Disableing wap / internet accsess on the samsung J700
I would like to know how to disable WAP / internet access on the samsung J700 i have got my daughter this phone and i dont like how easy you can make the mistake of going online so any help would be great.
Re: disableing wap / internet accsess on the samsung J700
Go to settings and select > Browser settings >Current Profile> >select Profile>
There are 5 option chose only (PROFILE) which means empty settings.or chose another network name profile
*#1111# ------------------ S/w Version *#1234# ------------------ Dev.Version FW *#2222# ------------------ H/w Version Rev *#0206*8376263# ------ S/w Version ,Dev.Version FW,H/w Version Rev,time and Month and year flash *#0206*8378# ---------- Test Mode *#4777*8665# ---------- GPRS Tool *#0206*523# ------------ brightness of the display of 1-5 *#7465625# -------------- Interrogate - indication locks *#0206*377# ------------ Error -- Table errors *#0206*327# ------------ EEP(01/10) *#0206*667# ------------ Debug mode *#92782# ----------------- User agent (samsung-Sgh-G600/G600XEGH3) *#232337# --------------- bluetooth addrnap uap lap *#28837# ----------------- S/w Version BT and H/w Version BT *#288378# --------------- Bluetooth Test *#56658378# ------------ Look Test (Bomba code in a well-meaning words) *#638738# --------------- Profiles Gprs- Inet settings (choice of various countries) *#36245# ----------------- Test Mode (e-mail, mms, etc.) *#0206*3768665# ------ DRM Tool (java, etc.) *#777324# --------------- PPP TEST Menu *#0673# ------------------ Mp3 Test Menu *#0206*6366# ---------- Memo test *#4378378# ------------- Gfs test *#7378378# ------------- RESours Test *#688# -------------------- Vod Test *#64898378# ------------ NITZ test mode *#898378# --------------- Timezone test mode *#875108# --------------- FM Radio- speaker volume 1-10 *#52828378# ------------ Java Test Menu *#73887# ----------------- Setup Wizard: (off/on) *#2769737# -------------- Browser Test Menu *2767*8451# ------------- Reset *#738277# ---------------- Auto Profile Setting ( on/off) *#0206*8376263# ------ S / w Version, Dev.Version FW, H / w Version Rev, time and Month and year flash *#0206*8378# ----------- Audio Settings [menu (2) H / W test]*2767*688# = Unlocking Code *#8999*8378# = All in one Code *#4777*8665# = GPSR Tool *#8999*523# = LCD Brightness *#8999*3825523# = External Display *#8999*377# = Errors #*5737425# = JAVA Something{I choose 2 and it chrashed} *#2255# = Call List
#*536961# = Java Status Code #*536962# = Java Status Code #*536963# = Java Status Code #*53696# = Java Status Code
#*1200# = AFC DAC Val #*1300# = IMEI #*1400# = IMSI
#*2562# = ??? White for 15 secs than restarts. #*2565# = Check Blocking #*3353# = Check Code #*3837# = ??? White for 15 secs than restarts. #*3849# = ??? White for 15 secs than restarts. #*3851# = ??? White for 15 secs than restarts. #*3876# = ??? White for 15 secs than restarts.
