Question about RCA PRO854 8mm Analog Camcorder
Video's won't play sound or sound comes and goes during play back
I have a number of old 8mm videos from when my kids were young and I'm trying to transfer them to my PC. On playback the sound either does not play or it comes and goes. If I push on the face plate it seems like it works slightly better. It seems like there must be something that is not adjusted quite right so the pickup is not getting the sound. I also get a blurry area at the bottom of the picture.
5 Suggested Answers
SOURCE: RCA PRO854 camcorder
maybe I would buy your camera,
yes as far as I know hi8 and 8mm are completely different cameras,
where are you and how much for the camera?
david@fullbliss.com
Posted on Oct 15, 2007
SOURCE: Canon UC1 8mm video camcorder
No solution..... but eager to know where one can get the battery packs and charger fir this camcorder (UC1) A 8 mm videotape is stuck within the camera housing and can not be ejected...No battery and charger available..
Where are those battery packs available f.i." SUNPAK RB-E77MF 6V 1700 mA ??
I would highly appreciate your advice
Thanks in advance
J.van Bochove
e-mail: jvbochove@onenet.an
Posted on Jun 27, 2008
SOURCE: I want to transfer old pictures from my D.S.C. to the P.C.
i have the same problem
Posted on Oct 01, 2009
  • 269 Answers
SOURCE: When attempting to transfer to CD for long term
8mm head cleaning tape should be available at most electronic stores.
If the tape does not help after two or three attempts you are best to take it to a techincian.
BTW: The tape is one of the best backup mediums. Transferring to DVD is a great option for viewing only.
Posted on Feb 06, 2011
Playback 8mm camcorder tape fuzzy
8 mm and the newer super 8 mm video tapes are different. You can't use super 8 mm in old player. And old tapes won't play well in new super 8 mm players. Like Sony!
Nov 04, 2013 | Video Cameras
Sony 8mm camcorder will record sound but no video
Since it is playing the tape, the play head is ok. Now recording is done by recording heads so you may have a clogged heads or damaged recording heads. Try to clean the heads with head cleaning tape to see if it would help. 1. remove the tape and leave the door open. 2. using a canned air, blow out any dusts in the tape area. 3. run head cleaning tape for about 10 seconds and no more. 4. try the recording.. If this does not resolve, you may have a damaged or heavy clogged video heads. Take it to nearest video technician for a diagnostic. -James
Mar 28, 2009 | Sony Handycam CCD-TR517 Camcorder
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Sony TRV510-playback, audio choppy, image isn't clear
    I was having the exact same problems, and I read a post on this website somewhere recommending that I just record a few seconds of video on a blank portion of tape and then the camera should start playing video normally again.
    I tried it, and IT WORKED!!
    Jul 15, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
    Old Sony Handycam Video 8 CCD TR36
    Head alignment (re-aligning the tracks) is not something we as owners can undertake - it has to be done professionally.
    You can however quite safely clean the heads by using one of the dry cleaning tapes sold for the purpose. I have used an 8mm/Hi-8 cleaning tape made by TDK for a number of years with good results. Remember that if your heads are dirty both recording and playback will be affected and once you have cleaned the heads you need to test the camera by recording new footage and then playing it back to see if matters have improved. Good Luck.
    Dec 27, 2007 | Sony Handycam DCR-TRV480 Digital Camcorder
    Adapter question
    There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
    Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
    Video Cameras Logo
    50 people viewed this question
    Top RCA Video Cameras Experts
    Lawrence Oravetz
    abdul rauf
    abdul rauf
    Are you a RCA Video Camera Expert? Answer questions, earn points and help others
