Have an acer 2000 series, model type CL32. will not power up, put the power jack in, the battery (blue) flickers but wont stay on to give power
    Scholar:
  • 100 Answers
Try a couple things for me first--
*put your comp on a flat stable surface.
*look at your power cord. there is a big box in the middle of it. check to make sure the wires on either side of it are pushed in all the way, if it is the kind that unplugs from the box like mine are.
* open your notebook and plug the cord into the back.
* while holding the plug firmly into the back of your notebook, turn it on and try to boot up.
if this doesnt let you turn it on and boot up, you have either an internal power supply problem, battery problem or possibly a bad power cord. you would need to have someone physically check this for you.
If it does turn on. the jack in the back could be worn out, loose or what have you or the cord is possibly bad.
please let me know what happens
Posted on Dec 25, 2008
Fault finding
What! !O_O!
For a statement, such as, "Motherboard not on", you would be stating the motherboard either does not receive power, or the motherboard does not use the received power.
Primer:
You press the Power On button. The first chipset to receive power is the BIOS chipset. The Basic Input/Output System program is initialized.
BIOS looks to see what devices are connected, does a Ram Memory count, turns the Processor (CPU) on; and hands the computer over to the Operating System. (In this case a version of Microsoft Windows)
If the statement is the motherboard is not turning on, you are in effect stating the BIOS chipset is Not receiving power.
Diagnoses must start from the AC adapter (Charger) You need to know if the AC adapter is putting out the correct Voltage. Also while testing have an assistant, gently wiggle the cable FROM AC adapter TO laptop; and power cord TO AC adapter. Any fluctuation in the reading, means a broken wire.
AC adapter proves to be good, the diagnoses goes to the DC Power Jack. The DC Power Jack is the jack on the laptop, that the AC adapter plugs into. (DC_IN)
AC adapter removed, Battery removed; a small instrument is used to see if you can gently move the DC Power Jack. ANY perceptible movement means a bad DC Power Jack -> Replace.
DC Power Jack checks out OK, then the problem will most likely be the Power MOSFET's on the motherboard. They determine if the Battery is to receive a trickle charge, or full charge. Also determines if the laptop is to run off of the Battery, or just the AC adapter.
Using the HP Pavilion dv6000 series, and Pavilion dv9000 series of Notebook PC's; as an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
I can give a lot more, than the generic information above, if I had the Model Number of the Acer laptop. This is on the Bottom of the laptop. Post back in a Comment.
Regards,
joecoolvette
Apr 23, 2013 | Acer Computers & Internet
Does ACER ASPIRE One 11.6" have camera ?
Yes'
General Brand Acer Series Aspire One Model AO751h-1401 Part# LU.S780Y.002 Operating System OS Provided Windows Vista Home Basic Processor CPU Type Intel Atom CPU Speed Z520 CPU L2 Cache 512KB Chipset Chipset Intel SCH US15W Display Screen Size 11.6" Widescreen Display Yes Display Type WXGA Max Resolution 1366 x 768 Display Feature LED backlight & Acer CrystalBrite Technology Graphics Graphics Processor Intel GMA 500 Video Memory Shared system memory 2GB Hard Drive HDD 250GB Hard Drive RPM 5400 RPM Hard Drive Interface SATA Netbook Camera Camera Type Acer Crystal Eye webcam Communications LAN 10/100Mbps WLAN 802.11b/g Wireless LAN Expansion / Connectivity USB 3 x USB 2.0 Video Ports 1 x VGA Audio Ports 1 x Headphone/Speaker/Line-Out Jack 1 x Microphone-in Jack Audio High-Definition Audio Support Speaker Built-in stereo speakers Input Device Touchpad Multi-gesture Touchpad (Circular-motion scrolling, pinch-action zoom, page flip) Keyboard Standard Card Reader Battery 3-cell Li-ion Battery (2200 mAh) Battery Life Up to 4-hours Manufacturer Warranty Labor 1 year limited Parts 1 year limited
Oct 14, 2011 | Acer Aspire One AO751h-1401 11.6-Inch...
I have an acer one, and it went into hibernation, and now it wont come out, when i hold the power button a blue light flickers above a light bulb on the key bored, but for some reason it wont come on
I would remove all the power--that is, unplug it from the wall and take out the battery.
Wait a couple of minutes and replace the battery and, if you are using it with the computer plugged in, plug it in again.
This was a common problem with Vista when it first came out.
Sep 23, 2011 | Acer Aspire One Netbook 8.9" Notebook
My laptop battery i guess hit critical stage but now the system wont work with ac power
DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 26, 2011 | Acer Aspire 7520-5185 Laptop
My hp pavillion dv6700 will not power up all of the blue lights will flicker as i press the power button for a few seconds then it will power off. ive tried taking the battery out and running it strictly...
Your DC jack may be loose or broken off the system board.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it's still under warranty, it would be fixed at no charge to you.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Jan 19, 2011 | HP Pavilion dv6000z Notebook
Hi my sisters laptop is a acer 5315 series and as soon as you push the power button the laptop shuts off after 2 seconds
Have you had the power adapter checked to see if it putting out the proper voltage required for running the laptop and charging the battery? You might also want to check your power jack to be sure it is not bad or the solder connections to the board are not broken.
Sep 23, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 5600
You still need to test the AC cord better.. Wiggling it in different areas to see if there is a break in the wires.... That is why i said watch for the Power light (when I say Power Light, not the one on the ac adapter cord... the power light on your laptop...)to see if it flickers or turns off at any point while you're testing the cord... If you have a Solid Lighted Power Light the whole time youre testing the AC cord (bending & wiggling it) then it is probably not the cord itself and i would then lean towards the DC jack...
Jun 04, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Laptop was working fine, but doesn't turn on anymore...
a5e3d98.jpg You might have a Loose DC Power Jack.. Or.. if you're using the same AC Power cord for both laptops that you tested, you apparently have a break(short) in the Power charging cord which is quite common...
To Test the cord..take the battery out and try to boot with just the AC power cord plugged in, If it does'nt power up, try turning and slightly twisting the plug into the port.. LOOK to see if the power light is on or flickers...
Computers & Internet Logo
90 people viewed this question
Alun Cox
David Payne
David Payne
