On my laptop Fn displays a certain number icons corresponding to Esc, F1, F2,F3,F4,F5,F6,F7,F8, F9 with F8 activating and deactivating the Wireless. F10 toggles the overlaid keyboard, F11 allows one to use the overlaid keyboard
There are no icons for F10, F11, and F12.
After the icon for F9, there is one for TAB, another for Space, and a last one.
If you click the last icon you open a second set (second page) where there are other icons that control other features. There is one to turn ON and OFF the BlueTooth Adapter.
SOURCE: Enabling wireless LAN on Medion Akoya
install the driver for your wifi device. go to your laptop manufacturer website and download the driver. www.medion.com
SOURCE: Wireless Button Disabled
After one month of trying everything, I finally figured this one out. First turn off and restart your computer. Then press F10 to enter the System BIOS Settings. Select F9 (Setup Defaults) and when it asks Load Default Configuration Now? , Enter YES. Then, press F10 (Save and Exit) and when it asks Save Configuration Changes And Exit Now, Enter YES. This should restore the wireless LAN button to its original factory settings. Once you restart the computer the button will be listed as disabled, but press on the button and it should work again. I hope this helps someone else out!
SOURCE: this wireless network device is disabled. please
Please check your device manager and see that it is enabled.
Thank you
SOURCE: can't enable Dell Wireless 1390 WLAN Mini-Card
I had the exact same problem and went through the same steps that he did. It was only when I searched for a physical wireless switch (on the left side of my Dell D630) that the problem was solved. I didn't even know it was there and must have inadvertently knocked into the off position.
F1 - Security System
Press and hold the "Fn" key on the lower left-hand corner of your Toshiba keyboard.
Press the "F1" key to activate the security system.
Your laptop's screen will go blank so others can't see what you are working on or accessing.
No Fix, No Fee. Same Day or Free. We Come To You - 1300 723 628
www.thepcdoctor.com.au/melbourne
Press any key or touch the touchpad to exit the security mode.
F2 - Power Save Mode
Press and hold the "Fn" key.
5
Press the "F2" key to activate the Power Save mode and make changes to how your laptop handles operating on battery or AC power.
6
Press "Fn" and the "F2" key again to exit the power save mode.
F3 - Standby Mode
7
8
Press the "F3" key to place your laptop in Standby mode.
The Standby dialog box will appear.
9
Verify you want to enter Standby mode. Press the power button on your Toshiba laptop to exit Standby mode.
F4 - Hibernation Mode
10
11
Press the "F4" key to activate the Hibernation mode and save whatever documents and files that are open to your hard drive.
12
Verify you want to enter Hibernation mode. Press the power button on your Toshiba laptop to exit Hibernation mode.
F5 - Active Display Device/F6 and F7 - Toshiba LCD Screen Brightness
13
14
Press the "F5" key to change your laptop's active display device from the laptop screen to an external monitor.
15
Click on the display configuration you want: displaying on both the laptop and external monitor; only on the laptop; only on the external monitor; or a specific screen resolution.
16
Press and hold "Fn" and "F5" to accept the new display settings. Press and hold "Fn" and "F5" again to return to your laptop's display only.
17
18
Press the "F6" key to decrease your laptop's screen brightness. Press the "F7" key to increase the brightness.
F8 - Wireless Connection/Bluetooth
19
20
Press the "F8" key to select the wireless Internet or Bluetooth connection you want to use.
21
Press and hold "Fn" and "F8" to make your selection. Release the keys to confirm your selection.
F9 - Touchpad Control
22
23
Press the "F9" key to enable your laptop's touchpad.
24
Press and hold "Fn" and "F9" again to disable the touchpad.
F10 and F11 - Numeric Keypad/F12 - Scroll Lock
25
26
Press the "F10" key to enable your Toshiba laptop's numeric keypad.
27
Press and hold "Fn" and "F11" to enable the cursor control keys on the numeric keypad.
28
Press and hold the "Fn" and "F10" or "F11" key to disable the numeric keypad or cursor control keys.
29
30
Press the "F12" key to lock your cursor on a specific line of text. Press and hold "Fn" and "F12" to turn scroll lock off.
hope this helps
