Question about Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook
DVD-RW Drive not working with all media types
I am only able to run DVD-R's (with movies burnt on it) and I am unable to run any software, mp3 or audio cds. What gives?
  • 6 more comments
  • bjgrissom Dec 25, 2008
    I didnt see the link.
    When I insert the DVD-R it auto runs and plays. If I insert any other type of disk, it does not autorun. However, I do get the little disc icon where the mouse pointer is. I then open up My Computer, then select the disk drive and it doesnt show the contents of my disk or a disk name.
    I get the following error when trying to upgrade the firmware..."Target NEC ND-6650A is not found correctly"
    I did not have to make any changes.
  • bjgrissom Dec 26, 2008
    Still no luck.
    If I insert DVD Media (movies) I can explore the contents. However, any other type of media (Audio, PC Software) I am unable to explore it. I did the whole regedit thing and it all checked out as it should. For the services.msc console, I stopped and started the Shell Hardware Detection with the same results. The media I am trying to use is good, I have tried it on a known working machine. Thanks for your help so far. Hopefully there is some more good ideas out there. I am running XP SP3. I had windows media center on here at one time, but removed it. Could this have created my problem?
  • bjgrissom Dec 27, 2008
    It appears that none of the above has corrected my issues. Any more suggestions?
    This is the log file that I get after running the system check you listed above. I am going to run the same software with a DVD and see if the log is different.
    AutoFix [V5.2.3790.67]
    Time [2008-12-26 23:05:06]
    Microsoft Windows Version [5.1 (Service Pack 3) <2600>]
    Test [The Shell Hardware Detection service is running.] - Instance [N/A]:
    Result [AutoStart Setting]: OK
    Result [The Shell Hardware Detection service is running.]: OK
    Test [Policies] - Instance [D:\, Drive Type: 5]:
    Result [HKCU\...\Policies!NoDrives]: OK {Absent}
    Result [HKCU\...\Policies!NoDriveAutorun]: OK {Absent}
    Result [HKCU\...\Policies!NoDriveTypeAutorun]: OK {Present}
    Result [HKLM\...\Policies!NoDrives]: OK {Absent}
    Result [HKLM\...\Policies!NoDriveAutorun]: OK {Absent}
    Result [HKLM\...\Policies!NoDriveTypeAutorun]: OK {Absent}
    Result [Driver level policies]: OK {
    HKLM\...\Services\cdrom!Autorun (Present)
    HKLM\...\Services\cdrom\Parameters!Autorun (Absent)
    HKLM\System\CCS\Enum\...!AlwaysEnable (Absent)
    HKLM\System\CCS\Enum\...!AlwaysDisable (Absent) }
    Test [Drive Notification] - Instance [D:\, Drive Type: 5]:
    Result [Legacy Notification]: Problems
    Result [AutoPlay V2 Notification]: Problems {
    Service (Silent)
    Shell (Deaf) }
    >> Repair << [Legacy AutoPlay Event]
    Step: No steps to take.
    Result: This AutoPlay setting cannot be fixed. Either the device is malfunctioning, or the wizard cannot determine the problem.
    >> Repair << [Autoplay V2 Event]
    >> Required action: The wizard found problems but cannot fix them -> None
    I get this error when inserting a DVD. The before error was when I was trying to use a Software disc.
    Time [2008-12-27 09:42:15]
    Result [Legacy Notification]: OK
    Service (Silent)
    Shell (Deaf) }
    Scholar:
  • 100 Answers
Might be a driver problem. when you say it wont run, do you mean it doesnt automatically start? or it wont start if you go to mycomputer and click on the drive and start it from there?
first follow this link and follow it to the driver for your dvdrw, download and install and see if that works
if this diesnt work please let me know and i'll assist you further
Posted on Dec 25, 2008
  • 5 more comments
  • Brian Ebeling Dec 25, 2008
    oh sorry. try this link --
    http://support.dell.com/support/download...
    try this first and let me know.
    ok . lets try this... got to --
    start -> control panel -> system -> hardware -> device manager
    go to and click on the IDE ATA/ATAPI controllers
    click on Primary IDE controller
    click on advanced settings
    make sure Transfer Modes are set to DMA
    make sure Device Types are set to Auto Detection
    click on Secondary IDE controller
    check the same settings
    dont set the transfer modes to PIO
    if you had to change the settings, reboot and try your drive.
