Question about StarTech.com StarView SV211K 2-port KVM Switch
S/box won,t work
Starview3 went off 23-12-08 i have used codes on fixya before, to get it to work.but this time i pressed ok twice on store,now it won,t change codes, i can,t get it to clear any codes .now it going onto standby automatically then goes off and comes back on on its own. its going on to normal channels i.e bbc 1.2.3.etc. please help thanks dickie
A friend fixed it for me. he installed a new firmware and factory setting that,s all i can remember hope this helps
Posted on Dec 29, 2008
Need a universal remote code
Try 0000..
If that doesnt work I have another solution for. Westinghouse flat panel TV
TV 10812 probably has the correct IRsignalsfor enter programmed to the ok/select button. However the comcast and access remotes are intended to control a cable system so even in tv mode the remote sends the digit, ch+1and enter signals to the set top box.
There are two ways to defeat this.
1)Turn off channel lock. Sethe 9xx comand for this.
OR2) Assign a EFC for the Enter signal to the device mode.
1) Press TV
2) PRESS SETUP UNTIL IT BLINKS TWICE.
3) Enter 994 (two blinks)
4) Tap setup(DO NOT HOLD)
5) Enter 00069
6) Press ok/select.
The remote should blink twice and the ok/select button should work in the tv mode.
Use 1 unlessyou're going to use remote with cable box.
I hope this works...
Dec 17, 2014 | Westinghouse Televison & Video
I cant program my uverse remote with my 32 inch emerson lcd tv.
Try using the codes for Funai, Daewoo, all the low end China sets.
Dec 18, 2010 | Televison & Video
Anybody out there with new ntl codes for Dublin area 28/6/09
Not 100% certain that this'll work even if yrs is a starview5 box but just in case it is but this is what I did & hopefully it'll work for you too - good luck :- Even if not Starview3 it might give U a few tips ;o)
Subject: Star View 3 The Box Super when channels discappear ;o) 1. Press menu then Factory Setting & Enter code 0000 to reset. 2. Exit to main menu & enter 1570 to get into the CASS SYSTEM & turn EMU on 3. Reinstall channels (Goto Installation, Cable network (try TW first & if no channels try NTL then C & W and so on - I'm with Virgin & used the setings for TW) & Voila ;o) Nb: You may have to redownload channels so reconnect yr box to the computer & follow the link below http://www.4shared.com/file/76886028/fd4ac296/GTRom_the_box_Super_8102e_081129.html?err=no-sess & press download !!!
Jun 28, 2009 | StarTech.com StarView SV211K 2-port KVM...
Uverse remote connection
This process should be used if the code for the device is not listed in the Manufacturer Code List.
  1. Turn on the device you wish to program.
  2. Point the remote control at the device.
  3. Press and hold the Mode key (TV, DVD or AUX) you want to program. Without releasing the selected Mode key, press and hold the OK key simultaneously
  4. Release both the Mode key and the OK key at the same time.
    All the Mode keys will flash twice indicating programming mode.
  5. Enter code 922 by pressing the number keys on the remote control. The selected Mode key will flash twice indicating correct entry.
    Note: This next step is For AUX Searching only, press and release the PLAY key then press:
    • 1 for VCR
    • 2 for Receiver/Tuner
    • 3 for Amplifier
    • 4 for Home Theater In The Box (HTIB)
    All the Mode keys will flash twice indicating correct entry.
  6. For AUX only, press and hold the PLAY key and wait until the device turns off, then release the PLAY key.
    • The REW key can be utilized to go back through the codes one at a time.
    • The FF key can be utilized to move forward through to codes one at a time.
    • Press the PLAY key to resume auto search of device codes.
  7. To save the code, press the ENTER key on the remote control (bottom right) or press the EXIT key to return to normal operation.
    The selected Mode key will flash three times and return to normal operation.
  8. If no valid code is found, the red light will flash two times and the remote control will return to normal operation.
  9. Turn the device back on using the remote control. If this doesn’t work start over or try Manual
  10. Press the appropriate Mode key on the remote control to work with the selected device. To use the remote control for the AT&T U-verse TV Receiver, press the AT&T Mode key.
