Question about Dell Dimension 8400 PC Desktop
Uncontrolled sound I get voice from an unidentified source on my speakers. Is it possible i have a virus that activates this problem? I have run a scan with McAfee but does not help.
  • chris dowell May 11, 2010
    Does this occur only when you are on the web or other times ?
  • 27 Answers
If you have the speakers next to the monitor move them away from it, keep the monitor and the speaker seperated by atleast 1 m,
Posted on Feb 07, 2009
    President:
  • 948 Answers
It is possible that a virus can do that. Please make sure your Windows is updated by going to Start-->Help and Support, then in the Pick a Task section click "Keep your computer up-to-date with Windows Update"
Posted on Dec 31, 2008
CANT TURN VOLUME UP ON LAPTOP
Hi...
Your problem may be due to some problems.
among these are problems in the audio driver or settings problem ataupau speaker on your computer's sound system has changed.
The first thing you need to ensure that the whole setting on your sound system is activated or the situation could possibly use.
if the same problem, do troubleshooting on your speakers using the ear phone to troubleshooting.
If the status remains the same, check your sound drivers or remove the existing driver and then re mamasangnya the updated driver from the manufacturer.
if all these measures are not successful, you need to reinstall the operating system (reformat) to identify whether the problem comes from the operating system or device. but if you do not want to take the decision to reformat the operating system, you can just change the sound device and all your problems should be done, unless there is a problem of your operating system from virus attacks, it is likely it also will disrupt the operation of a voice device.
TQ
Sep 16, 2011 | Computers & Internet
I need to know how to bridge the mtx speaker 4500
I assume you mean wiring a dual 4 ohm voice coil sub to a 2 ohm load, right?
Follow closely
Go from positive of the source (amp or positive post in box) to the positive of both voice coils.
Then go fromt he positive of the source (amp or positive post in box) to the negative of both voice coils.
You will be running two length of speaker wire for this. It's the easy way and makes sure that each voice coil gets clean power.
This is called a parallel set up and will bring two 4 ohm voice coils to a 2 ohm load.
Happy Wiring
Aug 14, 2011 | MTX Thunder 4500 T4510-04 Car Subwoofer
All of a sudden no sound for the DVR. All others have voice.
Check the obvious: A mute control activated or volume down on the unidentified DVR? Check the Audio path from the DVR, port assignment on the Yam if the audio is digital, maybe look at the manuals.
Jul 29, 2011 | Yamaha RX-V663 Receiver
I have tv hooked up to the pioneer but the TV will not play its sound through the speakers? what Am I doing wrong? I have the DVD hooked to the Pioneer and it works fine.
Is the unidentified TV a sound source from the SX-315's perspective? Is it's audio output enabled whene the TV volume is down? Would the Cable Box be a BETTER source?
Jul 26, 2011 | Pioneer SX-315
When playing a movie,everything sounds great until the actor speak.it sound very low or as if it were muted?
Your unidentified electronics probably has a manual that explains how the center channel functions and how to test and calibrate all of the speakers BEFORE you assess overall sound.
Your unidentified source may also be responsible for the missing dialog.
Jul 23, 2011 | Audio Players & Recorders
I have an old Philips Amplifier which I bought 18 years ago. The Amp actually can handle 5 speakers but I only connect 2 speakers (L & R). When I play certain DVD, although the background music sounds...
If you identified the specific products involved we (and you) might be able to look at the documentation and verify the obvious answer. Voice is generally concentrated on the center channel, so, yes, a speaker there would be a good idea.
If you don't have a multi-channel rig you shouldn't feed multichannel audio to it. Maybe use the unidentified DVD player's analog output and make sure it's set to mix the channels down to stereo.
Jul 01, 2011 | Philips Audio Players & Recorders
I have a Onkyo TX-8222 receiver. Sound is ok for music but voices are very low. When two voices, one is very clear abd the other very low. What is the problem ?
You don't say what source(s) are affected. I'm guessing TV or Cable-TV is the problem because music with vocals has voices and you say it sounds ok. Your speakers have no clue whether a sound is a voice or music so that lets THEM out and your receiver doesn't know or care either.
In the modern multichannel world it's usually assumed your electronics are multichannel. This receiver is old-school stereo.
The Center channel is usually where voices are found but some systems (like yours) don't have a Center speaker so they have to be configured to share the Center duty with the front left and Right speakers.This isn't possible or even normally necessary in your case. WYSIWYG
http://www.retrevo.com/support/Onkyo-TX-8222-Receivers-manual/id/469ci869/t/2/
The audio coming in from 'wherever' should be correctly mixed to 2-channels at the source or you'll probably be missing something. I'd look higher up the audio food chain for where the voices are being attentuated. If a cable box is involved I'd look at its audio settings regarding stereo mix-down
Wait, I just had an inspiring thought. Centered voices being mono in nature would partially cancel out if your two speakers were out of 'phase' with each other. Bass would also suffer. Make sure your two speakers are wired identically regarding the red and black (or plus and minus) conductors. If turning the Balance control fully to one side makes bass of voices sound louder you probably have a phase mismatch. Reverse the wiring on either speaker to match the other. There is no absolute right or wrong for phasing as long as they're all the same.
Dec 31, 2010 | Onkyo GX-D90 Main / Stereo Speaker
Our Dell computer speakers work but the sound is not normal voices. It's like the voices are animated
It is possible that a setting on your soundcard has the pitch of the voices higher than normal or an effect is turned on that isnt required. Have you tried plugging the speakers into another source to see if it sounds the same?
Nov 16, 2009 | Dell Dimension 2400 PC Desktop
No sound, no outgoing call jamin imate
I dissambled my iMate JAMin and found that one of the wires for the speaker had been broken, they seem to be pretty weak - resoldered the wire now speaker works fine.
Jan 28, 2009 | i-mate JAMin Smartphone
Surround center speaker does not work
This is a 5.1 (6 Channel Technology) You should hear only the voice thro the center speaker. If the source you are playing is stereo, however the software splits the source its difficult to seprate the voice track, if the source is a DTS 5.1, then you should hear the voice only thro the center speaker. eg: when you play a DVD movie which is DTS 5.1 then you should hear only the voice track in the center speaker, if the dvd movie is just stereo then you will not hear any audio in the center speaker, while the other four speakers get output, this is the special effect in 5.1 ( 6 channel Output).
Dec 27, 2007 | Inland 58019 ThunderSound 5.1 PCI Sound...
Dell Dimension 8400 PC Desktop Logo
35 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
