Question about MyGuide 3100 GPS Receiver
Updates for the 3100 my guide
Ineed up date where can iget them
  • zzervakis Dec 28, 2008
    new map for the navigaitor
  • will Jan 11, 2009
    i need to update both speed cameras and maps for my myguide 3100 sat nav.
    can anyone please help?
  • 52 Answers
No chance from myguide as they have gone bust (i know as i own one and have tried) apparently other maps are available from Tele Atlas
Posted on Aug 15, 2009
I m using compaq presario cq40. when i opening my lapy igetting massage on screen ( windows 7 ,build 7600, this copy of window is not genuine) and my screen in black. so pl help mi about this.
if you have a genuine copy, make sure your date and time settings are correct and try last known-good configuration if available else repair or reinstall your OS installation
Mar 21, 2011 | Computers & Internet
How can i up date my sat nav my guide 3100
the only place that can provide updates if any are avail is at the web site for this GPS, we have no software downloads, that is very specific to this GPS and can only come from the manuafacturer
May 28, 2010 | MyGuide 3100 GPS Receiver
MY GUIDE SAT NAV 3100 SERIES Car GPS Receiver: my guide sat nav 3100 series update...
switches on but no navigation. Press navigation and it bleeps only but will not change mode for search
May 17, 2010 | Navigon MY GUIDE SAT NAV 3100 SERIES Car...
How can i update my guide sat nav
If the maps are on an sd card you may be able to put tom tom on but as for updates myguide no longer exist and so don't provide updates. Mine still works fine and any roads that have been built that don't appear on the sat nav i have managed anyway.
Mar 18, 2010 | MyGuide 3100 GPS Receiver
HOW TO CHANGE DATE FOR 2010
on a PC, double click your Clock on the lower right hand side of the screen. adjust to the correct date. If this did not update automatically then you have issues with your operating system or system board.
Jan 03, 2010 | Symbol PDT 3100
Magellan maestro 3100 frozen on blue screen tried power on and off and reset button still frozen black bar at bottom of scren stays on blue screen
i just replied to a fellow with the same problem and since your problem is same, ill post what i wrote him/her but try a hard reset 1st..turn the gps on then locate the little pin hole on the side, using a paper clip, push reset....if that fails, try the 2.18 update if you havent already.
updates for any magellan can be found HERE
but read below first before getting the update
i cant stress enough that patients is a must here. this update is huge 1.75GB
follow the instructions below whether you have updated your gps already or not!
There are few ways to solve this problem. i assume you installed the 2.18 update for the 3100 and assuming you tried the reset already, try and run the update again and follow the directions to the letter..make sure the battery is fully charged (i also keep mine plugged in if the update doesnt say not to) and do not try and run the update across a network. this update is huge 1.75GB and can take an hour or so depending on the computer..do not interrupt the update process. if you do not have the 2.18 update read me file, i can try and post it here, but its in PDF and dont think i can post that
if all else fails, magellan will fix or replace for free any of there gps that were rendered inoperable due to one of there updates.
either solution will work but magellans going to tell you to run the update again anyway before sending it back.
i gave you the 2 easyest ways to fix it,but
there are other ways to get it running again, but if your not comfortable copying and moving files...youll make it even worst then it is.
hope this helps.
bill
Comments: Jul 19, 2009 - here are a few key points, but read the full update guide before trying the update again.
hope this helps
NOTE: This update is COMPATIBLE ONLY with Windows® XP.
Before Beginning:
Check to make sure you have everything required for updating your unit:
• Magellan Maestro 3100 GPS
• PC running Windows XP
• A Blank SD memory card (16 MB to 2GB)
• USB cable
• Paper clip or similar object (for resetting your unit)
EACH OF THE FOLLOWING POINTS IS CRITICAL TO THE UPDATE PROCESS
1) The battery of your Maestro 3100 must be fully charged before beginning the update.
NOTE: It takes between 3 and 4 hours to fully charge the battery with your vehicle power adapter. Check System Settings to ensure the battery is fully charged.
2) Your Address Book will be erased during the process. Please back up your data to an SD memory card.
a. Insert a blank SD memory card
b. Select User Options
c. Select Backup and Restore
d. Select Yes to confirm
3) Do not connect your Maestro 3100 to your PC until instructed to do so by the Update Wizard.
4) Close all other applications while performing the update.
5) Disconnect all Pocket PC devices from the USB ports on your PC.
6) Insert a blank SD card (16 MB to 2GB) into your Maestro 3100.
7) Perform a hard reset on your Maestro 3100 by pressing a paper clip or similar object into the hole marked reset.
Update Process:
1) Launch the Magellan_Maestro_3100_2_18.exe file.
2) Select Next on the Welcome screen.
3) Turn on your Magellan Maestro and connect the USB cable.
Jul 14, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Printer
you check for the updates from dell website
Jul 03, 2008 | Office Equipment & Supplies
MyGuide 3100 GPS Receiver Logo
452 people viewed this question
Top MyGuide GPS Experts
Ric Thomas
Level 1 Expert
LP
Are you a MyGuide GPS Expert? Answer questions, earn points and help others
