Question about Samsung DLP HL-P5663W 56" TV
My samsung tv startup with full volume
When i turn on my tv it start up with full volume. no other problems
Its memory IC is gone needs to replace check model spec or IC log book for yours model or email brand services to get IC number i.e. 8 pin ic any one with soldering knowledge can do that
Posted on Apr 12, 2013
    Problem Solver:
  • 18 Answers
U have 2 replace the memory ic
Posted on Dec 26, 2008
Why won't my Samsung LCD tv boot properly at startup
Hi Tom,
This is becoming a theme with Samsung TV's, Samsung have extended warranty cover for some customers with this problem, have a look at this post for more info and the link to Samsung:
have 60 Samsung led tv Sound keeps cutting out all night for 3 5 seconds...
Feb 13, 2016 | Samsung 9000 Series UN65F9000AF 65" 4K LED...
I have a Samsung Pn58a650t1fxza tv. When I turn it on the tv goes to full volume. What board should I replace
Have you tried using the auto volume adjustment, balance control to make a new setting?
Nov 18, 2015 | Samsung Televison & Video
How can I fix a Samsung TV on which the volume is on full blast when turning the set on, not matter what it was set on when turned off.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 10, 2015 | Samsung Televison & Video
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
I have a '96 samsung 25" tube tv. model # TXE2546 - series # 3CAG700429. when i turn it on it has always made a click sound a couple of seconds afterwards. the "power & timer" led light flashes about...
This problems the FBT-the Flyback Transformer have cold solders.Must resolders the FBT.The right side wall of the FBT-the "H" horizontal transistor,must be also resolder too.
Oct 18, 2010 | Samsung TXJ2754 27" TV
I have a Samsung 46''B6000 tv hooked up to a samsung Blu ray player B-1590 via HDMI cable. During the course of watching a BR disc, the volume had to be increased all the way up to 100 (max), to be able to...
This happens on our samsung too with some dvd's.
It is not the tv's fault (in my case) but have to turn the volume button on the dvd remote up full first then adjust from the tv remote as required.
Oct 19, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung F480 won't startup
press Camera button + volume down + power button ( together )
if the mobile turn on and show ( download or any word .. so you can fix it by changing the software )
Dec 19, 2008 | Verizon Communications Samsung Juke Cell...
Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Aug 24, 2008 | Samsung LN-S2651D 26 in. LCD Television
Problem with the volume
what about sound bar in the tv that shows how much is vol.
is it remain normal or go at full ..
check if it remains normal then its another problem
if it goes also full then it might be software problem
Aug 14, 2008 | RCA F25422 25" TV
Rainbow of vertical lines during startup
I could be a tuner problem. But since the set is new, you should return it for replacement.
Geno
Feb 27, 2008 | Samsung LN-T4671F 46 in. LCD Television
Samsung DLP HL-P5663W 56" TV Logo
490 people viewed this question
Jerry Greenberg
Jerry Greenberg
