Question about JVC AV-36D503 36" TV
Video swiching tv will not turn to video one and two, also front av ports won't work.
  • Paul Teichmann May 11, 2010
    Have you ever been able to switch to video 1 or 2? And, if you can't switch to video 1 or 2, how do you know the front a/v ports don't work, since they are probably input 1?
Have hook up to front av ports and tried to switch from video 1&2 and no change. To add to the problem it doesn't switch to video 2. thanks!
Posted on Feb 04, 2008
WHAT DO I PLUG IN THE BACK OF THE TV/DVD COMBO?
You may not have AV ports, AV ports being the ports that you would plug in a yellow video and a white audio cable into, so you may want to take a look at some adapters. Maybe an HDMI to AV adapter?
Tmvel mini RCACVS 3 RCA Composite Video AV to HDMI Converter for TV PC PS3... This one may cost you a bit, but if you don't have AV ports, but do have an HDMI port, this should work.
Dec 09, 2015 | Video Game Consoles & Games
I have a trutech tv model number plv1615 t I cannot find the manual I want to use it with my video player. Can you help
I'm assuming you have hooked up the video player and tried, and haven't got it to work? If so, Run the video cords to the correct places, i.e. yellow (video) to yellow port (front/back); white and red are sound, insert each to their corresponding places as well. Next, turn the tv on, as well as the video player, (dvd/vhs/etc) - next, if you have a remote use it to access the menu - then scroll through the list (usually with the volume up/down button, channel up/down buttons, or there will be arrow keys to use). Find in the menu the selection to choose which video port to use i.e., video 1, video 2, or AV, which is more commonly used - AV is usually the ports on the front side for tv's like this. If you do not have a remote, to access the menu (if not "menu" button is available on the front of tv) try using the channel up/down buttons on the tv, by pressing them both at the same time - also, using the channel up/down, or volume up/down buttons to scroll through the menu - to select, there will either be a "select" or "enter" button, or as one set of up/down buttons are used for scrolling, the other two up/down are used for selecting. Once you have determined the uses, find the channel selection, and try AV first. You may be able to find it easier first by simply flipping through the channels on the tv until it appears on the screen usually in the upper right hand corner in big letters -- AV. This will be the channel to use for video - if not, there is one other way to make this work - if the tv and video player have a co-axle port (cable cord connection) then use a co-axle cable. Plug it in to the back of the video player, and then the back of the tv. Select Channel three/four ( some video players have a switch on the back, so make sure they are both on the same channel). Most commonly used is channel 3.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
May 26, 2011 | Daewoo DTQ-19Z4SC 19" TV
Canrt seem to get a connection from box to the tv.all wires are in correct .have tried the hold the button untill it beeps twice an still no picture. platstation 3 3-275772-01
  1. Make sure the AV Cable is connected to the AV MULTI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the AV Cable into the yellow port for video, and into the white and red audio ports on the back of your TV.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive ON/OFF button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically be reset to the Standard Resolution (or detect the current display output settings of your TV/monitor).
Jun 25, 2010 | Sony Video Game Consoles & Games
My PS3 won`t work on other TV`s than my own at home. how can I fix this. I know it`s nothing wrong with the other TV`s I`ve tried it on.. It is almost like it has locked itself on one spesific TV.
its simple
plug ur xbox in ur old tv (which u used to play)
1. connect through hdmi port or av port setting
got o setting---video settings- video output change to automatic or which cever port u like
2. now pulg to other tv
Mar 15, 2010 | Sony Playstation 3 (PS3) Console
Will not play without using HDMI cable
  1. Make sure the AV Cable is connected to the [AV MULTI-OUT] port on the back of the PLAYSTATION 3 system.
  2. Connect the other end of the AV Cable into the yellow Composite port for video, and into the white and red audio ports (if your TV does not have the red port, simply ignore it) on the back of your TV.
  3. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  4. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
Want to view my canon mvx330i camcorder through my tv
Open the front plastic cover to the right of the lens and expose the ports. The yellow one is the AV port. Press the MENU button on the left side and use the rocker switch above to display AV-PHONES, select AV, and press the MENU button to set it and close the menu. Turn both  the camcorder and TV OFF.
Connect the camcorder AV port to the TV RGB inputs (VIDEO + AUDIO L + AUDIO R) with the cable that came with the camcorder. It has a mini stereo plug at one end and three RCA plugs at the other.
Switch everything on, press PLAY on the camcorder (don't forget to make sure the cassette is wound back to the start). sit back and enjoy.
Dec 11, 2008 | Canon MVX330i Mini DV Digital Camcorder
Can't get Leapfrog to work with Orion (13") tv
Use the TV/AV button on the remote to turn on the "ports".
Oct 13, 2008 | Orion Televison & Video
IBM ThinkPad 380Z AV Hook up To Tv
From what I have been reading, the video card in the computer itself MUST support TV out. You can't just use a TV like a computer monitor...it won't work. Check the ads on eBay for those adapter cables and they will say: Check to make sure your video card supports TV out. Go back to eBay and search in the same general area for a computer video to TV adapter or converter box. DO NOT get it confused with the converter box for HDTV. They are about $25-$35 and you will still need the cable adapter you already have, plus another set of just the AV cables. Good luck. Please rate this if it was helpful.
Sep 26, 2008 | IBM ThinkPad 380ED
Sayno Tv
You didn"t say already working in AV mode or not. Suppose if it is worked means this is the simple one just change programme (-) button in TV front panel till becomes 1 or 0. After 1 or 0 again you press down the same button you get AV mode. Even you won"t get try in menu features to change AV mode. Even you won"t get there is a problem in Micom section. Technical persons only sort out your problem by changing EEPROM ic. I hope the above information is useful to you.
Sep 02, 2007 | Sanyo DS31520 31" TV
An old zenith tv
press -------- |tvvcr | |source| -------- its by the timer button on the bottom of the remote
Aug 11, 2007 | Zenith C27A24T 27" TV
JVC AV-36D503 36" TV Logo
87 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