May 24, 2009 | Durabrand DWT1905 TV
Starview3 the box
Hiya this is what I did & hopefully it'll work for U too - 1) Deleted all th channels & reset 'factory settings' by entering the code 0000, turned th box off waited a couple of minutes & turned it back on !!! 2) You may have to redownload channels so reconnect yr box to the computer & follow the link below (But try without doing this & goto stage 3) first & please let me kno if that works :- http://www.4shared.com/file/76886028/fd4ac296/GTRom_the_box_Super_8102e_081129.html?err=no-sess ) & press download !!! 3) ReConnect & Turn box back on; goto menu & press 1570 to get into the CASS SYSTEM & turn EMU on Reinstall channels & voila
Jan 29, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Coby tv code for fios remote
1. Press and hold the TV key. 2. While holding down the TV key, press OK. 3. Release both keys. The Device Keys will blink twice.
Ideally we do not have code for coby TV. So we need to manually program the remote
TV and Cable box should be both powered on.
4. Press 9 - 2 - 2. 5. Point the remote at the TV. 6. Press PLAY Press FAST-FORWARD. Every time you press FF the remote sends out a new power-off command to the TV. Keep pressing FF until the TV turns off. (You can press REWIND to go back 1 code.) 8. When the TV turns off, you have found the right code. Press OK to store this code. 9. Press TV and the power should go on. You will now have volume control also.
TIP: Press ff slowly so you know when it powers off and when you need to save the code by hitting OK after it powers off.
Jan 02, 2009 | Coby TF-TV1901 19 in. LCD Television
Starview3 box
Subject: Star View 3 The Box Suoper when channels discappear ;o)
Dec 29, 2008 | StarTech.com StarView SV211K 2-port KVM...
Cannot find a device code for ATT Uverse DVR cable box
1. Release the volume controls and assign them to the AUX: A. Press and hold AT&T Button and OK Button at the same time, release both buttons. All the mode keys will flash twice indicating you're in programming mode.
B. Enter 955 on the remote keypad, the AT&T key will flash twice indicating a correct entry
C. Press the mode key you want to alway receive the volume commands - I assigned mine to the AUX mode button. The mode key chosen will flash three times indicating success. Volume commands will now be delivered to the AUX button regardless of the mode you are in. 2. Assign the AUX to the BOSE system: A. Make sure the Boze remote receiver is powered on (green light is on). B. Press and hold the AUX Button and OK Button at the same time, release both Buttons. All the mode keys will flash twice indicating you're in programming mode. C. Enter the 4 digit BOSE code on the keypad, I used BOSE Remote Code 4000.
D. The AUX Button will flash three times indicating correct entry.
Dec 28, 2008 | Bose Cinemate Digital Home Theater System...
The Box-T codes for Chorus MMDS
Hi Geridowling,
Thanks for posting those caodes but I think you ar missing a couple of digits on the 00 line.
Could you please post the missing two didgits?
Cheers,
Captainautumn
MENU 5E 01
KEY CODE 00
19 2E 87 80 61 74 90
PRESS OK TWICE
KEY CODE 01
AA 26 9E F2 E9 14 D1 AE
PRESS OK TWICE
Dec 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
Cable boxes
Hiya this is what I did & hopefully it'll work for U too, not too sure about Irish Ntl tho but worth giving it a go :- 1) Deleted all th channels & reset 'factory settings' by entering the code 0000, turned th box off waited a couple of minutes & turned it back on !!! 2) You may have to redownload channels so reconnect yr box to the computer & follow the link below (But try without doing this & goto stage 3) first & please let me kno if that works :- http://www.4shared.com/file/76886028/fd4ac296/GTRom_the_box_Super_8102e_081129.html?err=no-sess ) & press download !!! 3) ReConnect & Turn box back on; goto menu & press 1570 to get into the CASS SYSTEM & turn EMU on Reinstall channels & voila
Oct 02, 2008 | StarTech.com StarView SV211K 2-port KVM...
StarTech.com StarView SV211K 2-port KVM Switch Logo
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
