Question about Hotpoint UY46 Style Line Stainless Steel Electric Double Oven
Oven on full all the time
Oven not regulating temperature on full all the time
  • Hotpoint Master
  • 3,463 Answers
Ypu need to replace faulty main oven thermostat, as it is obviously not controlling the temperature.
Posted on Dec 25, 2008
Why does the f10 code keep appearing on self cleaning fridgidaire oven? When using oven it starts heating out of control. Tends to happen when oven is being used for longer periods of time.
The thermostat is defective. It is a temperature sensor operated switch. It turns the heating element on and off to regulate the proper temperature in the oven at all times.
Jun 03, 2014 | Frigidaire Ovens
How does it self clean
The oven temperature is regulated by a temperature sensor when placed in self clean the sensor is removed from the circuit and full power is applied to both the bake and broil elements causing an the temperature to exceed in some some models up to 1,000 F. I would recommend against using self clean for the simple fact that no oven cavity to this date has been designed to withstand that high of a temperature and therefore excess heat is passed upward resulting in damaged lock mechanisms, control boards, and other electronic components.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 24, 2012 | GE Ovens
F10 oven code frequently beeps,often after cooking is over and oven is coolind down at different temperature settings tempermental some times it works sometimes it does not.
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It suppose to be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
Jul 15, 2011 | Frigidaire Ovens
Control dial on oven not working heat on full all the time
I have exactly the same problem, oven is heating to max every time, I have just replaced the thermo stat and temperature regulator to no effect.. running out of options an dmoney now!! Anbody able to assist with some knowledge??
Jun 14, 2010 | Zanussi ZBF360X Electric Single Oven
My oven takes a very very long to reach temperature
Hi.
Check the pressure regulator, and ensure that burner is working regularly. If the problem is not related to burner and pressure, then replace the temperature probe, that can affect heating time.
Regards.
Mar 05, 2010 | Amana Ovens
Fagor oven will not regulate its temperature, once
From the symptoms you describe, I would say the oven thermostat is faulty, and in need of replacement.
This is the control you regulate the temoperature with.
Hope this helps.
Dec 15, 2009 | Fagor 5HA-196 X Single Oven
2 of 4 ceramic rings do not respond to lowering the heat setting
You need 2 new temperature regulators fitting.
Quite a common problem..
Thanks
Plz rate solution
Dec 16, 2008 | Hotpoint SY36 Style Line Stainless Steel...
Oven temperature
you guys should check your tempurature sensor. Our oven has been acting weird like saying it has heated up to 400 degrees in like 1 minute haha. Well after a few months of this happening on occasion we get an F2 error flashing..
did some research on it and apparently for GE ovens this is a temp sensor gone bad. Im looking to buy one now which is how i found this post, i just thought id tell you all what i found out and maybe you should look into that as well.
Oct 30, 2007 | Viking VGS0166 Stainless Steel Gas Single...
Oven not heating
there is more to this than meets the eye if youre oven takes a long time on fan setting it may be thermostat but more likely to be fan not turning at all or quickly enough the stat capillary is above oven element and if fan not blowing air away from capillary oven stat will shut oven temp down too soon if using conventional heat eg no fan make sure there are no full size trays directly on bottom of oven this will block heat from bottom element effectively giving only half the heat output.
hope this helps
Jun 13, 2007 | Bosch HBN 430560B / 430520B Single Oven
Hotpoint UY46 Style Line Stainless Steel Electric Double Oven Logo
131 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
Steve Allison
Steve Allison
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