#*7222# = Operation Typ (Class C GSM) #*7224# = I Got !! ERROR !! #*7252# = Oparation Typ (Class B GPRS) #*7271# = Multi Slot (Class 1 GPRS) #*7274# = Multi Slot (Class 4 GPRS) #*7276# = Dunno #*7337# = EEPROM Reset (Unlock and Resets Wap Settings) #*2787# = CRTP ON/OFF #*3737# = L1 Dbg data #*5133# = L1 Dbg data #*7288# = GPRS Attached #*7287# = GPRS Detached #*7666# = SrCell Data #*7693# = Sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while) #*7284# = Class : B,C or GPRS #*2256# = Calibration Info #*2286# = Battery Data #*2527# = GPRS Switching (set to: class 4, class 8, class 9 or class 10) #*2679# = Copycat feature (Activate or Deactivate) #*3940# = External loop test 9600 bps #*4263# = Handsfree mode (Activate or Deactivate) #*4700# = Half Rate (Activate or Deactivate) #*7352# = BVMC Reg value #*8462# = Sleeptime #*2558# = Time ON #*3370# = EFR (Activate or Deactivate) #*3941# = External looptest 115200 bps #*5176# = L1 Sleep #*7462# = SIM phase #*7983# = Voltage/Frequenci (Activate or Deactivate) #*7986# = Voltage (Activate or Deactivate) #*8466# = Old time #*2255# = Call ??? #*5187# = L1C2G trace (Activate or Deactivate) #*5376# = ??? White for 15 secs than restarts. #*6837# = Official Software Version #*7524# = KCGPRS #*7562# = LOCI GPRS #*7638# = RLC allways open ended TBF (Activate or Deactivate) #*7632# = Sleep mode Debug #*7673# = Sleep mode RESET #*2337# = Permanent Registration Beep #*2474# = ??? #*2834# = Audio Path #*3270# = DCS support (Activate or Deactivate) #*3282# = Data (Activate or Deactivate) #*3476# = EGSM (Activate or Deactivate) #*3676# = Flash volume formated #*4760# = GSM (Activate or Deactivate) #*4864# = Dunno doesn't work on newer versions #*5171# = L1P1 #*5172# = L1P2 #*5173# = L1P3 #*7326# = Accessory (I got ********) #*7683# = Sleep variable ( #*7762# = SMS Brearer CS (Activate or Deactivate) #*8465# = Time in L1 #*9795# = wtls key #*2252# = Current CAL #*2836# = AVDDSS Management (Activate or Deactivate) #*3877# = Dump of SPY trace #*7728# = RSAV done# (Everything went to standart but nothing was deleted) #*2677# = ARM State (None or Full Rate) *#8999*636# = Have no clue what it is, i see 20 lines *#9999# = Software version *#8999*8376263# = HW ver, SW ver and Build Date *#8888# = HW version *#8377466# = Same HW/SW version thing
*#7465625# = Check the locks *7465625*638*Code# = Enables Network lock #7465625*638*Code# = Disables Network lock *7465625*782*Code# = Enables Subset lock #7465625*782*Code# = Disables Subset lock *7465625*77*Code# = Enables SP lock #7465625*77*Code# = Disables SP lock *7465625*27*Code# = Enables CP lock #7465625*27*Code# = Disables CP lock *7465625*746*Code# = Enables SIM lock #7465625*746*Code# = Disables SIM lock *7465625*228# = Activa lock ON #7465625*228# = Activa lock OFF *7465625*28638# = Auto Network lock ON #7465625*28638# = Auto Network lock OFF *7465625*28782# = Auto subset lock ON #7465625*28782# = Auto subset lock OFF *7465625*2877# = Auto SP lock ON #7465625*2877# = Auto SP lock OFF *7465625*2827# = Auto CP lock ON #7465625*2827# = Auto CP lock OFF *7465625*28746# = Auto SIM lock ON #7465625*28746# = Auto SIM lock OFF
*2767*3855# = E2P Full Reset *2767*2878# = E2P Custom Reset *2767*927# = E2P Wap Reset *2767*226372# = E2P Camera Reset #*6420# = MIC Off #*6421# = MIC On #*6422# = MIC Data #*6428# = MIC Measurement #*3230# = Trace enable and DCD disable #*3231# = Trace disable and DCD enable #*3232# = Current Mode #7263867# = RAM Dump (On or Off) *2767*49927# = Germany WAP Settings *2767*44927# = UK WAP Settings *2767*31927# = Netherlands WAP Settings *2767*420927# = Czech WAP Settings *2767*43927# = Austria WAP Settings *2767*39927# = Italy WAP Settings *2767*33927# = France WAP Settings *2767*351927# = Portugal WAP Settings *2767*34927# = Spain WAP Settings *2767*46927# = Sweden WAP Settings *2767*380927# = Ukraine WAP Settings *2767*7927# = Russia WAP Settings *2767*30927# = GREECE WAP Settings *2767*73738927# = WAP Settings Reset *2767*49667# = Germany MMS Settings *2767*44667# = UK MMS Settings *2767*31667# = Netherlands MMS Settings *2767*420667# = Czech MMS Settings *2767*43667# = Austria MMS Settings *2767*39667# = Italy MMS Settings *2767*33667# = France MMS Settings *2767*351667# = Portugal MMS Settings *2767*34667# = Spain MMS Settings *2767*46667# = Sweden MMS Settings *2767*380667# = Ukraine MMS Settings *2767*7667#. = Russia MMS Settings *2767*30667# = GREECE MMS Settings *335# = Delete all MMS Messages *663867# = Dump Mm file #*536961# = WAPSAR enable / HTTP disable #*536962# = WAPSAR disable / HTTP enable #*536963# = Serial eable / Others disable #*53696# = Java Download Mode #*5663351# = Wap Model ID [Your Model] #*5663352# = Wap Model ID [SEC-SGH***X/1.0] #*566335# = Wap Model ID [SEC-SGH***X/1.0] *2767*66335# = Check on which model it is *2767*7100# = SEC-SGHS100/1.0 *2767*8200# = SEC-SGHV200/1.0 *2767*7300# = SEC-SGHS300/1.0 *2767*7650# = Nokia7650/1.0 *2767*2877368# = Reset WAP Model ID to standart
Here are all known special codes for Samsung phones!
