Question about Kitchen Ranges
My new gas stove (propane) is releasing black soothe when lit. All the pots are covered in this black powdery like substance. Whats the problem and how can i fix it. It's really costing me a lot to clean .
  • 413 Answers
All gas stoves are set up for natural gas. Before using on propane, the oven and burners need to be converted for propane operation. Refer to the installation manual for conversion requirements for your particular stove.
Posted on Dec 25, 2008
Carbon residue on pots
There is an adjustment for correcting the air mixture on the gas line going from the knob to the burner. It usually is located at the point where the adapter nozzle enters the gas line going to the burner.
Aug 13, 2017 | Kitchen Ranges
The stove and cook tops send all the pots black with soot
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Aug 28, 2011 | Ovens
My pots and pans are covered with soot. We us propane for our 6 burner heavy duty gas range
u stove is designed for natural gas you need to retro fit or change the gas valve over to propane or locate a propane adapter kit for ur stove check with appliance part stores or product company
Oct 29, 2009 | Imperial Commercial Cooking Equipment...
Engine stalls occasionally even with new ignition system
The powdery black substance tells me that your egr valve is not working.And that is operated by the vacum sysem.The pipe has probebly come of the EGR valve.
Jul 17, 2009 | 1989 Jeep Wrangler
Propane not getting to oven... stove top works fine..
The pilot light must be lit and stay lit before you will have any propane coming into the oven. This is a safety feature.
May 17, 2009 | Magic Chef 9122 Gas Single Oven
Yellow flame blackening pots and oven
Are you on LP/Propane gas or Natural gas?
Was the range set up by a technician?
Mar 13, 2009 | GE Kitchen Ranges
My new gas stove (propane) is releasing black soothe when lit. All the pots are covered in this black powdery like substance. Whats the problem and how can i fix it. It's really costing me a lot to clean...
There is usually a "shutter door" adjustment at the end of the burner to control the amount of air that is mixed with the gas. If you just did a conversion the air fuel mixture likely needs adjustment. You want a blue flame with faint yellow tips or optimal adjustment. Too little air causes soot and too much air is noisy and wastes fuel. Remove the burner (as for cleaning) and open the shutter door on it, replace, and retry until the correct burn is achieved. I don't have direct answer for the Kenmore. Did you try using the model number in Google or Ask? If you don't get a hit the call Sears Service and request a manual.
Jan 16, 2009 | Kitchen Ranges
Black is on the burners
the fuel to air mixture is set incorrectlty or your pressure at the ouitlet for the gas valve is too low.
you culd play around adjusting the first part of this but for the gas valve part you have to have a manaometer to check it out correctly. then it should be set at 10"wc. Good Luck
Jan 10, 2009 | Coleman Propane Grill Stove 9921-700
Flames are extremely uneven and high
okay, DO NOT USE THIS STOVE ON LP GAS.
It's not intended to be used with LP gas, because LP gas requires a smaller orifice than natural gas. Call your propane supplier IMMEDIATELY...DO NOT USE THIS STOVE UNTIL IT IS CONVERTED TO LP GAS (if it's even possible)...this is extremely dangerous and you could hurt yourself if you continue to use LP gas on a stove that was designed to run on natural gas.
Dec 06, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Burn marks on pot and pans
Just got a Garland 6 burner stove w/single oven. It was Natural gas need to convert to propane. Need supplier for conversion kit
Sep 05, 2008 | Garland H283 Gas Kitchen Range
Kitchen Ranges Logo
622 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
