Question about New World 50GSO Gas Kitchen Range
50GSO COOKER WILL NOT STAY LIT HELP PLEASE
We followed the instructions last night on our new cooker. We held the setting 8 in and last night that worked.
This afternoon as we try to cook Christmas Dinner the D"£M thing wont stay lit no matter how long we hold 8 in. It stays lit so long as we hold it but a minute later out the gas goes again. Can anyone help QUICK PLEASE x
  • Anonymous Jan 16, 2009
    same as above
  • Anonymous Feb 03, 2009
    I have the same problem on a Stoves gas hob. In total it has 8 gas burners. Nearly all the burners have the same problem. I am limited to about 1 or which work consistently. It is extremely frustrating esp when cooking larger dinners like christmas. From what I know there is a safety shut off for the gas so that if the flame blows out the gas will be cut off to prevent a dangerous situation. I feel that these sensors which detect the flame heat are not functioning correctly. Not sure if I can get replacements or not... any advice would be greatly appreciated.
SOURCE: Fuse tripping
This usually means an earth fault, probably a faulty element
Posted on Dec 18, 2007
SOURCE: oven wont stay alight on new world 110G
Hi - I had this problem too. I assume you are referring to the automatic oven, not the manual one. There is a small 'Licon' switch behind the control knob, which provides electrical power to the main gas valve in the oven. It is activated when the knob is turned on and is also connected to the timer clock, so that power is only provided when the timer reaches the cooking start time, or the timer is not being used. I had this replaced by an engineer from New World (at great expense!). Changing it seemed to be fairly straightforward - the engineer removed the two outermost knobs and unscrewed and removed the facia. The switch is behind the main oven knob - but where you might get one from, I don't know. And don't forget to switch off the power before you try to access the switch, as it is likely to be live.
Good luck
Keith E
Posted on Dec 18, 2008
SOURCE: new world gas cooker (apex hl 500)
the battery compartment is located right at the bottom of the cooker on the front, slightly to the left. It's a little compartment that houses a aa battery. it's unclips on the right hand side. hope this helps
Posted on Oct 15, 2009
johnrodgers1
  • 80 Answers
SOURCE: How to replace a thermocouple in a New World
not at all hard to replace just have a few small wrenchs on hand 10mm 7/16 maybe 1/2 in and screw driver. how do you know its a thermocouple problem, theremocouple are on commercial ovens and basic ranges usually a domestic range has a glow coil operating oven and not a thoemocouple
Posted on Feb 05, 2010
  • 494 Answers
SOURCE: there is a strong smell of gas from my cooker,
Do not light anything if you are smelling gas. Make up a soapy solution in a spray bottle and apply to all connections and look for bubbles. Most common place to leak is hook-up at cylinder and hook-up at cooker. If you can't find the leak and continue to smell gas, do not use it. Also make sure your cylinder is not empty.
Posted on May 15, 2010
I need an instruction manual for a Cook's manual 8 qt. pressure cooker.
Dawn, We're you able to find the Gasket you were looking for? I have the same 8 qt. manual pressure cooker, hard anodized, #Y22-4(8)-00 and am in need of a new gasket. Can you please advise?
Jan 01, 2012 | Crock Pots & Slow Cookers
When you first light the pilot works fine after cooker heats up it may cycle a few times and the pilot goes out and then when you try to relight it will only stay lit while the pilot button is being...
Hi there. Try cleaning the thermopile, it must be free of soot or any other form of dirt, the pilot flame should be of good quality, as well as the gas pressure.
Regards.
Aug 02, 2011 | Imperial IFST25 Deep Fryer
I purchased a Sears Counter Craft Crock Watcher crock pot at an Estate Sale, but there is no instruction booklet. It has low, high, and auto shift on the dial. Can you help provide some instructions for...
From a couple of different slow cooker manuals - most I looked at are the same:
When in the AUTO setting, the slow cooker will begin cooking on HIGH and then will shift to LOW after approximately 2 hours of cooking time. AUTO setting does not turn off the unit. Other favorite recipes may be adapted to the slow cooker. All times listed in the following chart are approximate and should serve only as cooking guidelines.
Regular Cooking Slow Cooker Cooking Times
1 (Low) 2 (High) AUTO
30 minutes 6-8 hrs. 3-4 hrs. 5-7 hrs.
35-60 minutes 8-10 hrs. 5-6 hrs. 6-8 hrs.
1-3 hours 10-12 hrs. 7-8 hrs. 8-10 hrs.
Sep 16, 2010 | Vacuums
I have Ronson slow cooker with no manual, it has settings 1,2 qnd auto. Which is high and low, and what does auto setting do>
I also have a Ronson slow cooker.
Instructions from the book read as follows:
- On setting 1 (low), the slow cooker can operate all day and night if required.
- When set to 2 (high), it is very much like a covered pot on the stove. Foods will cook in half the time required for 1 (low).
- When set to auto, the slow cooker will cook on 2 (high) until the food reaches a pre-set temperature, then switches to 1 (low) and maintains a constant slow cooking temperature. Auto is the ideal setting for someone leaving the house for the whole day as most food will cook for 8-9 hours and be ready to serve when they return.
I always use the auto setting, unless I don't have as much time, and will then use setting 2.
Sep 15, 2010 | Crock Pots & Slow Cookers
Belling G755 Cooker oven wont stay lit
I'll give this a go! With a cooker like this, you depress and then turn the control knob, press the ignition button and continue to depress the control knob for a few seconds. This is because a device called a thermocouple is heated by the flame and you have to continue to depress the control knob so that sufficient gas flows to heat up the thermocouple. If the thermocouple does not get hot or stay hot then the gas valve is automatically closed - stopping the gas. The thermocouple is a 'flame failure' safety device. If the gas gets cut off then the flame goes out and the thermocouple goes cold switching off the gas valve automatically. However, you are having to try and manually keep the gas going for a good five minutes. I would think that there is either a problem with the thermocouple or the gas control valve! Tony www.birminghamelectricsltd.com
Jun 18, 2009 | Belling Solitaire G755 Gas Kitchen Range
Ronson slow cooker don't know which is high or low
on setting 1 (low),the slow cooker can operate all day and night if required
when set to 2 (high) it is very much like a covered pot on the stove.food will cook in half the required time
AUTO the slow cooker will cook on 2 (high) until the food reaches a pre-set temperature,then switches to 1(low) and maintains a constant slow cooking temperature.Auto is ideal for someone who is leaving the house for the day 8-9 hours please feel free to share this information.If you have any more ? please fell free to contact me.
bianca
Jun 12, 2009 | Crock Pots & Slow Cookers
No instruction book for rival rice steamer cooker
http://www.rivalproducts.com/manuals/MANUALS/RCS200_43_68557881.PDF
Mar 28, 2009 | Rival 4350 8-Cup Rice Cooker
New World 50GSO Gas Kitchen Range Logo
Top New World Kitchen Ranges Experts
Paul Carew
Craig Jones
Level 1 Expert
myrlanthian
Are you a New World Kitchen Range Expert? Answer questions, earn points and help others
