Question about Panasonic PT-44LCX65 Television
Warning light will not reset
Warning light on my panasonic tv came on to change the bulb, which was done. all efforts to reset the timer have failed.warning light continues to show ''red.'' panasonic says it is a software problem and service needs to be called. any other suggestions to resolve this problem?
Press and hold the volume down button on the television itself. While holding the volume button press the button on the remote located directly under the word "split".
Posted on Jan 23, 2009
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
I replaced the bulb in my Sony TV . when it powers on there is a warning that the bulb is about to expire
With the model number either Google "lamp timer reset" or call Sony; note that the lamp timer reset should be in the owner manual and is done with the Sony remote control.
Apr 16, 2012 | Sony Televison & Video
How do you turn off the replace bulb warning?
hi,
you can reset the lamp timer of your tv by the following procedure. to do this you should have the remote.
power on the tv and press "volume --" button on the frond panel of ur tv and the "split" key in the remote simultaneously for five second.
there will a display come on your tv that lamp timer reseted.
ok
Jan 06, 2011 | Panasonic PT-50LC14 50" Rear Projection...
Replaced bulb last nite, green light blinks for a min. then it worked! watched a few min.turned on this morning blinking.... wont stop green blink. last nite when i changed bulb tv said change bulb reset...
Many projectors use a lamp hour timer for predicting bulb life so they can give you fair warning of impending failure. Since a bulb may be removed and reinstalled because it is still working or another used lamp installed, the timer is not automatically reset to zero when the lamp is replaced. I surmise your set is complaining because the timer was not reset or the time verified when you changed the bulb.
To fix the problem, buy or borrow a remote control; a universal remote control with a menu button may work. (If you borrow a universal remote from a friend, be sure to record the code for your friend's TV first so you can set it back before returning it.)
You could probably get back into the timer reset menu by removing the new lamp and reinstalling it. Caution: follow the directions on page 68 of the user's manual or the sheet that came with the bulb - let the set cool for an hour first, unplug, and wear gloves when handling the bulb since skin oil can cause discoloration and possibly an explosion when the bulb gets hot. You can download the user's manual from Panasonic's support page for this set.
If you can edit the timer hours instead of just resetting, you may want to set it for the number of hours the new bulb has been used.
It is likely that you can get into the lamp timer menu if the set is in service mode, but the user's manual doesn't tell how to get there (I don't have that info either - it's in the service manual, which may be available online from a third party for a price). Usually it is something like holding a volume or channel button on the front of the TV while turning it on with the remote control. After that you need the code to switch to the timer menu. If you have problems getting into the timer menu, ask your dealer's service department or try calling the Panasonic help line listed on the bottom of page 68: 1-888-VIEW PTV(843-9788).
Oct 16, 2010 | Panasonic PT-40LC12 40" Rear Projection...
When I turn my tv on, there is a box that comes on and says replace lamp bulb and lamp timer, I changed the bulb but I do not know how to change the timer?
I can help you reset the lamp timer for your Panasonic PT-61LCX66 Projection HDTV.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Mar 28, 2010 | Panasonic PT-61LCX66 Television
How to change the bulb in my panasonic 52 inch model # pt-52lcx66 tv
I can help you change your bulb and reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV.
  1. Installation instructions for the TYLA1001 bulb are here.
  2. Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Aug 22, 2009 | Panasonic PT-52LCX66 Projection Television
Just replaced bulb to a phillips, lasted one month
Most systems with lamps will have a timer. If the timer gets to a certain hour the set should warn you to replace the lamp. Once you do, you have to reset the timer. If it gets to the max it will not allow you to turn it on till the timer is reset. Check your manual or call the mfg. to see how to reset. Sometimes it's the volume up and down at the same time or menu and power at the same time. They are all different so if you have no manual it's best to call tech support to get the reset steps.
Jul 17, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Changed bulb on panasonic PT-52LCX66-k and cant reset timer.
I can help you reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV.
The buttons used are the TV's volume down and the remote's number 0.
I hope that helps.
Apr 11, 2009 | Panasonic PT-52LCX66 Projection Television
PT-50DL54 panasonic 50" DLP
to get rid of "replace lamp" push the blue action button on the remote and the volumn down on the tv set for a couple of seconds. this has to be done at the same time, good luck.
Bob
Dec 09, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic PT-44LCX65 Television Logo
113 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
