Question about Toshiba 32A3000 32A3000 32 16:9 Multi System Regza 1366 x 768 HD LCD TV
Toshiba 32A3000A Service Manual Settings
While trying to fix my screen splitting problem (i.e. the left side of my screen is divided 3 vertical line with different color levels), I tinkered with the service menu thinking the solution was there but unfortunately, it gave me a whole new problem. Worst of all, I failed to take down the original values.
There are essentially two things I wish for your help on:
1) Would your end be able to advise on default service menu settings for this TV model?
2) On the screen split problem, has that been seen before in this forum and is there a way to fix it? My 9 month old niece was playing with the remote control and it came out and we do not know how to bring it back.
Thanks a lot and looking forward for your reply!
Regards,
JD
techman
  • 3130 Answers
SOURCE: Default service menu codes
They are all different, in every set. Why do peeps not remember to leave these settings alone! sorry but now you will need to have the set serviced.
Posted on Jul 11, 2007
  • 84 Answers
SOURCE: Vertical lines in my laptop screen
There could be three different possibilities why you would get a line on your lcd display.
First, it could be a missing signal from the controller IC to LCD driver IC
Second it could be a defective LCD driver IC itself
Third it could be a dry contact in the tape carrier package ( TCP).
Attach an external monitor to your laptop and make it your primary display unit to see if you are still getting the lines if not its you TCP if you still get lines it will need to have either the LCD IC or the controller IC checked and possibly replaced.
Posted on Feb 11, 2008
  • 128 Answers
SOURCE: Vertical Flashing Lines on Toshiba 42HP84 Plasma 42"
troubleshooting PCB's of certain electronic units require advanced technical skills. no service manual of any source would provide specific solutions. the best you can get are schematic diagrams. if your field of expertise is not related to electronics, i suggest you let the technicians handle the problem for you. every shop have their repair cost qoutations. just be sure to ask for warranty of their repair. goodluck!
Posted on Oct 24, 2008
  • 280 Answers
SOURCE: fine color vertical lines in right and left side of screen
One of two things could be wrong.. One is the digital board and or connector. the second is that the LCD display is going bad..
Posted on Jan 30, 2009
  • 732 Answers
SOURCE: Toshiba regza went black, then the northen lights appered!
prosit, If unit can be opened, I recommend you visually inspect the main power supply printed circuit board for "bad" electrolytic filter capacitors that may be faulty and failed prematurely! Lots of DIY videos at YOUTUBE that you should view before doing a "teardown" !!! Remember THIS!!! You MUST document your teardown with video or digital stills so before disconnecting any connectors to the board so you can put unit back together exactly as it was before you started any board repair work!! e.g. replacement of filter capacitors, fuses, resistors, and solder joint inspection of through-hole and or surface mounted active and passive components. DO YOUR WEB RESEARCH OF YOUTUBE VIDEOS FIRST!!!! Good luck guy. Keep us tech's informed of your progress by doing additional posts (comments) here on fixya. 12fixlouie
Posted on May 25, 2010
I have a Toshiba Satellite C655. The screen is malfunctioning as you can see. The screen has 3 vertical striped lines which has divided the screen into separate parts. The cursor will not pass through
Had this problem once and a found out how to fix it. It's a hardware prob, to fix this prob your Pc has to be on while doing it, this way you can see if the problem has been fixed or not. You need to unscrew all screws on the shell of the screen. Then you remove the two screws found at the bottom of the screen they are found close to the hinge.
Now the back part of the shell should be off. once that is off just disconnect the silver cable that is connected to the screen and reconnect it again and bend and squeeze it to see if it is a shortage in the wire. If not remove it once more and reconnect it again. (should be fixed now)
Use a strip of tape to hold it in place and your done. use it for a couple hours to ensure it fully functional then put it back together and you're done.
Nov 05, 2012 | Computers & Internet
Subtle Two Toned Split Screen Color Difference.I think I hit some button by accident. Monitor is great but now I have a split screen where the left hand side of the screen has a lighter tint than the right...
Hi. I have got the same problem, and it was very easy to solve. Monitor was LG. The problem was not in the system, it was in the monitor. I just clicked the buttons on the monitor, it was on the wrong setting that divides monitor in two colors, so if it happens to you, try checking your monitor settings, mine was set to "demonstration", half was lighter than the other one, just set it to usual or user. Keep in mind the settings are on the monitor itself, not in the windows (buttons on the monitor itself) Good luck.
May 10, 2012 | LG 22" FLATRON LCD Monitor
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
Jun 10, 2008 | Toshiba G15-AV501 Qosmio Notebook
what i recommend you to test is to press behind your monitor and see that the line goes off or not.If it does..that mean you have a loose connection,it can be fix.Incase no then you have problem with your LCD.Normally if its LCD problem then you fix this problem,all you have to do is change the LCD.
goodluck,takecare.
May 04, 2008 | Toshiba Satellite P30 P35 Series Notebook
Toshiba 50A60 vertical picture adjustment
Try downloading the service manual and go through the calibration excercise. There's also some additional controls behind the right front speaker.
Nov 18, 2007 | Toshiba 50A60 50" Rear Projection...
Divided picture on Protron PD-800 DVD/CD/CD-R PLAYER
Hi Alberto,
The split screen (identical display left & right) indicates that your DVD is on Progressive Scan.
P scan refers to progressive scanning mode and is not an indication of something broken but rather is a feature. What you can do is look over your remote and check if it's got a PS or PScan button. Pressing the button should revert to the single display. If there is no such button, pls check your menu or settings and should be there somewhere. At other times, there is a small hard switch at the rear (or front) of the player itself just for this purpose.
On your concern for no color, determine the color system of the disc you're playing, the setting of your DVD player as well as the color system of your TV. They should be the same. The 3 systems are NTSC, PAl and SECAM.
Hope this be of some help/idea. Pls post back should you have other concerns.
Good luck and kind regards.
Nov 11, 2007 | Spectroniq PD-1100 DVD Player
Two vertical lines one at 1/3 screen the other at 2/3's of screen
I have not fixed it yet. But I have identified the chip that is causing the problem. If you have a service manual scan it and post it please, so I can show you the chip.
Aug 04, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 32A3000 32A3000 32 16:9 Multi System Regza 1366 x 768 HD LCD TV Logo
258 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