    if you didn't have to make changes let me know and we'll move on to the next step
    ok, lets reinstall the drivers ---
    start -> control panel -> system -> hardware -> device manger
    click on the Driver tab
    click uninstall and click ok
    if it asks you to restart your computer, say no for now. might ask twice.
    and then click ok to close the box for the Primary IDE
    now back to the Device Manager --
    click on Secondary IDE Controller
    click on Driver
    click on Uninstall and click ok
    if it asks you can go ahead and restart your computer now.
    if it doesn't ask go ahead and do it from the Start menu
    Once you reboot it will start to pop up little messages stating that it found new hardware.
    just let it go for a few minutes until it's done doing it's thing.
    it may ask you to restart the computer again or say the new hardware wont work without a restart but dont do it yet, FIRST go to ---
    Start -> Control Panel -> System -> Hardware -> Device Manager
    click on Advanced Settings
    make sure
    Transfer Mode is set to DMA
    Device Type = Auto Detection
    Go to and click Secondary IDE controller
    and check for the same settings
    after that you can reboot your comp and see if it is working now.
    if not let me know
  • Brian Ebeling Dec 26, 2008
    ok do me a favor just wanna rule out something.
    put a disk in that it wont start. go to my computer and right-click on the drive and click explore.
    does it open the folder and show the contents?
    you're using vista right?
    Lets try this--
    First Backupthe registry --
    1/ Click Start
    2/ From the menu click Run
    3/ In the Run dialog box type: regedit
    4/ The Windows registry Editor will now open
    5/ Click the File option on the main toolbar and, from the drop down menu, select Export
    6/ In the Export Registry File dialog box select All
    7/ Now name the file
    8/ Finally click the Save button
    9/ To return the registry back to its original state should something go wrong simply click on the File option on the main registry editor toolbar and then select Import
    10/ leave Regedit open
    Now lets check the autorun settings ----
    5/ Now navigate to the following subkey: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CDRom
    6/ Look down the list of option in the Right Hand pane of the Registry editor Window and locate the AutoRun option
    7/ If the AutoRun value is 1 (one) then AutoRun is enabled. If it is 0 (zero) then it is disabled. To re-enable it, Right Click on the AutoRun option, Select Modify and in the Value Data box type: 1 (one), then Press OK
    8/ If AutoRun is already enabled in this Registry key, then Locate the following Registry subkey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
    9/ If you are unable to locate this registry key look for he following registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
    10/ Look at the entry NoDriveTypeAutoRun (It is sometimes difficult to locate this particular option in the maze of other registry entries, therefore, I find that it is easier if one the Find option. Click Edit on the registry main toolbar and then, from the drop down menu, select Find. In the 'Find What' dialogue box type NoDriveTypeAutoRun and then click the Find Next button.
    11/ If the value of this key is 0xb5, then AutoRun is turned off. (or 255) then AutoRun is turned off
    12/ To turn AutoRun back on, Right Click the NoDriveTypeAutoRun option and then Click Modify. Select the Hexadecimal option then type: 91 (Ninety One) in the value box, and then press OK
    13/ Finally Close the Registry Editor
    14/ reboot
    Next ----
    Type “service.msc” in Start Search to run Services console. Locate Shell Hardware Detection. Double Click on it and ensure that the “Service Status” is Running, and “Startup Type” is Automatic. If not, start the service and change the Startup Type setting accordingly.
    Now insert a disk and try it out
    fingers crossed. if this doesn't work we still have options.
    AAAHHHH XP SP3. go here and run this tool ----
    http://www.softwarepatch.com/windows/xpa...
    Should start to download automatically
    If that doesn't work ---
    Copy and paste the following into NOTEPAD
    Windows Registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Cdrom]
    "AutoRun"=dword:0000001
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
    "allocatecdroms"="0"
    [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
    "NoDriveTypeAutoRun"=dword:00000091
    "NoSaveSettings"=dword:00000000
    Save it as REGFIX.REG onto your desktop and then double click it.
    let me know...
    if that doesn't work --- Have you updated windows recently? there maybe new drivers etc that need to be installed.
    windows.update.microsoft.com
    need to use Internet Explorer or FirFox with the IE Tabs add-onn
    try these and if no success then it's time to think about hardware and not software.
    let me know
What is the Lifespan of CD Drives? I have an HP dv7 that seems like the cd rom is not communicating well with the machine. Could it be software related?
