Question about Reddy Heater-30-55,000 BTU Variable
Model R110 Does not ignite on startup
Have taken the cowl top cover off and observed the system on startup. The fan comes on but there is NO spark at the plug and NO ignition. What component may be bad and where do I get parts?
  • 232 Answers
Check:
  1. be sure the transformer is grounded
  2. If 110v is going in but nothing going to the plug then order an Ignition Device #102482-01
www.reddyparts.com keep them in stock
Posted on Dec 26, 2008
Remington 35 portable forced air heater parts
Top cover is shorting out the spark plug wire.
Jan 10, 2014 | Heating & Cooling
I have a 98 gmc 2500, w/ 454 engine.. Recently the engine was making some major noise so I took off the valve covers to find that the pushrods were very loose. I then dissected the truck taking off the...
Engine Cranks But Will Not Start Basic Checks:
A. Test Fuses. Test both under hood power distribution center and the fuse panel under dash. This is done with a test light tool. The test light should illuminate on both sides of the fuse, if not the fuse has failed and needs to be replaced.
B. Testing Fuel Pressure Test for proper fuel pressure with a test gauge on the fuel rail, most throttle body injection cars (TBI) are between 13 psi and 17 psi. and most (DPI) direct port inject systems are between 40 psi and 55 psi. If no or little fuel pressure is observed and there is 12 volt power present the fuel pump, the fuel pump needs replacing.
C. Checking Timing Belt Test for compression by removing a spark plug and insert a compression gauge. Crank the engine over about 5 seconds the gauge should read between 125 psi and 165 psi, if no compression is observed remove front engine cover to inspect timing belt or chain. Crank engine to observe cam rotation, if the cam does not rotate the timing belt or chain has failed. (note: if the timing belt drives the water pump it is best to replace the water pump at this time)
D. Test for Injector Pulse Remove injector connector to insert injector test light (node) or volt meter. Observe light flash or gauge pulse while cranking. If light/voltmeter doesn't respond, an ignition distributor/crank angle sensor (CKS) or an ignition module is most likely your problem.
E. Test for Ignition Spark Remove spark plug wire, insert an extra spark plug into end of wire, rest spark plug next to a ground source then crank engine. You should observe a blue spark between the spark plug gap and ground source. If no spark is observed, an ignition coil, ignition rotor or spark plug wires might have failed. (always keep hands away from engine when cranking)
The ENGINE CROSS-SECTION below (typical 'V-8' ENGINE) shows all main ENGINE components and indicates the exact location of the most HEAT DAMAGE PRONE PARTS - THE HEAD GASKETS.
Jul 18, 2008 | GMC Sierra 2500 Cars & Trucks
Where are the spark plugs located in a 2004 GMC Envoy, 6 cyl
Hello erikkaloves,
The spark plugs are under the coils. To get to them you must remove the plastic cowling from the top of the engine. Then you will see the coils, there will be six coils, one for each cylinder each looks the same with an aluminum heat sink on the top. These are removed by removing and the retaining the screw and wires.
Once removed the spark plugs can be access but before you remove the spark plugs make sure the spark plug well is clear of foreign material. Dirt or debris in the spark plug well can fall into the engine and cause damage.
Regards,
netvan
Feb 23, 2011 | 2004 GMC Envoy
Model SRG 300 Series 09 Serial # 424030XL The top burners will ignite only 5 or 10% of the time. There is a clicking sound but no spark. When the burners do ignite and are turned off they will not...
You hear clicking but there's no ignition. First thing to do in this case are the following observation checks which do not require any tools, instruments, or taking anything apart.
Check the spark color. A healthy ignition system will produce crisp blue sparks. A weak ignition system, on the other hand, will produce light blue, almost white sparks. If yours produce a light blue, it means your ignition knob is bad and will need to be replace.
Take care.
Aug 13, 2010 | Maytag Kitchen Ranges
I have a Reddy Heater Model R110. It has operated great until it ran out of fuel. I filled it up and now it will not ignite. It is pumping fuel as fuel is running out the front of it. I cannot find my...
remove the cover and check for spark at plug when plugged in if no spark check spark plug gor proper gap, or defective transformer electronic ignitor if you see spark check for proper pump pressure and restricted fuel flow due to seal leak, filter blocked and restriction in nozzle. I would check for defective photocell first for soot/dirt if dirty wipe with clean damp cloth remove photocell from heater and connect ohmeter on the 1000 ohl (rx1k) scale. Hold the lens up to a light source (60 wtt bulb, with the lens of the photocell pointed towards the source the resistance of the meter should be low by clocking off the light source by putting thumb over opening of cell the resistance on meter should be high, replace photo cell if a change in resistance is not observed during this test, let me know if you need more assistance
Dec 07, 2009 | Reddy Heating & Cooling
My reedy heater pro 110 blows fuel out the front but does not ignite and then shuts down
The Pro 110 comes in 2 different technologies. The true model (examples: R110, RHD110T, etc) designates which technology your heater has. Rather than ask for clarification I am posting links to Troubleshooting Tips for BOTH types. You must investigate to see if your heater is the Spark Plug technology or the HSI (glowbar) technology.
Troubleshooting greatly differs between the 2 types.
Spark Plug Tips
HSI Tips
Nov 15, 2009 | Heating & Cooling
Cannot remove casing around ceiling. Hampton Bay
Try twisting the bezel (cover) counterclockwise to unlock it from the mounting base plate on the ceiling. The other option is to see if the bezel/cowl has fasters (screws) holding it in place either from the sides near the top edge or at the bottom nearest the narrow portion of the cover.
Sometimes the fan cowl bezel is fastened using screws at the point nearest the motor shaft.
There could also be a trim ring that needs to be gently pryed off from the edge nearest the ceiling, so you can gain access to the screws that are holding the cowl in place on the mounting plate. There are usually 2 sets of 2 screws placed 180 degees apart from each other that secure the cowl in place.
I hope you find this Very Helpful and best regards!
Aug 20, 2009 | Hampton Bay Dryers
1992 Volkswagen Cabriolet
CHECK TRANS IGN UNIT NEXT TO WIPER MOTOR UNDER COWL COVER FOR CORROSION OR WATER
May 11, 2009 | Volkswagen Cabriolet Cars & Trucks
Reddy heater r110
Take reading on the air pump. Is sounds like the pressure is low, therefore not sucking fuel. It's a place to start, anyway.
How to check the pump pressure
Dec 05, 2008 | Reddy R60A Utility Heater
Cranks but wont start
For an engine to run, you need three things to happen inside the engine. Compression, fuel and ignition, without any one of these components the engine will not run.
Basic Checks:
Jul 14, 2008 | Hyundai Motor 2002 Sonata
Reddy Heater-30-55,000 BTU Variable Logo
95 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
