Question about Pentax Optio 33LF Digital Camera
Can't get it to stay on!
I have used the camera for over a year. I was taking some pics with it today and then the next thing I know, the lens will not come back in and it's like froze. Put in some new batteries and it will come on and show me the pic screen and immediately go off on it's on and the zoom lens is still stuck out! What do I do or is a lost cause???
  • 1 more comment
  • Anonymous Jan 24, 2008
    have the same exact problem, someone please help!
  • cage_bird Mar 31, 2008
    yes. Same here!! Seams though it works ok when I changed back to my 65 mb memory card instead of the new 1GB I bought. It seams like that works. Problems started when I changed to that new memory card, can't turn it off. And it also take a pic automaticly before it freezes. Very odd. when
  • Anonymous May 23, 2008
    I have the same problem as " cage bird ".when trying a 2GB card all sorts of problems occured including the ones listed . Changing back to 64 mb card seems to fix problem. Doesnt help the need for more memory though. Tercar
Try to take out batteries and put them back if it doesnt work right away with change of memory card.
Posted on Mar 31, 2008
Hi, I have D90 standard package with 80-105 lens kit and I'm using it with 16 GB SD card. I'm using it almost a year now however last few weeks, when camera is on "off mode", little yellow light...
That is the card access lamp. It should light briefly when you insert a card and when you take a picture. If it's constantly blinking, something is wrong. Try removing and re-inserting the card. Try a camera reset with no card in the camera. Try downloading the pics to your computer and then formatting the card in the camera to completely erase it.
Mar 16, 2011 | Cameras
Displays icons but won't register pictures
First make sure that you accidentally didn't turn off the screen by repeatedly pressing the DISP button to cycle it on and off. If that didn't fix it, and if your camera is less than 1 year old, call 1-800-OK-CANON to arrange free warranty repair.
If your camera is more than a year old, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 03, 2009 | Canon PowerShot SD1100 IS Digital Camera
Camera has auto-deleted pics twice
I've had similar problems with other cameras. The problem is not the camera, however, it is the sim card. If you remove the sim card and place it in the card reader on the computer, the contacts on the card eventually wear out. What it sounds like is that your new pics were not saved to the card due to poor contact. If this is the case, unfortunately, nothing is recoverable as nothing was saved. A possible short term fix is to remove the sim card and scrub the contacts with a pencil eraser. A long term solution is to get a new sim card and leave it in the camera and transfer pics using a USB connection from the camera to your computer. I hope this helps.
May 03, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Lens error with Canon ixus 970 IS
Has anyone responded to you on this yet - I have had the same problem and don't know what to do?>
Apr 07, 2009 | Canon PowerShot SD890 IS / IXUS 970 IS...
Error 99
the lens contacts are dirty - get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them. Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I've used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
Works well for me....let me know how you fair!
Mar 16, 2009 | Canon EOS 40D Digital Camera with 17-85mm...
My camera wont stay on even with new batteries
I Have The Same Exact Camera As You And Have lost of Experience With Digital Cameras I'm Guessing you just need digital camera compatible batteries (Rechargeable) Oh and keep in mind taking a picture requires a lot of energy use
Dec 30, 2008 | Polaroid i735 Digital Camera
Sony Cyber-shot DSC-W55...
Dear Julie339
Battery of your camera has less charge storage/ got weak.
Replace with new battery and try it. Hope problem would be solved.
May 18, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Lcd reads system error
Apparently often related to a lens motor malfunction. My old 4300 just gave this error for the first time today. The lens extended but made a whirring noise before the message popped up. Nothing I tried would fix it - but after I drove home it worked fine again.
I had a similar problem over a year ago after the camera fell out of my backpack (it was in its own bag but not well padded). When I used it the lens stuck and refused to retract, but I don't recall a "System Error" message. After a few tries, the lens went in and it's been fine since, until today.
Make sure there's nothing (dust, dirt) stuck in the lens barrels. Otherwise, just keep turning it on and off and hope it works.
Dec 31, 2007 | Nikon Coolpix 4300 Digital Camera
Action pics with a long lens
What you are experiencing is not blur, its camera shake. You are shooting in low light so the shutter speed is being reduced by the camera's automatic features. Also the longer the lens (the farther you zoom), the higher the shutter speed you need. Even for non moving objects or when panning the shutter speed should be at least one stop above the focal length. ie - 300mm lens = 500 or 1000 shutter AT LEAST! (and don't forget, if its a film lens on your rebel, thats actually 300mm x 1.6 =480mm, so 1000 shutter or higher min.) Moving objects require even faster shutters. Solutions: Get faster (also called brighter) lenses which can be pricey. In low light use higher iso settings in the camera menu. Shoot in either manual or Tv mode and choose the higher shutter speeds while using the light meter to decide aperture. Use wider angle lenses or back off the zoom and move closer. Stabilizers built into the lens can steady the shot by two to four times as well.
Sep 14, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Can't take pic
hi bell, I think there is no problem with battery but it may be with lens assy. . you have to check out the lens assy at sony shop so go to sony shop. good luck...
Aug 02, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Pentax Optio 33LF Digital Camera Logo
117 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Mohamed Ismail
Mohamed Ismail
Are you a Pentax Camera Expert? Answer questions, earn points and help others