*2767*688# = Unlocking Code *#8999*8378# = All in one Code *#4777*8665# = GPSR Tool *#8999*523# = LCD Brightness *#8999*3825523# = External Display *#8999*377# = Errors #*5737425# = JAVA Something{I choose 2 and it chrashed}][/b] *#2255# = Call List
#*2562# = ??? White for 15 secs than restarts. #*2565# = ChAeck Blocking #*3353# = Check Code #*3837# = ??? White for 15 secs than restarts. #*3849# = ??? White for 15 secs than restarts. #*3851# = ??? White for 15 secs than restarts. #*3876# = ??? White for 15 secs than restarts.
#*7222# = Operation Typ (Class C GSM) #*7224# = I Got !! ERROR !! #*7252# = Oparation Typ (Class B GPRS) #*7271# = Multi Slot (Class 1 GPRS) #*7274# = Multi Slot (Class 4 GPRS) #*7276# = Dunno #*7337# = EEPROM Reset (Unlock and Resets Wap Settings) #*2787# = CRTP ON/OFF #*3737# = L1 Dbg data #*5133# = L1 Dbg data #*7288# = GPRS Attached #*7287# = GPRS Detached #*7666# = SrCell Data #*7693# = Sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while) #*7284# = Class : B,C or GPRS #*2256# = Calibration Info #*2286# = Battery Data #*2527# = GPRS Switching (set to: class 4, class 8, class 9 or class 10) #*2679# = Copycat feature (Activate or Deactivate) #*3940# = External loop test 9600 bps #*4263# = Handsfree mode (Activate or Deactivate) #*4700# = Half Rate (Activate or Deactivate) #*7352# = BVMC Reg value #*8462# = Sleeptime #*2558# = Time ON #*3370# = EFR (Activate or Deactivate) #*3941# = External looptest 115200 bps #*5176# = L1 Sleep #*7462# = SIM phase #*7983# = Voltage/Frequenci (Activate or Deactivate) #*7986# = Voltage (Activate or Deactivate) #*8466# = Old time #*2255# = Call ??? #*5187# = L1C2G trace (Activate or Deactivate) #*5376# = ??? White for 15 secs than restarts. #*6837# = Official Software Version #*7524# = KCGPRS #*7562# = LOCI GPRS #*7638# = RLC allways open ended TBF (Activate or Deactivate) #*7632# = Sleep mode Debug #*7673# = Sleep mode RESET #*2337# = Permanent Registration Beep #*2474# = ??? #*2834# = Audio Path #*3270# = DCS support (Activate or Deactivate) #*3282# = Data (Activate or Deactivate) #*3476# = EGSM (Activate or Deactivate) #*3676# = Flash volume formated #*4760# = GSM (Activate or Deactivate) #*4864# = Dunno doesn't work on newer versions #*5171# = L1P1 #*5172# = L1P2 #*5173# = L1P3 #*7326# = Accessory (I got ********) #*7683# = Sleep variable (8) #*7762# = SMS Brearer CS (Activate or Deactivate) #*8465# = Time in L1 #*9795# = wtls key #*2252# = Current CAL #*2836# = AVDDSS Management (Activate or Deactivate) #*3877# = Dump of SPY trace #*7728# = RSAV done# (Everything went to standart but nothing was deleted) #*2677# = ARM State (None or Full Rate) *#8999*636# = Have no clue what it is, i see 20 lines *#9999# = Software version *#8999*8376263# = HW ver, SW ver and Build Date *#8888# = HW version *#8377466# = Same HW/SW version thing
