Question about Fisher RS909
Vintage speaker connection
I have a pair of "The Fisher XP-55b" loud speakers, and they have COM/OHMS connections instead of a typical +/- one. So, how can I connect them to a new amplifier? My current connection is that "+" to "COM" and "-" to "OHMS". If I changed the current poles, would I only change the diaphragm's beating direction? I am wondering if there is an appropriate connection form for those ones. Thanks..
  • dark side
    dark side Apr 15, 2007
    It's like my speakers sounded quite clearly after I had connected'em in your way. Thanks.
    Brigadier General:
  • 6,966 Answers
Hi, assuming there are only 2 connections then you're idea is basically sound as long as you follow the same setting/connection scheme for both left and right speakers. However, you may want to reverse since if I remember it right COM would refer to common or ground and therefore OHMS(there should be a 4 or an 8 somewhere) would have to be the +. It might also be a good idea to check if the impedance of the speaker will match the "new amplifier". Please let me know how this turns up. Regards.
Posted on Apr 15, 2007
Safe to use 4 speaker with Technics Receiver?
The best thing to do is place a VOM meter to confirm that there are 6 ohm speakers
Nov 21, 2014 | Technics Audio Players & Recorders
How do I pair speaker with phone
turn both phone bluetooth and speaker bluetooth off. then turn them back on. the speaker's light should be flashing indicating its searching for a device to pair with. as its flashing make sure your phones bluetooth is visible and searching. they will pair and your phone will tell you and the speakers light should quit flashiing and just remain on.
Oct 20, 2014 | Audio Players & Recorders
I have a saex700 with mission speakers 753x4 connected when i run all 4 of them fairly loud i seem to get a sort of popping noise from the speakers if i turn 1 pair off it stoppes its not the speaker
Transient response is increased with all four speakers connected so you are hearing cone rattle that you wouldn't hear ordinarily. Excessive drive is a contributing factor as well.
Jan 10, 2014 | Technics SA-EX700
Put new pa speakers in church 2 1000 watt tied 2gether and 2 300 watt. tied 2gether. the pa amp only has 250 watts with 6 mics connected and a cd player which plays fine. every time the mics are used if...
hi,
You have to check the ohms of the speakers all spekers should be 8 Ohms or above. if not it will overload the amplifier at high level. The minium ohms impedence of the amplifier is 4 ohms. If you connect two 8 ohms speakers together then the effective ohms will be 4 OHMS then the amp will handle the speakers. If you connect two 4 ohms spekers together then the effective ohms will be 2 Ohms, this will overload the amplifier. You will be able to connect two 8 ohms speaker to left channel or right channel of the amplifier. Check the speaker spesifiction to know its ohms. Make sure all the speakers have an impedence of 8 OHMS or above
OK
Aug 19, 2011 | Radio Shack 250 Watt PA Amplifier...
I am using an old pioneer SA-750 stereo amplifier and am having trouble connecting 4 speakers instead of just two. Is there any way that I can utilize alll the speaker ports in the back instead of just...
Now make a match of TWO pairs of speakers which must have the same impedance so that it could be connected in series or parallel to get the right impedance preferably closer to 4-8 ohms .
Use a mulitmeter in the ohms range to check the rating of the coils and connect in series/parallel to get this combination. connect two each into one channel.
Please get help if in doubt to connect the speakers.
Aug 18, 2011 | Audio Players & Recorders
I have five pairs of 8 ohms speakers which i want to connect in serries. what wattage will you advice ?
Why? Amps are designed for specific loads, typically 8-ohms. I'm sure you could arrange several speakers in such a way as to present as close to, say, 8-ohms as possible.
Feb 15, 2011 | Behringer EUROPOWER EP2500 Amplifier
I have an Onkyo A-7055 amd want to hook up two speakers. Looks like a dozen connectors in the back of the unit... which ones to use. If I experiment is there a chance I could blow out the unit?
Do you mean you want to connect 2 pairs of speakers, or just 2 speakers like you say in your question? There are 4 pairs of screws on the back of your amplifier on the upper right side of the rear panel near the fuse cap and the AC outlets. Each pair of screws will be connected to one speaker. Your Onkyo can be connected to 4 speakers. If you want to connect only 2 speakers, use the screws labeled "SPEAKER A" and connect the speakers to the left and right channels, and make sure you connect the + speaker wire to the screw with the red marking around it. Connect your other speakers the same way, one speaker per pair of screws.
Nov 15, 2010 | Onkyo Audio Players & Recorders
I have just been given a pair of aiwa speakers sx-fz1800,there is two cables comming out of the back,which one do i use.
One pair goes to bigger speaker (woofer) and other pair for smaller speakers in box, to get full frequency response, you need to hook both cables.
Sep 10, 2009 | Audio Players & Recorders
I have a set of peavey scorpion sp5xt's one works fine but if i plug into the other one ,in full range, only the horn works,
Horn and speaker combo cabinets have an electronic component called a "crossover". The horn and speaker both work off different electrical signal frequencies. If you can take off the back, or get inside by pulling the speaker, check for a small circuit board mounted inside the box or on the speaker or horn. Check for a broken wire or loose connection of the crimp connectors.
A common problem with speakers, often the cone, or paper part of the speaker will come un-glued or separated from the magnet "voice coil". This happens when played too loud, when it's commected to the wrong impedance, or if the signal was shorted and "overdriven" (usually sounds like an awful buzz that's really loud).
Always make sure your output impedance matches the impedance of the speaker. Most auto stereos are 4 Ohms. Older home stereos are typically 8 Ohms. Musical PA gear varies between 4, 8, and 16 Ohms. Peavey gear is typicall 4 Ohms, but some older models are different. The Ohm rating is the amount of the resistance in the circuit. If your speaker is 4 Ohms and you plug it into an 8 Ohm circuit, you can destroy the speaker and sometimes the crossover circuit board.
Good Luck.
Jim
jimmydsmith@cox.net
Phoenix, Az
Jan 09, 2009 | Music
Behringer ep2500 amplifier
Yes you can,,,,,BUT the output labelling on the AMP will tell you where you can connect the 4ohms or the 8ohms....please read these labels and connect the 4ohm speakers to the 4ohm terminals, and the 8ohms to the 8ohms terminals...
If you intend to connect the 4ohm and the 8ohm speakers in parallel then the output impedance terminals you use should be the 4ohm ones.
If there is no labelling showing any 4ohm output terminals then its best if you dont use the 4ohm speakers at all....just connect the 8ohm to the 8ohm terminals...you dont mention any crossover networks inside the speaker boxes or if you have tweeter speakers... so just stick to the basics above at present....
Cheers From YUBEUT
Oct 20, 2007 | Sunfire Cinema Grand Signature 400 seven...
493 people viewed this question
Top Fisher Audio Players & Recorders Experts
Are you a Fisher Audio Player and Recorder Expert? Answer questions, earn points and help others
