Question about Miller RENEGADE 180 WELDER GENERATOR MIG 907395
Mig proplem torch feed bounces
  • Ron Jones
    Ron Jones Jan 23, 2009
    This is not a question luxur4. sent in the wrong context
  • 56 Answers
Check the feed wheels at the wire spool make shure they are installed properly tight them if needed >>change tip >>
liner may need replaced.>
Posted on Jan 29, 2009
Hi I need a cobel mig/tig/arc welder wiring diagram can anyone help
Have you joined the Cobel/ Mig Weldin Forum? There are a few videos on youtube but I dont know your model so I did not post a link. But try the forum first.
Jan 30, 2015 | Welding Tools
216 mig no feed no fire maybe selonoid problem please help seloniod does not click
It could be just the simple problem of the trigger not working. Disconnect the trigger wires from the machine at the plug at the front of the machine. See if you can manually trigger the machine by placing a piece of bent over mig wire onto the contacts. If the machine does trigger from this then your fault is in the torch somewhere. It could be the trigger (which commonly does fault from a dusty environment) which is easily replaced by going into any welding store with the torch model number (magnum 250L), or it could possibly be that a trigger wire has broken from the torch being damaged
May 29, 2011 | Lincoln Electric Lincoln Power MIG 216...
Three phase power went through our single phase butters mig. no fan or torch now
Hi:
Sorry to say this but feeding 3 phase current to a single phase machine will fry the PC board.
You will need to send the machine to your nearest welding/maintenace shop.
May 19, 2011 | Welding Tools
105 Turbo Model 90778 welder. Took apart the gun/handle because it was not feeding the wire corretly. Put back together and it shorted out. Don't have an exploded view of the handle, to see if anything...
most wire feed problems stem from WF rollers, liners, clutch mechanism on the reel, or contact tip, very rearly on the torch, Torch units are cheap enough and come in a wide range and lenghs, avoid long length cables unless nessasary. you can obtain a drawing of torches from the torch manufacturers
Jun 30, 2009 | Welding Tools
Spool wire starts to melt while on the spool
1] Switch off the mains power,remove the torch from the machine,ther should be a button or switch on the unit to feed the wire, push or switch these and observe that the wire feeds and dose not heat up, if ok then you have a short in the torch, a new torch assembly is required,if the wire heats up with the torch removed, the wire spool is shorting out, remove the spool and check wiring in and around the feed motor, if you can't see anything check for a voltage from a good earth and on the rollers, if you have a voltage then the motor is faulty.(earthing out) a P.A.T test should show exactly where this is.
Feb 16, 2009 | Miller RENEGADE 180 WELDER GENERATOR MIG...
Renegase 180
This fault is typical in most MIG/MAG Units. the feed roller/s need slackening off, pull the trigger so the rollers spin wire the wire not moving, turn the tensioning 1 turn check to see if the wire feeds, if not give a half turn on the tentioner repeat this half turn untill the wire feeds, bend the wire to the torch and pull the trigger, If the wire feeds then thats the correct setting. be awear of all safety rules. use gloves
Nov 01, 2008 | Miller RENEGADE 180 WELDER GENERATOR MIG...
Miller RENEGADE 180 WELDER GENERATOR MIG 907395 Logo
118 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Robert Monigold
Robert Monigold
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
