Question about New World 50GSO Gas Kitchen Range
New World 50GSO Oven lights then goes out yet again
We are trying to make Christmas dinner with our new cooker. Last night we thought we had the problem solved as it lit and stayed lit.
Today after following the exact same instructions to hold 8 down the oven lit. It stays lit so long as we hold the 8 down but a minute or so later it goes back out.
This is driving us insane. The cooker is days old.
2 Suggested Answers
SOURCE: oven wont stay alight on new world 110G
Hi - I had this problem too. I assume you are referring to the automatic oven, not the manual one. There is a small 'Licon' switch behind the control knob, which provides electrical power to the main gas valve in the oven. It is activated when the knob is turned on and is also connected to the timer clock, so that power is only provided when the timer reaches the cooking start time, or the timer is not being used. I had this replaced by an engineer from New World (at great expense!). Changing it seemed to be fairly straightforward - the engineer removed the two outermost knobs and unscrewed and removed the facia. The switch is behind the main oven knob - but where you might get one from, I don't know. And don't forget to switch off the power before you try to access the switch, as it is likely to be live.
Good luck
Keith E
Posted on Dec 18, 2008
New seal needed for obsolete model
Hi! I have the same problem. I have a System One but I cannot find the model number. Did you manage to find your model number? Can you please share it with me. Thanks in advance, LA
May 09, 2010 | New World 50GSO Gas Kitchen Range
Oven not getting up to correct temperature
check the thermostat and replace if needed.if you have an electronic control board this will also cause the temp not to risie properly.also make sure there is no restrictions with the gas flow.
Jan 27, 2010 | New World 50GSO Gas Kitchen Range
Hi When I try to light the gas oven, it will light but as soon as I release the button the flame goes out
Are you giving the thermocouple time to warm up?
You have to hold the oven knob in for a while to warm the thermocouple before the oven will stay alight. If you are doing this then the thermocouple needs replacing.
See my other posts for a link and price as it was at that time.
Dec 11, 2009 | New World 50GSO Gas Kitchen Range
Our New World gas oven is just on two years old (i think) when we use the grill it keeps clicking and then it just shuts itself off as though there is no gas getting to it. The pilot light will continue...
If the grill is clicking because you are holding the ignition button, which I'm asuming you are because the grill will not light then the thermocouple on the grill is broken.
goto www.espares.co.uk but unfortunately you'll have to ask them if they have any grill thermocouples for this model as I can't find them anymore only thermocouples for the oven.
Nov 08, 2009 | New World 50GSO Gas Kitchen Range
Melted knobs
New world engineer called out and fitted cooling fan there was no charge done as a gesture of good will as cooker was just out of warranty.
Sep 15, 2009 | New World G70m Gas Double Oven
Grill wil not work
The termocouple is broken, just had the same problem myself, looking for replacement part will let you know when I find the part.
May 25, 2008 | New World 50GSO Gas Kitchen Range
Tricity bendix fan oven
The element is almost certainly burnt out .A replacement element is fare cheaper than a new cooker and relatively easy to fit
Apr 07, 2008 | Ovens
I can't make my oven to work
That model has an electric ignition ? you turn the oven to full (8), keep the dial pressed in & press the ignition switch.
You should hear the clicking & if you look at the bottom of your oven you should see a flame through a small round hole.
You have to keep the dial(not the ignition, the dial(8)) pressed in for about 30 seconds for the thermocouple to warm up before you let it go else the flame will just go out. ( if the thermocouple isn't warm enough it will cu off the gas, safety incase of loss of flame or accidental use of oven)
Jan 20, 2008 | New World 50GSO Gas Kitchen Range
Duco4ss main oven not heating on fan setting
put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Dec 17, 2007 | Ovens
New World 50GSO Gas Kitchen Range Logo
Top New World Kitchen Ranges Experts
ashburton
Ismael Rodriguez...
Paul Carew
Are you a New World Kitchen Range Expert? Answer questions, earn points and help others
