Question about Canon imageRUNNER C3200 Copier
N96 secret codes
Ive forgotten my lock code for my nokia n96 and i cannot get in
Nokia Code : *#7780#
NOKIA Factory Reset (Hard Reset)
Posted on May 10, 2009
I forget my nokia5253 code plz what can i do unlock code
HI PZL TRY THE FOLLOWING THERE ARE THE LIST OF NOKIA
SECRET CODES .. >>
*#7780# Restores Factory
Settings (Memory, language,
counters are not included)
Nokia 3110 Secret Codes
*#746025625# [*#sim0clock#] : Checks if the
SIM clock can be stopped. SIM
clock stop is a kind of stand-by
mode which will save battery
time. This code doesn't work
with software version 4.59. Nokia 3110 Secret Codes
*#3110# : Checking the
phone's software (SW) - Also
called "Firmware Revision
Information".
Nokia 3110 Secret Codes *#92702689# [*#war0anty#]
Press the following warranty
code
7332 (OK) : Displays the date
of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial
Number
7832 (OK) : Displays (if found)
the date where the phone was
purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the
Purchasing Date MMYY
(Warning : You can only set
this once.)
Nokia 3110 Secret Codes 87267 (OK) : Transfers ALL
phone numbers, pictures,
sounds from one phone to
another
6232 (OK) : Displays the Month and Year of Manufacture
(0997)
This code is able to check,
activate or remove SIM card
restriction (SP-lock)
Use the * key to get the p, + and w chars
'Y' has to be 1,2,3 or 4 -
depending of what lock you
what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+3# for
Country-Lock status
#pw+1234567890+2# for
Network-Lock status
#pw+1234567890+4# for SimCard-Lock status # = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4 [Master Code] is a 10 digit
code, based on the phones
IMEI number.
[ No requests for the "Master
Code" will be entertained. ]
Nokia 3110 Secret Codes Eg. To remove restriction on
Lock 1 type following code:
#pw+(master code)+1#
If you just want to check your
phone use 10 random
numbers Eg. 1234567890 as the (master code)
eg. To check if phone if
restricted on lock 1 type the
following code:
#pw+1234567890+1# 1: Insert sim card of different
provider.
2: Turn on the phone and press
the UP VOLUME key for 3 sec.
then release it and the phone
says PIN CODE? 3: Press the "C" key
4: Then Press * and wait until
it disappears and appears
again, then press * one more
time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or
ACCEPTED) and the SIM card is
accepted until you restart the
phone again. NOTE: On version
5.04 Nokia has removed this
option. Fast silent mode
*#06# : Checking the IMEI
(International Mobile
Equipment Identity)
Sep 09, 2016 | Cell Phones
I locked my phone with pass code but I have forgotten when I turn on the phone it asks for code what should I do. The phone is Nokia 2322c with IMEI:355968/04/880123/6 and the code is 4443991
  1. In the next step tap the following secret code: *#7370#
  2. Afterwards enter your lock code. The default one is 12345
  3. Wait a few minutes to comple the whole proccess.
  4. Success! You have just accomplish the factory reset operation.
Jul 17, 2016 | Nokia Cell Phones
How do i unlock a Nokia c3-00 security code when ive forgotten the code
You will need to reset the phone.
You can format your Nokia C3-00 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
Some Nokia phone can be reset via this menu option
Press menu button or enter Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore > YES
I
MPORTANT! Formatting the device will permanently erase all user data and settings as well as add-on applications and operator specific settings.
Mar 31, 2015 | Nokia C3 C3-00 Unlocked
I have forgotten my lock code in my nokia n80 mobile phone. pls help me 2 solve my problem. thankz...
Hello, try this, it might work:
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Other secrets :http://gleez.com/articles/did-you-know/nokia-secret-codes
Also look at this thread -> http://www.fixya.com/support/t450511-nokia_n80_phone_lock_code It might be handy ;)
Oct 19, 2009 | Nokia N800 Tablet PC
N96 Lock code needed
It is verry difficult to do yourself.so you better to send it to a autherised service center.they will easily unlock usig softwares.letd do i. and enjoy.
Sep 26, 2009 | Nokia N95 Cellular Phone
N96 i forgot my lock code cannot open,hw?
Hi buddy there are 2 codes for N96 the LOCK Code and the PIN Code.
If you have not changed your LOCK code, the default number is 12345. The PIN Code is provided by your cellphone provider unless you have changed that too.
All Nokia LOCK code is always a 5-digit code, not 4 or 6-digits. So in case you changed your LOCK code to more than 5-digits, enter ONLY the first 5-digit of your LOCK code.
OR Try this:
Nokia *#7328748263373738# Resets the security code to default(ie,12345)
If that does not work then this applies:
The service provider cannot help you when the passcode has been changed from the default. It is not called a security code for no reason. You have 3 choices:
1. Replace the device
2. Send the device back to the manufacturer or take it to a shop to have the software flashed and reloaded
3. Start at 0000 and keep adding 1 to it (0000; 0001; 0002; etc) until you hit the right number
I hope this will help you otherwise I don't know. Plz vote for me.
Thanks.
Sep 25, 2009 | Nokia N95 Cellular Phone
Hi, I have forgotten the security code and now its
thank you for choosing Fixya.com
click on this site and you will be directly connected to secret codes of Nokia please follow very carefully the instruction.
please don't forget to rate our answers properly
Mar 02, 2009 | Nokia 1600 Cellular Phone
I have forgetten my nokia 6500 security code?
i have forgetten my nokia 6500 security code
Feb 23, 2009 | Nokia 6500 Slide Cellular Phone
Forgotten security code nokia 6301
thank you for using Fixya.com
click to this site and you will be directly connected to nokia secret code manual jsut follow the instruction very carefully enjoy.
please don't forget to rate our answers properly.
Feb 21, 2009 | Nokia 6301 Cellular Phone
Canon imageRUNNER C3200 Copier Logo
941 people viewed this question
old marine
old marine