*2767*3855# = E2P Full Reset *2767*2878# = E2P Custom Reset *2767*927# = E2P Wap Reset *2767*226372# = E2P Camera Reset #*6420# = MIC Off #*6421# = MIC On #*6422# = MIC Data #*6428# = MIC Measurement #*3230# = Trace enable and DCD disable #*3231# = Trace disable and DCD enable #*3232# = Current Mode #7263867# = RAM Dump (On or Off) *2767*49927# = Germany WAP Settings *2767*44927# = UK WAP Settings *2767*31927# = Netherlands WAP Settings *2767*420927# = Czech WAP Settings *2767*43927# = Austria WAP Settings *2767*39927# = Italy WAP Settings *2767*33927# = France WAP Settings *2767*351927# = Portugal WAP Settings *2767*34927# = Spain WAP Settings *2767*46927# = Sweden WAP Settings *2767*380927# = Ukraine WAP Settings *2767*7927# = Russia WAP Settings *2767*30927# = GREECE WAP Settings *2767*73738927# = WAP Settings Reset *2767*49667# = Germany MMS Settings *2767*44667# = UK MMS Settings *2767*31667# = Netherlands MMS Settings *2767*420667# = Czech MMS Settings *2767*43667# = Austria MMS Settings *2767*39667# = Italy MMS Settings *2767*33667# = France MMS Settings *2767*351667# = Portugal MMS Settings *2767*34667# = Spain MMS Settings *2767*46667# = Sweden MMS Settings *2767*380667# = Ukraine MMS Settings *2767*7667#. = Russia MMS Settings *2767*30667# = GREECE MMS Settings *335# = Delete all MMS Messages *663867# = Dump Mm file #*536961# = WAPSAR enable / HTTP disable #*536962# = WAPSAR disable / HTTP enable #*536963# = Serial eable / Others disable #*53696# = Java Download Mode #*5663351# = Wap Model ID [Your Model] #*5663352# = Wap Model ID [SEC-SGHXXXX/1.0] #*566335# = Wap Model ID [SEC-SGHXXXX/1.0] *2767*66335# = Check on which model it is *2767*7100# = SEC-SGHS100/1.0 *2767*8200# = SEC-SGHV200/1.0 *2767*7300# = SEC-SGHS300/1.0 *2767*7650# = Nokia7650/1.0 *2767*2877368# = Reset WAP Model ID to standart
Samsung Secret Codes
Software version: *#9999#
IMEI number: *#06#
Serial number: *#0001#
Battery status- Memory capacity : *#9998*246#
Debug screen: *#9998*324# - *#8999*324#
LCD kontrast: *#9998*523#
Vibration test: *#9998*842# - *#8999*842#
Alarm beeper - Ringtone test : *#9998*289# - *#8999*289#
Smiley: *#9125#
Software version: *#0837#
Display contrast: *#0523# - *#8999*523#
Battery info: *#0228# or *#8999*228#
Display storage capacity: *#8999*636#
Display SIM card information: *#8999*778#
Show date and alarm clock: *#8999*782#
The display during warning: *#8999*786#
Samsung hardware version: *#8999*837#
Show network information: *#8999*638#
Display received channel number and received intensity: *#8999*9266#
*#1111# S/W Version
*#1234# Firmware Version
*#2222# H/W Version
*#8999*8376263# All Versions Together
*#8999*8378# Test Menu
*#4777*8665# GPSR Tool
*#8999*523# LCD Brightness
*#8999*377# Error LOG Menu
*#8999*327# EEP Menu
*#8999*667# Debug Mode
*#92782# PhoneModel (Wap)
#*5737425# JAVA Mode
*#2255# Call List
*#232337# Bluetooth MAC Adress
*#5282837# Java Version
Type in *#0000# on a Samsung A300 to reset the language
Master reset(unlock) #*7337# (for the new samsungs E700 x600 but not
E710)
Samsung E700 type *#2255# to show secret call log (not tested)
Samsung A300, A800 phone unlock enter this *2767*637#
Samsung V200, S100, S300 phone unlock : *2767*782257378# Samsung Secret Codes Part 2
#*4773# Incremental Redundancy
#*7785# Reset wakeup & RTK timer cariables/variables
#*7200# Tone Generator Mute
#*3888# BLUETOOTH Test mode
#*7828# Task screen
#*#8377466# S/W Version & H/W Version
#*2562# Restarts Phone
#*2565# No Blocking? General Defense.
#*3353# General Defense, Code Erased.
#*3837# Phone Hangs on White screen.
