Question about RCA F27676BC TV
PC to TV via S-Video
I hooked up an S-video cable from my video card to my RCA 27 inch tv, and i cannot change the video source on the tv. I have the original remote for the tv and i cannot find the video button, I use a Shaw Universal Remote Control Atlas XL (picture can be found on www.urcsupport.com). I use the video source on that remote control but only goes to my dvd player and back to the tv if i hit the tv source button twice. Is their a way to view the s-video feed? Cheers Jamie
  • 56 Answers
You can purchase an AV Scart Hub (a switching box/scart box),and connect all of your devices to your tv.
Posted on Apr 15, 2007
I have a (i think 20 inch) rca truflat tv and i can't find the channel for video and dvd. the manue didn't help and i don't have the guide"
Press menu on your remote. Press "4" for channel and "4" for video input source. In this menu, you can toggle between s-video and regular video (yellow plug) input. The disadvantage is, if you're like me and you've got a DVD player and and VCR (or maybe a video game system) all hooked up to the same TV, you've got to go through the menu and switch the inputs to watch something else. I'm happy with my digital audio cable; I'll deal with yellow-plug video.
Oct 12, 2011 | RCA TruFlat 27F520T 27" TV
We did a channel scan by accident while trying to hook up a dvd player (couldn't get that hooked up) and now are unable to get any channels. model#20f424t
With the tv cable hooked up do another channel scan and that should find all the channels again. As for the DVD there should be a source button or a tv/video button for that :) hope this helps :)
Dec 27, 2010 | RCA TruFlat 27F520T 27" TV
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
No Picture or sound in TV Mode
Are the RCA cables matching(in tv to out sources.audio to audio and video to video)?And make sure the cables are in working condition
Nov 15, 2017 | Sceptre Naga III X27SV 27 in. HD-Ready LCD...
Have an RCA F27636BC TV. Can u hook a DVD player
How to hookup TV
If you have a TV with only a single coax input and you want to hook up components like DVD players and VCRs, here's how to do it.
What you need to connect your DVD player or game players to a TV that only has a VHF/UHF 75-ohm F-connector ("coax antenna input").
1.) RF Modulator with Stereo Audio Inputs.
2.) 6 foot long coaxial cable with male "F" connectors. This cable goes from the modulator to the TV. The modulator also has a coaxial input to plug in your antenna or your VCR.
3.) 6 foot long Video and Audio Cables with "RCA" plugs. The cables connect the yellow, red and white outputs from your DVD or game player to the yellow, red and white inputs of the modulator.
Works with X-Box, PlayStation, Nintendo or other devices that output audio/video via the RCA plugs and you want to connect them to your coaxial only TV.
Nov 24, 2009 | RCA F27636BC 27" TV
I connect my sanyo 42 inch LCD tv via s-video, no signal on TV
Be sure you changed the source on the tv (i'm guessing you did this), be sure you switch the out-put on your computer to s-video. You can do this in the properties box. If you are running the nvidia video utility, you can set up hot keys to do this. I set up ALT, Z, 3 as my hot key combination. All I do is hook up to my tv, press the three buttons above, at the same time, and the video moves from my pc monitor to the tv.
Sep 10, 2009 | Nvidia GeForce 7200 Graphic Card
Must hookup DVD-VR375to tv,cablevision box & MSNtv2.
Here's How:
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Jan 20, 2009 | Air Tools & Compressors
I want to hook laptop up to tv
after you hook the cable up to the tv, go into the tv's menu to make sure the input mode is set to s-video. then go into the control panel on your laptop and find the settings for your video card and set the output to "TV" or "Clone"
Let me know :)
Dec 24, 2008 | Toshiba Satellite A35-S159 Notebook
Hook up to computer
your computer must have a video card installed that has S-VIDEO OUTPUT so you can send it into the S-VIDEO INPUT to the tv
Sep 23, 2008 | RCA TruFlat 27F520T 27" TV
Ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | iLO V27DMBX Television
Televison & Video Logo
137 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
