Question about Sony KDS-R50XBR1 50" HDTV
Power shutting off and coming back on
My Sony tv is randomly shutting off and coming back on. It can go for several hours or it could be every two or three minutes. I've had the tv for about a year and it shows no other problems. Sony really had no solution other than leaving it unplugged for a little or making sure it was plugged directly into an outlet. I have an extended warranty and have contacted a repair man. They haven't come out to look at it yet, but they think it could be the lamp. The problem is if it turns out to be a lamp, the warranty won't pay for the service call because the lamp coverage I have is just for parts so I want to see if I can figure this out before having the repair man come out. The lamp indicator trouble light on the front of the tv is not lit and the tv doesn't blink in red for the trouble codes when it shuts off. Any ideas?
  • Disturbed Dec 13, 2007
    Our Sony is 1 year 8 months old. Three days ago it started "truning itself off" and then immediately powers back up again, just like powering it on for the first time used in a day. Two night ago, within 2 hours, it turned itself on and off 14 times. The longest it worked uninterrupted was for a period of 16 minutes. Talked to Technician, he is baffled, and I am waiting for him to get back to me. Quite disturbing for a very expensive 50" TV. Any help would be appreciated
  • Anonymous Dec 18, 2007
    tv shuts off do not loose audio green light flashes on tv 52 times yhen comes back on
  • 23 Answers
Folks, if the red light is blinking, it's a trouble code. In order for anyone to help, we need to know how many times the red light is blinking...
Posted on Oct 01, 2008
I have the same problem with the my sony 50xbr1 turning itself off and on. I had the bulb replaced yesterday and it is still doing the same thing. My TV is a little over a year old and sony covered the bulb replacement- I think because of the class action lawsuit. In my case the bulb replacement did not solve the issue.
Posted on Dec 22, 2007
  • 4 Answers
The problem is your bulb is going out or malfunctioning. I had this same problem and Sony's repair service couldn't fix it. I posted on another forum and found a great tv repairman that told me that when the lamp is going out or bad that it can cause the tv to do strange things. I replaced the bulb and the problem is gone. Here's a tip, you can replace just the bulb for about half the price of the full lamp assembly. Sony wants $250 but I bought just the bulb for $125 on ebay, spent 20 minutes taking apart the housing to replace the bulb. Just make sure you take note of how the spring is installed before you take the first part off. Other than that, piece of cake.
Posted on Dec 14, 2007
2 Suggested Answers
SOURCE: Sony KDS-R50XBR1 shutting off
My Sony was doing this too. The tech found that the reflector around the bulb was cracked probably from overheating of the bulb. The TV was shutting down to cool down the bulb. This fixed the problem. I had over 6000 hrs anyways on my bulb. HTHs
Posted on Mar 31, 2008
Sony rear proj tv, no picture, menu appears, but in three seperated colors pin cushioned.
Best to first if you have not done so---UNPLUG the set for several minutes and plug back to power to see if that fixes it (it does a lot of the time especially if you had a power outage).
Nov 30, 2012 | Sony Televison & Video
RCA 50: HDTV, just started shutting itself off and won't come back on for several minutes or over an hour what could cause this
My friend had the same problem. There is some display bulb that is on its way out. They aren't cheap. Find a 2nd hand TV parts/repair shop, They usually have cheap used ones from discarded units, and will know what you need!
Sep 16, 2012 | RCA Televison & Video
My sony big screne started shutting itself off and wouldnt come back on for several hours. Then it would power up and standby flash 7 times and after a few mins the picture would be gone but the sound...
On your tv you have cooling fans on the back side you will need to check to make sure that they are running. Lay your tv on the bed take off back cover (it's not hard) and used some air-in-the- can to remove dust from the back! If you need a fan go to Partstore.com (1-866-925-PART
Jan 26, 2011 | Sony Televison & Video
My Sony TV, model no: KDF-46E2000, all of the sudden started shutting off randomly every couple minutes. It then takes between 30 and 60 seconds for it to reboot, or turn back on. This happens whether...
It is problem of weak lamp that has been reached to end of its working hours life, replace lamp in tv to fix tv problem.
Lamp replacement procedure is easy and would be written in user manual.
Thanks.
Nov 27, 2010 | Sony KDF46E2000 46" Projection HDTV
Thin white horizontal lines!!! I've had my WEGA KE-42M1 for 5 years with no problems until about three months ago. After about an hour being on, there are thin white horizontal lines that move randomly...
Sounds like your TV is giving out, plain and simple.
If this doesn't sound right, then only one thing comes to mind. Have you moved the TV recently? Are you using a different coax cable, (if using cable that is). If so, just change the cable back to the previous one and you should be fine.
Aug 21, 2010 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony kv27v22 TV
check horizontal drive tramformer for intermitance is common problem some time blows horiz transistor to or vertical IC intermintence to
Apr 01, 2008 | Sony KV-27V22 TV
TV turns off anf on
unplug-replug any/all connectors one at a time, including PCB edge connectors.
Sep 26, 2007 | Sony KDS-R50XBR1 50" HDTV
When the lamp becomes weak in this Sony the unit will shut off intermittently. I would replace the lamp and use only an OEM Sony lamp, not an LTI or other knock off. The knock off lamps are of poor quality in my experience and opinion.
Apr 15, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony KDS-R50XBR1 50" HDTV Logo
166 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
