Question about Hunter 52" Ceiling Fan With Light And Remote Control
Adding light to Hunter Fan w/o light
My wife wants to add lighting to a Hunter fan in our library. There is a plate on the bottom that covers seven wire-nut terminated sets of wires. The diameter of the round piece at the bottom of the fan is 3 and 1/2 inches, the distance between two screw holes inside is 2 and 1/2 inches.
Can I purchase a lighting kit for this fan? AND, how would I hook it up?
You can get the kit at home depot, it has a plug inside, under the cap. very simple
Posted on Dec 26, 2008
Looking for light fixture for hunter ceiling fan model # 25434
I can't find that fan anywhere in my old catalogs. If you have a center plug in the switchcup, you can put almost any light kit on it. If you have two screws on bottom switchcup, you need a hunter light kit.
Aug 13, 2015 | Hunter Dryers
I need a light kit for hunter fan model #23530
  1. Hunter Fan - Accessories
    www.hunterfan.com/Accessories
    Need more control? We have many universal remotes and wall control options for yourfan and light ... Customize your lighting. Add a new light kit or change the lighting hardware on your fan. Complete light kits. Need lighting parts? Glass and ...‎Complete Light Fixtures - ‎Controls - ‎Glass/shades
Jul 09, 2015 | Hunter 52" Ceiling Fan With Light And...
I have a Casablanca slumber three delta ii that I want to get a light fixture to fit. Can I use a Hunter, or are there certain ones I need to use?
You have to use the bottom plate to attach the light kit to so whatever you get ,you have to be able to screw the two screws back on the fan. I have some older Casablanca light kits that will work without the bottom cap. fanman9952@aol.com
May 13, 2015 | Casablanca Fan Dryers
Hunter ceiling fan fan is working but lights are not
Make sure light wire is connected at the ceiling & at the bottom. Otherwise it's probably the receiver. 1-888-830-1326 ( Hunter parts )
Jan 05, 2013 | Hunter 52" Ceiling Fan With Light And...
I am having a problem adding a hunter 28550 light to my existing hunter ceiling fan. The fan works fine but I can not get the light to work.
It's possible whoever installed the fan originally, did not connect the black/white striped wire to the electric box. Drop the ceiling canopy and let me know what you find.
Mar 31, 2010 | Hunter Ceiling Fan Control Switch
Adding lite kit to 1980's solid state fan. Manual
the switch on the wall has to break the power to your fan and new light and the both must share but be switched independently at the fan. the 2 wires that the light were hooked up to should be tied to a pull chain and tied to the supply and not tied in with the wiring for the fan any longer
Nov 26, 2009 | Hunter 23852 Classic Original Ceiling Fan
I have removed the light fixture on my hunter vista iron model 20538. It looks like there should be some sort of a cap that goes on the bottom of the switch fixture. do you know how I might locate one?
There is usually a blank cover that comes with tyhe fan when new, but when installing a light kit they usually get trashed ,, Try any bnuilding supply store that stocks the Hunter fans ,, bring the part for the light fixture so you can get the exact size and mounting screw araingement as the old kit .
Aug 15, 2009 | Hunter 20537 / 20538 The Vista Iron...
Check/add oil to a hunter ceiling fan
If you are asking for instructions on checking and possibly adding oil to a Hunter Original fan. Here are instructions:
Check oil level immediately after filling the reservoir. To check oil, bend an ordinary pipe cleaner into a 1/2" long hook and dip it into the oil reservoir.
If oil touches the end of the pipe cleaner, the fan has ample oil. If it does not touch, add SAE 10 non-detergent oil slowly until it touches the pipe cleaner.
-Hunter Original fans rarely/ never need oil unless they were relocated or tipped. ...Or if the fan was improperly installed.
-Hunter sells an oil refill / oil level check kit with good instructions. They also sell a relocation kit that includes the same kit plus all mounting hardware needed.
Good Luck!
Apr 26, 2009 | Hunter 23852 Classic Original Ceiling Fan
Dryers Logo
125 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
