Question about GE 24 in. GSD4630Z Built-in Dishwasher
Leaking door (Running Water)
Earlier today the door on my dishwasher was leaking water. That is to saYy it was running out as if the water level overfilled itself. the dishwasher is several years old and appeared to be n good condition when I bought my house. In the recent pasy (Year) i have replaced the hose underneath as it leaked previously. The door seals do not appear hard, discolored or inflexible. After I stopped the washer, I opended the door to remove the dishes that remained. Once I closed the door it began to leak again. It is a GE Model GSD4630Z and I have no idea how old it is. I am guessing around 10-12 years. Is it even worth the time and money for a service call due to its age? Thanks.
  • Anonymous Mar 28, 2014
    Model FDB212RBM0. I replaced the gasket around the door in 2011 but it has started leaking again with no sign that the gasket is bad. Could it be somethingelse?
    President:
  • 1,462 Answers
Being in the uk i dont know this appliance, but the fault is probably that it is overfilling caused by crap in the airchamber or the hose leading to the pressure stat blocked or a split in this hose
Posted on Apr 15, 2007
Samsung dishwasher leaking when not running
First, try to find the source of the leak. Leaks most often appear at the door of the dishwasher or underneath. Leaks can be caused by a number of issues: worn door gasket, water temperature, leaking drain hose, worn gaskets, or a corroded tub. For help identifying the cause and finding a solution, see the troubleshooting chart at Dishwater leaking for more information. Good luck!
Aug 17, 2012 | Samsung Dishwashers
The door on my Maytag Dishwasher is leaking out of the bottom. Do I need to replace the seal or could it be the float?
Hello, Thank You for using FixYa. I will be helping you today. If its only leaking while its running i would check the lower spray arm for cracks if its cracked or damaged it will cause water to shoot up over the bottom of the door every time it spins around. Its best to remove the door panel and let it run and you can see better where its leaking from.
Thank You and please rate my answer if it was helpful..
Jun 21, 2011 | Dishwashers
I have a Model #DU960 Pwkq1 Whirpool dishwasher leaking
It is probally leaking from the vent assembly, rinse aid or soap dispenser. You will need to remove the door panel. Do this when the dishwasher is dry. Look closely for staining where the water is running down the inside of the door. Replace the gasket. Here is a couple links that should help with this.
http://appliancehelponline.com/dishwasherdispenser.html
http://appliancehelponline.com/dishwasherfrontpanel.html
Jun 03, 2010 | Whirlpool Dishwashers
Leaking dishwasher simpon silencio 850. not alot of water 100mls or so. can't see where it is leaking from, there are some water marks on the front right underside.
Commonly leak from door seal- check seal for rips, notches. Also common to leak from the black retainer that the door seal sits it-remove the seal (they just pull off) and shine a torch from inside the dishwasher around the back of the seal retainer, and see if there are any gaps around the outside of the seal retainer. Repair with silicone sealant if any gaps. Other things to check- check the screws that hold the top basket runner on are tight- there are two holes in the runners, move runner until you can see screw, check they are tight. Also check water level is not too high inside machine whenits running- there are three vertical lines on the bottom spray arm support tube- water level should not be above top line. If still leaking, call in the experts!! Good luck!!
Mar 13, 2010 | Dishwashers
My dishwasher is leaking water from the front door
The water inlet level setting could be faulty and thus "overfills" the washer with water. The water level is senced via a plastic tube feeding an ajustable switch. Sometimes the plastic pressur sence pipe gets clogged and water level is then not correct. The switch can have burnt contacts and might need replacing.
Jan 23, 2010 | Dishwashers
Water Pouring out of door, appliance stuck on wash
dishwasher leaking from the door or from the bottom of the door is common problem and yes its advisable to get it fixed.but if its having any other problem other then leaking then it has to be checked first.but leaking problem is common it can be solved.first from which part of the door area the leak is occuring that has to be checked.
Some common leaking trouble makers....
Leaks at the door:
Door gasket loose/torn
Corner gaskets or door baffle/vent gasket
Door lock/latch loose/broken
Split spray arm
Over filling with water...usually the level is just under the heating element is normal
Something leaking through the door...like the soap or rinse agent dispenser gasket, silverware basket button.
Door hinge(s) bent
Wrong soap was used...dish sink soap instead of dishwasher soap
Rinse aid being used with mechanically softened water ( makes foam or suds inside the dishwasher )
Leaks from under the unit:
Look for whiting or calcium stain on the motor and pump assembly = motor and pump assembly seal leak...access panel removal help
Hose for upper spray arm split
Fill hose split or fill hose spout air inlet is calcium covered
Drain hose is split
Rusted liner...metal liners only
Fill valve leaking or allowing water to fill all the time
Heating element ends....where they come out through the dishwasher liner
Float or float gasket
for parts you can get it from
www.repairclinic.com
Nov 21, 2009 | Candy Dishwashers
My dishwasher is leaking water when it is running
If it's leaking out the front by the door then you should check the latch and the rubber gasket/seal around the door.
If the leak is under the dishwasher then it could be the waste/drain hose or it's connection to the dishwasher or the pump/valve assembly. You should be able to narrow this down by running the dishwasher with the kickplate removed and feeling around underneath while it is running to find the water source.
Oct 04, 2009 | Dishwashers
Sounds like it's running but no water seems to be getting to it
Your drain m ay be clear but it sounds as though the dishwasher line may now be clogged, remove the dishwasher drain line from the trap below the sink and check for leaks. You drain nthe dishwasher into a bucket.
Mar 20, 2009 | Dishwashers
Water leaking from the door
Could be a number of things. If you are in an area with hard water you could be using too much soap or the wrong soap. The dishwasher could be out of level, or the door seal could need replacing. Dishwashers also need to be cleaned. Soap residue builds over time. Try running the d/w with no dishes or soap, pour 5-6 cups of white vinegar directly into the tub and run a whole cycle. And again watch the soap usage.
Apr 08, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
165 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
