Question about Apple iPod Photo MP3 Player
Frozen nothing works!!!
Hi my ipod 30gb(video) frozen screen, no buttons work n the backlight wont even turn off. how do i reset please???
  • Anonymous Apr 20, 2009
    It is making weird mechanical noises and keeps freezeing it also wont let me play any songs when it isnt frozen.
  • Anonymous May 13, 2009
    we could not qble to see display or display not working
    President:
  • Apple Master
  • 688 Answers
Press the Menu Button and the Center button until the apple appears and it will reboot
Posted on Mar 02, 2009
2nd gen ipod shuffle non-responsive
Step 1:
Like all electronic devices, iPods sometimes freeze and become unresponsive. Sometimes iPods lock up when they're dropped on the ground or come in contact with water, but less destructive accidents may also cause them to stop working. All versions of the iPod have a way to reset their hardware should they stop playing music or refuse to turn off.
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated. An iPod will appear frozen and unresponsive if this feature is activated. A lock symbol will appear on your iPod's screen if it is in Hold mode. Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button. Press both buttons at the same time and hold them for up to 8 seconds. Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen. Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod. Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it. Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons. Connect your iPod to its powerblock or a computer if it is still frozen. Wait 5 minutes and then try to reset it. Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again.
Feb 19, 2013 | Apple iPod shuffle Second Gen. Silver (1...
Screen froze on cover flow. nothing now works.
If u hold down the center button and the play/pause button at the same time the ipod will restart. Trust me I had the same issue before on my 30GB Ipod Video
Aug 15, 2009 | Apple iPod nano 3rd Generation
Apple Ipod Nano Chromatic Frozen on black screen.
Try reseting it, It worked for me. Hold down the "Menu" button and the middle button for about 7-8 seconds.
Hope this helps!
Aug 10, 2009 | Apple iPod nano MP3 Player
Frozen ipod
Here you go :) Please rate me on wether or not this article resolves your issue
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
May 06, 2009 | Apple iPod classic MP3 Player
Frozen ipod
Hey i scored you these instructions on how to reset your frozen ipod. Hope its hella useful. Good luck :)
Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
If the iPod is connected to a computer and displays any of the following messages you should eject the iPod from within iTunes instead of resetting it:
Connected. Eject before disconnecting Sync in Progress. Please wait... Do not disconnect If your iPod is frozen or won't turn on, the steps to reset it vary by model. You can easily tell which iPod model you have if you're not sure.
Apr 23, 2009 | Apple iPod MA446LL/A MP3 Player
Dead ipod
If it's frozen, a simple reset should do the trick. Just hold down the "Menu" button and the middle button for about 7-8 seconds
Mar 03, 2009 | Apple iPod classic MP3 Player
Ipod 30GB Video FROZEN
You can try an ywait till it runs out of battery or you can try and reformat it in itunes.
Hope this helps and good luck!
Jaxon
Sep 28, 2008 | Apple iPod MA446LL/A MP3 Player
Black Ipod 30gb
First thing to try is a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Jul 21, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod 30gb video black
Try a reset
To reset your iPod:
Tip:
  • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
  • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
May 15, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod Photo MP3 Player Logo
97 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
