Question about Maytag Neptune MDE5500AY Electric Dryer
How to remove a back panel of maytag neptune dryer?
I have to fix a tall baffle in a drum of Neptune maytag dryer, but i don't know how to remove a back panel to do so. I removed all bolts a screws but don see a way to remove the panel.
  • 4 more comments
  • Anonymous Mar 24, 2008
    I have a tappan dryer and i can't figure out how to get the back off i took out all the screws. but the back will not come off
  • Anonymous Mar 31, 2008
    I need to get into the back of my Maytag Neptune MD4000 dryer. How do I get the back off?
  • Anonymous Sep 11, 2008
    I am trying to get the back panel off but I don't know how Ihave removed all the srews in the back please help
  • jbfromal Apr 22, 2009
    belt is making a noise, like it is loose. How do I remove the back to get to the belt
  • Anonymous Mar 18, 2014
    can't remove front panel on maytag electric dryer
  • Anonymous Mar 22, 2014
    cannot locate screws to remove housing and replace wheel
Catriver was right on the mark. Took a little bit of doing but I was able to fix the problem myself within 30 mins, and saved some money. Many thanks. I'd like to expand Catriver's solution a bit.
I found a layer of lint on the inside bottom of my dryer. With the face off of the dryer, it proved to be a good time to vacuum the lint out and reduce the potential of fire.
Posted on Sep 07, 2008
    President:
  • 878 Answers
John, put all the screws back in the back. You are going to get it from the front. Remove the screws that hold the door in place. Lift up on door and slide the hinges out. Remove the two screws and spacers on the opposite side. Now pull the front panel forward and off. Now you will see two hold down brackets that secure the top. Loosen the screws and slide the brackets to the inside. Now the top will lift up and you can get at the screws for the baffles. Just rotate the drum till it's on top. Catriver..post back
Posted on Apr 15, 2007
I love you great advice and safed me some money kudos to you thx again
Posted on Jan 12, 2008
Maytag neptune dryer one of the dividers the screws came loose how can I fix this without calling for service
You are probably referring to the drum baffles. The baffles securing screws can be retightened by raising the top which requires the removal of the front panel. Click on the link below for the detailed steps.
Retightening the Baffle Screws on Maytag Neptune Dryers
Jan 24, 2011 | Dryers
The beater bar in my Neptune dryer modeL # MED5500AYW has come off and needs to be replaced.
It sounds like you are referring to the drum baffles when you say "beater bar". If that is so, you need to remove the front panel then raise the top cover to access the baffles mounting screws outside the drum. Below is the link to the procedure I posted previously.
Maytag Neptune Dryer Front Panel and Top Cover Removal
Sep 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
We have a neptune front dryer and a baffle came loose inside the drum. How do we repair it
an easy way of reinstalling the baffle is remove the top cover or rather flip the cover upward this will show you the dryer drum in which u can spin the drum to the proper spot where u can retighten the screws that hold the baffle on hope this helps
Jun 25, 2010 | Maytag Neptune MDE5500AY Electric Dryer
As dryer rotates, with clothes drying, it sounds like loose pocket change is loose in between the two tubs.........help!
the change gets caught in the three baffles that are attached to the drum.unplug the dryer,open the door and remove the two screws that hold the in place,remove the door,then remove the other two screws opposite the door screws and pull the front panel off.rotate the drum so one of the baffles are down in the right hand corner so you can get at the screws that hold the baffles onto the drum.try loosening the screws but you might have to remove the baffles to get to the change.let me know how you make out
Apr 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I know that I am asking this for the third time; however, on the other two I forgot to notate the make and model. Again, after I opened the top of the dryer, there were no coins, it seems to be the screws...
If the screws holding the baffles just came out of the baffles or if the baffle broke they can be reinstalled. If the screws have ripped though the drum, the drum will need to be replaced. The screw part number is 33002973. The short baffle part number is 33001755. The tall baffle part number is 33002032. If you need the complete drum it is part number 33001889. Below are the instructions on how to replace the drum. Parts can be ordered from this link.
below is a link to the service manual for the info u need to take aprt or replace the dryer drum on a Maytag Neptune, I suggest u print it and then enlarge it if u can read it.
http://media.fotki.com/1_p,swdbrqkqdgssrtkxgtqsskgwtqkq,vi/stkwfgbrgxkgtddqfqs/1/1303472/5961857/image7951020310251998097img-or.gif
Apr 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
How do I install a baffle for a neptune dryer?
unplug the dryer,open the door,take out the 2 screws that hold the door in and remove the 2 screws opposite the door screws,remove the door and pull the front panel off,spin the drum until you line up the baffle that you need to work on is down in the right hand bottom side,you can get to it there
Apr 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag dryer has a loose dryer drum baffle. How to i get to it inorder to tighten the screws? Do I remove the top
unplug Dryer, open door, Remove two door hinge screws going into front panel, remove two screws on opposite side. Grab front panel on upper sides and twist and pull front panel out. Panel sits on two clips at bottom so you have to tip panel out to unhook from the bottom. You will see a metal hook with two screws in it that holds down the top of the dryer on each side. Remove the screws and hook bracket. Make sure you note how it reinstalls. Top will now lift up and lean back against a wall. It is hinged in back. You can now easily get to the drum baffle screws. Good Luck, Appliance Specialists
Dec 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Inside of drum baffles coming loose on maytag neptune dryer
Hello.
Remove the door and the plastic pieces on the opposite side. Take the front panel off. There will be one metal bracket on each side holding the top panel down. Remove those brackets and lift the top. Turn the drum where the loose baffle is up top and tighten loose screws or replace missing ones.
Jul 18, 2009 | Dryers
Top Panel
there are 2 philips screws on the front panel 3" up from the bottomm remove screws and pull front panel from bottom then replace baffle scewes from the bottom
Sep 03, 2008 | Maytag Neptune MDE4000 Electric Dryer
You have a choice for which side front door should be on this model. There are 4 screws on front door. Take all 4 screws and pull down the front panel. You will see two metal parts each side which holds top panel. Remove two screws and metal parts. Now you can push up the top panel.
Mar 17, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
1,707 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