#*3849# Restarts Phone
#*7337# Restarts Phone (Resets Wap Settings)
#*2886# AutoAnswer ON/OFF
#*7288# GPRS Detached/Attached
#*7287# GPRS Attached
#*7666# White Screen
#*7693# Sleep Deactivate/Activate
#*2286# Databattery
#*2527# GPRS switching set to (Class 4, 8, 9, 10)
#*2679# Copycat feature Activa/Deactivate
#*3940# External looptest 9600 bps
#*4263# Handsfree mode Activate/Deactivate
#*2558# Time ON
#*3941# External looptest 115200 bps
#*5176# L1 Sleep
#*7462# SIM Phase
#*7983# Voltage/Freq
#*7986# Voltage
#*8466# Old Time
#*2255# Call Failed
#*5376# DELETE ALL SMS!!!!
#*6837# Official Software Version: (0003000016000702)
#*2337# Permanent Registration Beep
#*2474# Charging Duration
#*2834# Audio Path (Handsfree)
#*3270# DCS Support Activate/Deactivate
#*3282# Data Activate/Deactivate
#*3476# EGSM Activate/Deactivate
#*3676# FORMAT FLASH VOLUME!!!
#*4760# GSM Activate/Deactivate
#*4864# White Screen
#*7326# Accessory
#*7683# Sleep variable
#*3797# Blinks 3D030300 in RED
#*7372# Resetting the time to DPB variables
#*3273# EGPRS multislot (Class 4, 8, 9, 10)
#*7722# RLC bitmap compression Activate/Deactivate
#*2351# Blinks 1347E201 in RED
#*2775# Switch to 2 inner speaker
#*7878# FirstStartup (0=NO, 1=YES)
#*3838# Blinks 3D030300 in RED
#*2077# GPRS Switch
#*2027# GPRS Switch
#*0227# GPRS Switch
#*0277# GPRS Switch
#*22671# AMR REC START
#*22672# Stop AMR REC (File name: /a/multimedia/sounds/voice
list/ENGMODE.amr)
#*22673# Pause REC
#*22674# Resume REC
#*22675# AMR Playback
#*22676# AMR Stop Play
#*22677# Pause Play
#*22678# Resume Play
#*77261# PCM Rec Req
#*77262# Stop PCM Rec
#*77263# PCM Playback
#*77264# PCM Stop Play
#*22679# AMR Get Time
*#8999*364# Watchdog ON/OFF
*#8999*427# WATCHDOG signal route setup
*2767*3855# = Full Reset (Caution every stored data will be deleted.)
*2767*2878# = Custom Reset
*2767*927# = Wap Reset
*2767*226372# = Camera Reset (deletes photos)
*2767*688# Reset Mobile TV
#7263867# = RAM Dump (On or Off) Samsung Secret Codes Part 3
*#7465625# = Check the phone lock status
Type *#9998*627837793# Go to the 'my parameters' and there you will
find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the
following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then
type *#9998*3323# it will reset your phone. Push exit and then push 7,
it will reset again. Put your other sim in and it will say sim lock,
type in 00000000 then it should be unlocked. Type in *0141# then the
green call batton and it's unlocked to all networks. This code may not
work on the older phones and some of the newer phones. If it doesn't
work you will have to reset your phone without a sim in it by typing
*#2767*2878# or *#9998*3855# (not tested)
Try this codes:Samsung T309 and T809 100%
1st Make Full Eprom Reset *2767*3855#
After Rebooting Mobile
then enter...
*7465625*638*00000000*00000000# (to change NCK code to 00000000)
then enter...
#7465625*638*00000000# (to permanently unlock the phone)
check the lock status...
*#7465625#
T209, X100, X495, X660, D600, E780, T319
Input *#7465625# to check the locks....all locks should now be inactive as shown below:
network lock - inactive
subset lock - inactive
sp lock - inactive
cp lock - inactive
sim lock - inactive
activa lock - inactive
phone lock - inactive
auto network - inactive
auto subset lock - inactive
auto sp lock - inactive
auto cp lock - inactive
auto sim lock - inactive
T809 now with this procedure.
with t-mobile sim doesnt work.....
with wrong card it works.
procedure
1. enter *7465625*638*00000000*00000000# then turn your unit off. and power on again.
2. enter #7465625*638*00000000# then power off again. power on again .
full list of D500 secretcodes (same as on E800)
*#2255# = Call List
#*1300# = IMEI
#*1400# = IMSI
#*2562# = White for 15 secs than restarts.
#*3837# = White for 15 secs than restarts.
#*3849# = White for 15 secs than restarts.
#*3851# = White for 15 secs than restarts.
#*3876# = White for 15 secs than restarts.
