plumming pipes. Then the machine were full with water and after the cleening she pumped the water out, but then when we tried to start it with a program after a short time always comes C3 in the showing box. We can hear the motor is running. Can we fix this problem our selves?
  • etienneb Dec 25, 2008
    Same C3 error partially fixed after some cleaning.
    Four wash cycles then the error is back.
    The pump doesn't stop. Even after the machine is unplugged, the pump remains running.
    Any idea to reset the system?
  • stevie408 Feb 09, 2009
    i have .30 continually flashing in the led and can hear the pump running. the programme was interupted by a power failure. have tried re setting but it still comes back to the same. any ideas
3 Suggested Answers
COXY
  • 76 Answers
SOURCE: Favorit 44070Vi 3 short warning tones
It is most likely to be the wash pump leaking underneath, the float switch lies underneath the dishwasher, if you tip it back slightly you will probably find that water will leak out, that will prove that it is leaking and it will probably work a couple of times after this but it isn't the answer i'm afraid, a wash pump is not really the sort of thing you should tackle yourself.
Posted on Nov 27, 2007
SOURCE: AEG OKO-FAVORIT 50800
C3 error means that there is water at the bottom of the dishwasher. Unplug the dishwasher, slide it forwards and push it back. So it stands on the 2 back knobs. Do this atleast at a anle of 45 degrees. You will see water flowing at the floor.
If this happens often you have a leak somewhere. Time to cal the technician then.
Posted on Sep 11, 2010
Hi when kitchen sink drains water is coming out of the back off washing mashine on to kitchen floor whats wrong
You have a clog in the drain somewhere after these two join the main drain pipe.
Dec 13, 2017 | Dishwashers
Kitchen sink hole fills up with water when using the washing machein
After washing cycle all the water flows immediately from tub to drain pipe. If the flow capacity of sink is slow sink hole fill up with water .
Connect washing machine drain to proper place for drainage.
Oct 05, 2013 | Washing Machines
I installed new moen muirfield sink. It worked just great. Water flow just smooth. Then few hours later, it started making thumping sounds but when I use the spray, it stopped. But when stopping using...
That is called 'water hammer' and is usually coming from an old fashioned stop valve. The stem with the washer is bouncing up and down.
http://www.moen.ca/kitchen-bar/faucets/kitchen/muirfield/_/N-6a2Z1z141ulZ1z141o8 ]
Water hammer - Wikipedia
https://en.wikipedia.org/wiki/Water_hammer
A water hammer commonly occurs when a valve closes suddenly at an end of a pipeline system, and a pressure wave propagates in the pipe. It is also called hydraulic shock. This pressure wave can cause major problems, from noise and vibration to pipe collapse. ‎Hydraulic ram · ‎Nikolay Yegorovich Zhukovsky · ‎Surge tank
How To Stop Water Hammer - How To Fix Pipes ' HowStuffWorks
home.howstuffworks.com > ... > Home Improvement > Home DIY > Plumbing Water hammer is a specific plumbing noise, not a generic name for pipe clatter. It occurs when you shut off the water suddenly and the fast-moving water rushing through the pipe is brought to a quick halt, creating a sort of shock wave and a hammering noise.
Waterhammer - YouTube
? 2:34
https://www.youtube.com/watch?v=f9LY0-WP9Go Nov 27, 2013 - Uploaded by IAHR Media Library
From Effects of Fluid Compressibility - (Hunter Rouse) Courtesy of Dr Marian Muste, IIHR - Hydroscience ...
What is water hammer and how to prevent it - PlumbingMart.com
www.plumbingmart.com/water-hammer-information.html Find Water Hammer - PlumbingMart makes it easy to do plumbing and even misspelled pluming and plumming.
What is Water Hammer? Plumbing Tips on How to Solve It - The Balance
https://www.thebalance.com > ... > Construction > Materials > Mechanical Systems Mar 4, 2017 - Water hammer is a common plumbing issue where water changes direction suddenly. Use any of these 4 options to solve water hammer issues.
water hammer Google Search
Jul 11, 2017 | Moen 87530 Touch Control Single Handle...
Zannusi 24 911711057 serial number908805364 water from kithen sink goes back down dishwasher waste pipe into machine the ubend under sink is not blocked advice please asap thanks anthony wanford
Hello, your might have blocked kitchen drain? If not blocked, check that your dishwasher drain pipe has higher point then conection to waste pipe.
Jan 17, 2011 | Dishwashers
How can I reset an i30 (flood control) error?
you have to mopp up any water in the base of the machine. this can be caused by a leak . a sagging pressure pipe to the pressure switch can do it as well. you can tie it up to stop the sag. its at the front behind the plinth area.
Jul 22, 2010 | AEG 24 in. Favorit 60830 Free-standing...
The twin tub connected to the washing machine doesn't drain.
The laundry tub does not have adequate drain size to handle discharge from the washing machine. In addition, the kitchen and laundry area piping may not be correctly vented.
May 17, 2017 | Daewoo DW500M Top Load Washer
My washer will not drain...it fills up and then stops no drain no spin
hi
if it fills then stops working,no washing motor action then you may have a motor or pcb fault,check motor brushes and connections.if it works fine upto rinse and dont drain check filter for blockage or drain pipe if plumbed to sink.
Aug 02, 2009 | Indesit W 123 Front Load Washer
Water gets into disher when not inuse
dishwasher drain enters sewer system tapped into waste pipe below kitchen sink
water flowing from kitchen sink passes the opening of the dishwasher pipe
If the dishwasher hose does not loop up higher than the kitchen sink before going down to the bottom of the dishwasher water may flow downhill through the dishwasher drain into the dishwasher
ensure the dishwasher drain hose is screwed to the underside of the kitchen counter, to provide a stop to water flow.
The installation instructions suggest this
but often the dishwasher is at the end of its 'stretch'
and the installer assumes looping is just to use up excess hose, and doesnt.
an extension drain hose is available at most appliance stores
Oct 27, 2008 | Kenmore 22422 Top Load Washer
Dish machine
you need a plumber sounds like your sink piping has a blockage
Mar 08, 2008 | Dishwashers
AEG 24 in. Favorit 80800 Free-standing Dishwasher Logo
73 people viewed this question
Top AEG Dishwashers Experts
Paul Carew
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