Burning CD-R or DVD-R shortens the life cycle of any CD-R or DVD-R drive, while reading is generally. If you have burnt 1 disc per day, it is not surprising your DVD-RW drive is worn out.
1 detail to take into consideration: if you use ReWritable media, change them from time to time. I thought my DVD-Recorder was dead as I got a lot of non responding issue with DVD+RW media (while my computer had no problem to read these media), and finally getting rid off the old media and taking newer DVD+RW media has given the DVD-Recorder 3 more years.
Jul 10, 2014 | HP Pavilion dv7-1132nr Notebook PC
I dont know how to download a movie so I can burn it
http://download.cnet.com/movie-torrent/3000-2196_4-10786348.html Movie Torrent is a basic peer-to-peer file-sharing client that lets users download a variety of different media types. Although the program works just fine, expect to seek additional instruction if you're not already familiar with torrents.
peer to peer file sharing is a free program which allows you to download someone elses movies that are online the link might drop out but will automatically search for anotherlink once its dropped out even if you shut your computer down after the link has been dropped when you start your computer again and open up the program will search for and connect to the link
once you have selected a movie the movie starts downloading windows will ask whether you want to run or save it a browse option will open you can save it into a folder in my documents then depending on your burning software you might have to burn it as an ISO image if you dont have the software to burn an iso image there are lots of free burning software programs on the internet http://download.cnet.com/burn4free-cd-and-dvd/3000-2646_4-10217894.html Burn4Free CD and DVD is a burning solution that's compatible with more than 3,000 DVD, Blu-ray and CD burners. Burn data and audio from different file types (WAV, WMA, MP3, OGG, FLAC, WavPack, and CDA). Burn and save ISO files, open and save your project to disk, verify content, print compilations, copy DVD, copy BLU RAY and import your audio compilation from M3U and ASX playlists. The drives supported include dual-layer DVD, CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM, BD-R, BD-RE (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
hope this helps you
Sep 05, 2011 | Compaq Computers & Internet
I have a Brand New LG Portable Super Multi Drive DVD RW. Although I can get a Visual when I play DVD movies, I am unable to get an Audio. Please advise.
One of 2 things
a) Check your PC sound settings, make sure your CD/DVD drive O/P is included.
b) Your media player doesn't have the right codecs. Go to filehippo.com download and install VLC media player. Should work a treat.
Jul 07, 2011 | LG GP08NU40 Super Multi Disk drive DVD...
I am trying to record with a sony dvd-r disc and the recorder don't recognize it. the only disc that works is the dvd ram 4.7 but that disc does not work on other standard dvd players. what is the answer?
According to the official description of that recorder, you should have no problem, this is from the description for the DMRES15:
Recordable DVD Media
Record your favorite shows onto DVD-RW, DVD-R, DVD+RW, and DVD-RAM DVD discs. The DMR-ES15 is also compatible with DVD+R Double layer media and provides up to 14 hours of media recording.
Multi-Format Player
Don't worry about limited playback capabilities, the DMR-ES15 can play DVD, DVD-RW (VR Mode), DVD-RW (Video Mode), DVD-R, DVD+R, DVD+RW, DVD-RAM, VCD and CD-DA discs. Also, you can play your favorite songs from CDs or MP3 files, and JPEG images.
Nov 29, 2009 | Panasonic DMRES15 DVD Recorder
August 2005, I purchased this powermac g5. There has been a steady deterioration in the DVD player. Presently, no rented DVDs play. SONY DVD RW DW-Q28A: Firmware Revision: KAS7 Interconnect: ATAPI Burn...
OK. The movie industry strikes again! Your RENTED DVDs are the key.Hollywood made some adjustments to prevent the copying of the movies. So they put software to detect the kind of drives in which the movies are inserted. DVD/RW are capable of copying a movie, so they are disqualified as playing devices. Have it be a normal DVD player you won't be facing any troubles.
Apr 20, 2009 | Apple Power Mac G5 Desktop
Not able to burn dvds from file
if your DVD Drive ( ROM ) read-Only-Memory. then it will only read DVDs And Not Write Them. You need a DVD RW Drive, to be able to write. If Your CD Drive Is A CD/RW That means its a CD Re-writable drive. try a Burn To CD.
