Question about Samsung HCN5527W 55" Rear Projection Television
Picture Bowed I have no idea what happened but all of a sudden the picture bows in the middle. I tried the convergence but nothing helped. The picture is clear in the middle, but thinner than usual then it expands to the outer edges but it is blurry. TIA
    Genius:
  • 1,694 Answers
Try replacing the convergence IC's w/Panasonic STK392-040 for durability,then perform servicer mode convergence alignment procedure.Last,check customer adjust conv. alignment.
Posted on Sep 28, 2007
Picture bowed
Recheck ur connections and the covergence board the same make or return and exchange for another convergence board.Sound like u still have convergence problems.
Jun 11, 2010 | Samsung HCN4226W 42" Rear Projection...
Bowed Picture; Still have access to convergence. HELP!
The convergence power supply board is usually the cause of that problem. You can get the replacement Convergence power supply board from www.tvrepairworld.com
Apr 01, 2010 | RCA D52W23 52" HDTV CRT TV
Sony 46 inch proj tv picture is bowed in the middle and color is
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Suddenly the blue and red went way out of convergence and the picture is bowed, like upwards.. when i try to adjust convergence with setting and remote nothing moves
The Phillips DPTV305-DPTV345 convergence repair kit should fix the issue. The kit is avialable at www.tvrepairworld.com and contains the parts and the CD with instructions
Oct 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
Bowed convergence
It's best to replace both ic 's at the same time,but it will fix the problem.
Jul 25, 2009 | Televison & Video
Bowed picture and color misalignment
Replace both STKS ICs Ck low ohm resistors 2.7ohms most of the time there will be 2 of them bad.
Jun 11, 2009 | Samsung HCN5527W 55" Rear Projection...
Goofy intermitent picture (bows with wiggly fibers across screen)
Convergence amps are going bad replace these and you will fix your intermittent problem.
josh
Mar 02, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Picture is bowed and color is way off
i Would look for a loose connection around the convergence area.
Jan 21, 2008 | Zenith R49W36 49" Rear Projection HDTV
Covergence and Bowed Picture Problem
can you adjust any color of convergence in user menu blue, or red up or down left or right. if you can make any up or down left or right adjustments on any color then the likelihood it wont be a convergence ic. it would be a output resistor. so see if you can get any movement. with it being bowed i was suspect an convergence ic.
Jan 08, 2008 | RCA P60920BL 60" Rear Projection...
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Samsung HCN5527W 55" Rear Projection Television Logo
101 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