#*7276# = Dunno
#*8462# = Sleeptime
#*2558# = Time ON
#*5176# = L1 Sleep
#*7462# = SIM phase
#*8466# = Old time
#*2255# = Call
#*5376# = White for 15 secs than restarts.
#*7524# = KCGPRS
#*7562# = LOCI GPRS
#*2474# =
#*5171# = L1P1
#*5172# = L1P2
#*5173# = L1P3
#*7683# = Sleep variable (Cool
#*9795# = wtls key
#*6420# = MIC Off
#*6421# = MIC On
#*6422# = MIC Data
*2767*2877368# = Reset WAP Model reset
Format samsung I300
1. turn off the mobile.
2. Press (0) + power button.
3. show screen Enter password
then enter master password like (1234)
now your mobile was formated
e860 & e530
E530 Unlock Method By Code
IF UR FONE WITH WRONG CARD!!!!!!!!! THAN STEP1
STEP1>>>>>>>press *#9998*3323# then press exit and slect 6
the phone is unlock then press *0141#
IF UR FONE WITH SIM LOCK THAN STEP 2
STEP 2 >>>>>>>PUT MOTROLA TEST CARD GO IN SECURITY
AND THAN SIMLOCK AND THAN DISABLE AND ENTER CODE 00000000
THAN WITH WRONG SIM CARD DO STEP 1
GSM_BLUE
17th Oct '07 Wed, 18:27
mga boss eto try nyo sa mga wala pa. im sure wala pa nito dito kasi nag seach ako wala ako makuha. para mga walang cable! hehehe
Samsung X660
Turn off the phone. Put a non-accepted SIM Card and turn it on. Type *#9998*3323#. Press Exit. Choose menu #7.
After phone reboots type *0141# and t the Call button. Turn off and insert another SIM Card. Turn on. The code is 00000000.
GSM_BLUE
17th Oct '07 Wed, 19:05
!!!!Unlocking V804ss thru codes!!!!
To all who want to maintain as japanese version for V804ss and Z540 without flashing just do the following:
Take out SIM CARD
Press: *7465625*228#
Power off. Put your SIM CARD.
D807
Guys!!! :-) Unlock D807 - Its so easy!!!
Choose menu #7. After phone reboots type *0141# and hit the Call button. Turn off and insert another SIM Card. Turn on.
e900
Free solution (SIM)unlock E900
Here follows the free solution to (SIM)unlock a Samsung E900, which worked for me.
- NSdongle crack + D800 USB datacable (PCB120BBE)
- Select C200 model
- Select right COM port (Windows XP -> Devicemanager -> Ports (COM&LPT))
(Not the COM port which you can find under 'Modems')
- Press 'UNLOCK'
And your Samsung E900 is unlock! (Well, mine was)
(Thanks!! to BouRRi GSM, who wrote it somewhere on this forum)
Got
new sam unlock
NEXT ENTER
AND THEN *#7465625# to check the locks....all locks are inactive...these are all the locks...
sp lock - inactive
cp lock - inactive
sim lock - inactive
auto sim lock – inactive
panamastercodes
*01763*737381#
sam1
Power on your phone (Models Z105, Z107V, Z140, Z140V, Z500, Z500V, etc.......)
1- Enter code *7465625*28782# without a sim in the phone
2- Phone will display "Auto Subset Lock: Activated!"
3- Enter code *7465625*28638# without a sim again
3- Phone will display "Auto Network Lock: Activated!"
4- Now insert the sim and enjoy! Phone is Unlocked!
(NOTE: When you change sim to other operator
repeat this process to unlock it for that operator also)
sammaster
*2767*2878# without simcard
Samsung
*#2255# = Call List
#*1300# = IMEI
#*1400# = IMSI
#*7276# = Dunno
#*8462# = Sleeptime
#*2558# = Time ON
#*5176# = L1 Sleep
#*7462# = SIM phase
#*8466# = Old time
#*2255# = Call ???
#*7524# = KCGPRS
#*7562# = LOCI GPRS
#*2474# = ???
#*5171# = L1P1
#*5172# = L1P2
#*5173# = L1P3
#*9795# = wtls key
#*6420# = MIC Off
#*6421# = MIC On
#*6422# = MIC Data
__________________
yes you have to goto google typ in gprs settings for o2 virgin wichever tarrif your on
look for yours
then if o2 you need to copy o2 pay and go settings into ur mobile internet settings
as you see them
you can then have accsess to wap internet
here are all codes for E250,
enjoy and dont forget to rate it as it will fix the issue.
