Question about Motorola Mobility SLVR L7 Cellular Phone
Memory cards are not working in my phone
Whenever i try ro use the camera my phone hangs.. even if i try using a different memory card stilll my phone doesn't work!
  • Anonymous Dec 27, 2008
    is it a possibility that there's a virus in my phine??
    Brigadier General:
  • 7,752 Answers
Te firmware needs to be reflash on the phone so take it to a reapir shop and have that done.
Posted on Dec 27, 2008
Whenever i try to take a picture or press the " Qmenu" button "this memory card is locked" comes up. How do i solve this thanks.
Try taking out the memory card and putting it back in. If that doesn't work, try using a different memory card to see if that is where the issue lies. Also try to refer to the device manual for technical support:
Panasonic DMC F2 manual
Jun 16, 2014 | Panasonic Lumix DMCF2 Digital Camera
Tip
WHENEVER I MATE CELL GET HANGED ON BLUE SCREEN
I GOT THE SOLUTION REMOVE YOUR MEMORY CARD FROM CELL PHONE THEN PUT BATTERY AFTER THAT YOUR MOBILE GET ON AFTER GETTING MOBILE DESKTOP THEN PUT YOUR MEMORY CARD IT WORK PROPERLY BUT YOU TO PAY ATTENTION WHENEVER U SWITCH OFF U HAVE TO REMOVE YOUR MEMORY CARD TILL THE MOBILE DESKTOP APPEARS
on May 25, 2010 | Cell Phones
My phone reboots whenever i insert my memory card with music
It is possible that the phone hangs up because there are errors in the memory card/software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Jul 26, 2011 | Samsung B3310 Cell Phone
My nikon D200 shows CHA whenever I insert a CF card? How can I fix it? It shows that error even I use a different card.
Dear Sir e_jamandre, probably the connector memory card has one or more bent pins or cracked solder.
The worst thing would be that the memory compression circuit is damaged.
Greetings
Feb 11, 2011 | Nikon D200 Body Only Digital Camera
How long does it take to format the SD card? I have been waiting for this card to format for an hour. Message appears "no card" when the card is in the camcorder. Thanks,
You don't say what make or model of camera or the size of the memory card, so I am going to have to do some guessing.
My guess is that the memory card is incompatible with the camera. That would explain why the card is not recognised and why the camera cannot format it (it tries to, but hangs). Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. It is often difficult to find out the maximum capacity memory card a camera will use, as today's cards are much larger that those available when the manual for the camera was written.
There is a common problem with SD cards. "SD" cards larger than about 1GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
Jan 03, 2011 | Cameras
Not enough Memory, LG Renoir camera
From the settings menu, choose phone settings, then Memory Manager.then handset common memory. Chances are, this will nearly all be used up. Move any pictures, video, music etc from the internal memory to the external memory card using the My Stuff application, then move to external memory. This should solve the problem & any new photos will be stored on the external card. When theinternal memory gets full, the Renoir does funny things!!
Jul 11, 2009 | LG KC910 Renoir Cell Phone
Canon A560 will not erase pictures
Two possible solutions.
1. Apple users have reported that the switch on the memory cards performs the file lock function in either extreme positions Lock/Unlock. In some cases they have achieved success in centering the Lock/Unlock switch allowing access to the read/write operation of the memory card
2. Connect to PC
Access drive via windows explorer
Right click on drive (MEMORY CARD)
Select properties
Confirm that RO (Read Only) is not selected.
Selected RO
Try reading card
Repeat properties un-select RO
Try deleting files
If not successful card is likely defective
Hope this helps?
Mar 12, 2017 | Canon PowerShot A560 Digital Camera
Kept on hanging up
jha - you could be having a problem with the memory card, you could try a new m2 card and see if it hangs if it does not it was the card but if it still hangs with a new card then you should try and reflash the firmware on the phone.....to fix it...you can do this online at topsony.com or at a mobile service center.
Guest - reflash the firmware on the phone
Jan 27, 2009 | Sony Ericsson W910i Cellular Phone
N6680 camera is not working
Make a backup on your PC first,
Eject Memory Card from Phone
Format your Phone,
then Format memory Card through PC
some unnecessary library files in your memory card cause the camera not work
try this! :)
Jan 20, 2009 | Nokia 6680 Cellular Phone
LG kf600 memory card prb
see there can be 2 reasons.
firstly that your memory card is not in the good state anymore.
secondly, this cell supports upto 2 gb memory card.so you should not go with 2gb i.e it's max. capacity, instead u go for 1 gb card.it wont create any problem.
you should not use the memory card of the max. capacity which ur mobile supports as most of the times it creates problems like this and even keeps on hanging frequently.
Dec 26, 2008 | LG KF600 3MP InteractPad Triband Phone...
Motorola Mobility SLVR L7 Cellular Phone Logo
18 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
