Question about Samsung SPH-M300 Cellular Phone
Blue tooth peer device
Blue tooth wont connect to other devices will show that they are there ut thats it i get message peer device closed whats this ????
  • buckbeak Feb 22, 2009
    Everytime I want to transfer something using my bluetooth I doesn't have the option of transer photos from my cell to another and when someone is trying to send me a picture, appears a message that says "peer device is closed" or "cerrado equipo par" in spanish
Bajanguru
  • 7752 Answers
SOURCE: bluetooth connection
try another bluetooth device and if that work then try the GE Bluetooth headset.
Posted on Mar 26, 2008
nasirahmed
  • 282 Answers
SOURCE: 5400 won't connect to blue tooth device
Change the bluetooth device.
Posted on May 18, 2008
Bajanguru
  • 7752 Answers
SOURCE: D900 Bluetooth
try a hard reset *2767*3855# then try again
Posted on Jul 04, 2008
SOURCE: samsung U 600 failing to connect to blue tooth conection
My daughter's Samsung U600 connects to her Clarion Alpine CDE 103BT radio OK, and she can call from the phonebook in the Clarion OK. However an incoming call shows up on the Clarion but then is immediately dropped. The chap who fitted the Clarion said it would answer calls automatically. Even if this wasn't the case and she had to press a key on the Clarion to pick up the call there wouldn't be enough time for her to do this.
Is this a Bluetooth connectivity problem or is there some setting that would correct this?
Posted on Apr 12, 2009
  • 181 Answers
SOURCE: blue tooth wont pair with anyone/thing
have you put in a code this is usually 1234 or 0000 these codes are put in both units to pair them. the same number has to be put in both devices.
Posted on May 24, 2009
New purchase alcatel one touch mega lte bt wont link to buddy
Sounds like it doesn't support peer to peer connections
Feb 22, 2015 | Alcatel Cell Phones
How do I connect a blue tooth device that is already paired in my Samsung intensity 2?
Disconnect it first. means power off. unpair the device restart devices pair it again.
Oct 11, 2017 | Samsung Intensity II SCH-U460 Grey Verizon...
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I have a nokia 2730. but the bluetooth is not working properly. whenever i tried it shows "sending failed" to any other mobile.
Hi,for the blue tooth to work, first you will have to pair the device you want to use with it. Without pairing the device it will work.
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 25, 2010 | Nokia 2730 Cell Phone
How to connect sony ericsion w395 via blue tooth
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Take care.
Jul 07, 2010 | Sony Ericsson W395i GSM Quadband Phone ...
Cellnet Pico Bluetooth Headset wont connect to nokia 5800
Take care.
Jun 10, 2010 | Cell Phones
Bluetooth is not found in the control panel of my laptop
goto start and type bluetooth in search...if bluetooth drivers are installed ull get some icons like bluetooth, bluetooth devices etc.....try clickin bluetooth devices.....n u can try to connect with ur mobile.....if it doesnt show anythin u may have to install bluetooth drivers....hope this helps...
Mar 07, 2010 | Lenovo ThinkPad R61i 14 inch widescreen...
When i transfer songs from other mobiles via blue tooth, i get the message 'Operation Failed'.
Maybe your phone does not support the song format or you may not have free memory,
Feb 18, 2010 | Nokia 3110 Cellular Phone
Conecting blue tooth
You did describe the full question.
If you have facing some problem while connecting via blue tooth check you these sittings
you phone have name in blue tooth
your phone should be visible on
And you should one it while connecting to any device then you can search for any blue tooth device.
Let me know if you have any other question regarding this topic.
Nov 18, 2008 | Cell Phones
Samsung SPH-M300 Cellular Phone Logo
296 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