Mike @ Compurepair.
Mar 26, 2009 | Computers & Internet
Problem with sony dvd rw aw-g170a
plz sum 1 gimme the link to download SONY DVD RW AW-G170A firmware.
Mar 28, 2008 | Computers & Internet
SONY DVD RW AWQ170A
yes you can use nero 7 or cyberlink power dvd this software allow you to watch dvd movies. window media player doesnt play dvd without this softwares..
Feb 12, 2008 | Sony 16X DVD+/-RW Dual Layer OEM Black...
DVD+RW
dot.gif Unable to read a CD-R or other recordable disc. Question: Unable to read a CD-R or other recordable disc.
Answer: Unfortunately this can be a difficult question to answer because of the amount of potential reasons for this issue to occur. Below is a listing of several steps and recommendations that can be taken to help identify the cause of the issue and/or resolve this issue.
Drivers Verify you have the latest drivers installed for the CD-R or recordable drive. There are numerous driver related issues that may cause a CD-R drive or other recordable to stop reading a CD-R disc. If you are running Microsoft Windows verify your drive is properly detected and listed in Device Manager with no conflicts or errors.
If Windows Device Manager detects an error on the drive or if it has other drives listed in Device Manager with errors on them remove the device from Device Manager and reboot the computer to let Windows re-initialize the drive.
If Windows shows no errors, the above steps did not resolve the issue, or you are running a different operating system check with the drive manufacturer for updated drivers. A listing of disc drivers can be found here.
CD-R disk Not all CD-R disks are compatible with all types and speeds of CD-R drives or other recordable drives (especially earlier CD-R drives). Verify the manufacturer gives 100% guarantee for supporting all drives and disc speeds, for example, TDK discs often give a 100% guarantee.
Pre-mastering/Mastering Software Pre-mastering software can sometimes produce incorrect tracks due to bugs. An incorrect ISO image could be generated, or incorrect sub header codes could be recorded in the case of Mode 2 discs. A good way to check whether the incompatibility problems lie with the originating software or with one of the other causes listed above is to test the same disc on several CD-ROM drives. If one drive is capable of reading the disc back correctly, chances are that the problem was not in the mastering, but is one or more of the other factors listed.
Disc is a recordable disc that the drive or player does not support Verify the drive supports the recordable media you are attempting to read. Below are some situations to watch out for.
  • Old CD-ROM or early DVD drive - Some early CD-ROM drives and Gen 1 DVD drives (some of the first DVD drives released) do not support CD-R discs and/or CD-RW discs. Not only does this apply to computers but also home entertainment DVD players.
  • CD-RW in CD-R or CD-ROM drive - CD-R drives are incapable of reading CD-RW drives. If you are using a CD-RW disc verify the drive is a CD-ROM or CD-R drive is capable of reading the disc.
  • DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it supports reading the DVD recordable media you are using. Additionally a standard CD-ROM, CD-R, CD-RW, etc drive is not able to read DVD discs.
Disc was created incorrectly Make sure you're creating the disc properly. For example, a common mistake users make when creating audio CD's that they can listen to in their computer, car, or home stereo is burning the MP3 files or other files directly to the CD as a Data disc and not an Audio disc. All this will do is burn the data files to the disc and not create an audio disc. This may allow you to listen to the audio files in the computer but will not allow you to listen to the music in the majority of other CD players unless they support MP3 format.
Disc or DVD contains media content not supported by the player Not all home entertainment DVD players are capable of supporting and playing all the different formats movie files and audio files are stored in. Make sure the format or codec of the movie or audio file you're saving to the CD or DVD is supported by the DVD player. If you're computer is capable of playing the files off the DVD but your home entertainment DVD player is not able to play the file it's likely you're encountering this issue.
Bad disc If after reading through the above recommendations you still continue to have the same issue it's possible that the disc is a bad disc. Try re-burning the disc and if possible try a different type of recordable disc.
Computer DVD Support
Click on the above link should get ya back up and going/Good Luck....Please dont for get to Vote.Thank you.
Dec 15, 2007 | HP Pavilion zd8000 Notebook
Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook Logo
750 people viewed this question
Clive
Clive
Alun Cox
