Question about Grundig FR200 AM/FM/SW/DAB Radio
Grundig car 200/how to insert code
Battery went dead and radio would not work, coming up safe on dash board but don't know how to enter code.
4 Suggested Answers
SOURCE: Grundig yacht boy 400 radio does not work with mains operations
hello i have a grundig mini-300 radio , the volume control is stuck in high range . i have had many problems with this radio , i would love to talk with one of your representives . please call me at 585-313-3188,,thank you ,,,,nicholas ferrara
Posted on Aug 19, 2009
SOURCE: Grundig Radio Cassette in 2001 Smart Car
I have changed the battery on my car and now my grundig 200 is in safe how do i get it off please
Posted on Oct 21, 2009
SOURCE: Grundig Satellit 700 World Receiver. AM bands are dead.
Ist Local Oscillator (PLL) stops working. It's desiged with bare minimum feedback to keep it's output reasonably clean. Removing (De-soldering) the screening box reduces losses, but it's still marginal. Something in the osc. circuit is temperature sensitive, so squirting it with freezer spray - or putting the set in the 'frig will get it going again. Have one like this, "Repaired" - been going for about 5 years and just quit again! If I get any better luck next time, I'll re-post this!
Posted on Jan 27, 2011
My Seat Arosa car radio won't work after the battery went dead .
Normally put radio code in by holding the buttons as the numbers come up
Jan 13, 2018 | Cars & Trucks
Seat toledo aura radio code - safe mode !
tells me we display with 2 safe and do not provide any opportunity to set the code
May 08, 2012 | Car Audio & Video
Anyone have the code to reset this radio. battery went dead now the radio will not come on ?
Try checking your fuses. If the radio doesn't come on a code is not going to do any good. As far as I know these radios don't require codes anyway.
Apr 14, 2011 | Virtual Reality VRCD500-SDU CD Player
How do I enter my security code into my Grundig CAR200 car radio
CAR 200 Code Entry
Press and hold the [ AS ] key and switch on.
'SAFE' will display followed by '10 - - - - '
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ AS ] key to accept
May 20, 2010 | Car Audio & Video
Unlock code for grundig car 200 radio cassette
reset code for grundig car200 casette radio
Sep 02, 2009 | Vehicle Parts & Accessories
Safe mode on Grundig 200 car radio, do not know where to find serial number.
Grundig 200 car radio can decode in the next way:
First step: Switch off the radio and the ignition as well.
Second step: Push the AS button and keep it pushed, at the same time turn on the ignition.
After this you will hear a beep sound. Now you can release the AS button.
Now you can enter the code in the next way: The first number can be set with the button ''1'', the second number of your code can be set with button ''2'' and so on. By pushing the ''1'',''2'',3'',''4'' buttons the value indicated in the screen will be increased by one. So if the first number of your code is 5 then you have to push the button ''1'' 5 times.
if this doesnt work then it will be cheaper to buy a new car radio contact me and let me no how you get on :)
Oh and the serial number is either engraved on the side of the unit or an actual sticker which is in the format you describe. You'll need to remove the unit from the dashboard to be able to get access to this.
Apr 20, 2009 | Car Audio & Video
Radio reads SAFE won't let me enter a code
Normally you do have to leave your car running sometimes 10 mins sometimes couple hours,
I had same problem with my one and i must have been driving around for days like it and one day it just decided to work
You may find that if you disconnect the battery for couple mins then put it all back together it will work
If not matey then you probley have a faulty headunit
so this is what i suggest to do
Number 1
Disconnect Battery for say 5 mins then connect it all up and see what happens if not you most prob do have a faulty headunit. you can take it to your local car audio shop and they will either repair it or decode it for you
Hope this helps you
Upfront Audio
Please leave feeback and rate thanks :)
Apr 17, 2009 | Car Audio & Video
Hi PJE, I had this same problem, and I did find a solution. If you contact me at chasgould@aol.com, I can try to walk you through this. Chas
Jul 28, 2008 | Grundig S350 AM/FM/SW Radio
Honda CRV Radio Code Error
My car (2005 Honda CRV) was shipped overseas and the radio asked for a code. After several tries, I searched the internet for a solution. Apparently Honda now allows you to obtain the code through their provided website. You will need the VIN #, the phone number and zip code that is on file when you purchased the car. Our car was purchased used and did not come with a manual. When I went to enter the code in I had already entered too many tries, now it reads ERROR E.
However, even before having the code (as well as now that it reads ERROR E) I can get the radio working. Push in preset buttons 1 and 6 and push in the power button simultaneously. A long number appears - at that point I pushed preset button 2 and the radio operated normally. Unfortunately, I do need to do this each time I turn the radio on.
Apr 26, 2008 | Car Audio & Video
Grundig FR200 AM/FM/SW/DAB Radio Logo
114 people viewed this question
Top Grundig Audio Players & Recorders Experts
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
