Question about Gigabyte GA-6BX7 Motherboard
My pc can't boot
After i replace the battery of cmos on my gigabyte motherboard my pc cant boot up anymore,when i press the switch button and press the delete button to enter the cmos, the display reads preparing to set up but it already takes several minutes and still nothing happens. My pc motherboard is a Gigabyte GA-945ZM-S2, with pentium D processor, 2gb ddr2 667 RAM,256MB Nvidia video card.
  • 741 Answers
Make sure the battery is facing the correct way.
Posted on Dec 25, 2008
Cmos checksum erroe defaults loaded
press del to enter setup.then choose default bios setup. then save and exit.pc will restart.
Nov 17, 2011 | Gigabyte GA-945GCMX-S2 Motherboard
Bios not start.Only cd start but original bios not detected
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
if no luck
try removing the cmos battery although on some motherboards the cmos batteries are soldered in
which makes it hard or unlikely
hope this helps you
Oct 12, 2011 | Gigabyte GA-965P-DQ6 Motherboard
My computer is blue screening when i first load it up windows 64 bit home edition gigabyte k8n sli motherboard
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
hope this helps
Mar 30, 2011 | Gigabyte K8N-SLI (GAK8NSLI) Motherboard
I have gigabyte gl 81915 motherboard on my cabinet. but some days ago it's display check sum error default loaded so how can i solve it give me solution?
The CMOS checksum error occurs when the CMOS battery is worn out and the CMOS data gets corrupted. Replace the CMOS battery, this battery most likely a CR2032 lithium coin size button battery - check to make sure before you purchase.
After replacing with a new battery, then go to the BIOS configuration and set the Time
Sep 02, 2010 | Gigabyte GA-945GCMX-S2 Motherboard
Came home computer was on black screen and now it won't reboot. When I try to reboot, I get a "cmos checksum error ". Keyboard also isn't working. What could be the problem?
After replacing with a new battery, then go to the BIOS configuration and set the Time & Date etc.
Sep 02, 2010 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Power supply works but pc doesn't power up no lights and fans dont work
Have you checked the power supply in different system? If yes then first replace CMOS battery and switch the CMOS battery jumper. And while doing this please unplug the hard disk or optical drive data cables and power. If it does not work then check the power switch is working or not or it is perfectly connected with the front panel PINS on the motherboard. If it is not connected perfectly computer will not start after pressing power button.
Second Level Test : Remove the CPU Fan - replace the CPU perfectly - again place the Fan.
Third Level (motherboard test): Just take the motherboard removing CPU,RAM, SMPS - use another same type CPU, RAM and SMPS - if it does not work so it is motherboard problem. If it works may be CPU problem.
Jun 12, 2010 | Gigabyte GA-8LD533 Motherboard
Asus Eee pc 900 can't boot (blank screen)
Just had the same thing happen, and I thought it was the motherboard. Then a tech friend removed the battery and held the power button down. Then he replaced the battery, and it booted up fine! Good luck...
Aug 14, 2009 | ASUS Eee PC 900 PC Notebook
Reset BIOS
In order to reset BIOS you need to remove the CMOS battery located on the motherboard and re insert again
Jun 20, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
Booting problem
I think the CMOS battery is not connected properly when it is taken off and replaced. Check if the connector on the top is in contact with the battery correctly.
Feb 22, 2009 | Gigabyte Computers & Internet
My motherboard cant boot-up
did you put the jumper back in correctly ??
if yes then
1.) unplug the system
2.) remove the cmos battery and the rams (memory)
3.) press and hold the power button for 10 seconds
4.) replace the battery and the rams
5.) plug it back in and turn it on
6.) if it boots, enter the cmos setup and load optimised defaults
Jul 14, 2008 | ECS Computers & Internet
Gigabyte GA-6BX7 Motherboard Logo
167 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
