Playstation 3 - acoustic solutions tv connection
I cannot get my ps3 to play on a new acoustic solutions lcd2676IHDF lcd tv. It works well on other tv's.
  • Anonymous Dec 25, 2008
    my sons ps3 wont connect---------- happy xmas
3 Suggested Answers
SOURCE: Acoustic Solutions 26'' HD TV cannot play PS3 blue ray films
I have recently brought the same TV and had the same problem but I've mangaed to find a soultion.
The automatic setting for Blu Ray on PS3 is Full HD (1080p) but the Acoustic Solutions TV is HD ready (720p). For PS3 games it will automattically change settings for you to 720p. This is why this works straight away but Blu Ray doesn't.
Solution
You need to plug in your PS3 using the scart contection, then on the ps3 menu go to settings > display settings > HDMI. You will then need to attach the HDMI cable and manually set up
HDMI by checking the 720p option and deselect 1080p.
That should then play Blu Rays too. You don't lose too much quality as 720p works nearly as well as 1080p on smaller TVs.
Rich
Posted on Mar 30, 2009
SOURCE: lcd26805hd manual
My acoustic solutions lcd26805hd tv has started flickering really badly every time I switch it on. The flickering goes on for about 30 minutes before it calms down. I have checked all the connections at the back of the tv - all ok. This happens whether I watch cable or a dvd.
Posted on Aug 12, 2010
I try and play dvd's in my playstation 3, and within about 5 seconds, it says 'loss of signal' i sent if back but they found no problem with it... yet the problem of not playing movies has not been fixed.
simple solution if you are using hdmi the tv must be on first and to the correct input then turn on the ps3 . also you may have a bad hdmi cable. try using a differnet connection to your tv. let me know asap if that works i have swome more solutions.
Mar 16, 2011 | Sony Playstation 3 (PS3) Console
I connected a sony playstation 3 and there is no sound while playing games. The video works and I can play the game, but there is no sound. I returned the playstation 3 thinking it was the console but the...
http://manuals.playstation.net/document/en/ps3/current/settings/audiooutput.html
Adjust the audio output on your playstation and the television depending upon how you're connecting it to the television for picture and sound.
For an hdmi cable between the television and the PS3 only then adjust the audio ouput to hdmi on the PS3.
You do not need to connect anything else between the television and the PS3 besides an hdmi cable.
If you are using the colored plug type component or composite cables then it is av.
If you are connecting with a fiber optic cable to a surround sound system then it is set to optical.
Depending on what television you are using you would also have to change the Playstation to 48khz/96khz
Jan 09, 2011 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
PLaystation 3 won't link up via HDMI cable
You might want to try a factory reset on your PS3 = turn it off then hold down the power button for 5 seconds it should then Beep.
there is a small memory in the PS3 that stores info about the tv that is was Initially setup on. IF you do this reset this should allow you to connect it to your Acoustic Solutions tv via the hdmi cable.
Another Tip i would do is connect it all up with it turned off then power up your appliances once its all connected.
Hope this sorts it out for you
Little Dish Fitter
Sep 18, 2009 | Televison & Video
Solution
Rich
Feb 18, 2009 | Televison & Video
Video has white lines that roll on screen.
cheak video output 480 reg tv 720 p mid quilty lcd plamasa or full 1080 p only on hi end lcd tvs ect ok
Oct 06, 2008 | Sony Playstation 3 (PS3) Console
PS3 Won't Play Blu-Ray
If there is no picture on the TV screen: Back to top
  • Check that the input mode of the TV is appropriate for the connector in use on the PLAYSTATION®3 computer entertainment system.
  • There may be a problem with the cable in use. Try using another cable that is compatible with the PLAYSTATION®3.
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
If the DVD or Blu-ray Disc™ (BD) cannot be played, or the picture is distorted: Back to top
  • When outputting DVD content or PLAYSTATION®3 system format software in SD resolution, only discs recorded in the NTSC standard can be played.
  • If the PLAYSTATION®3 is connected to a VCR or a combination TV/VCR unit, copy protection encoding on some DVDs and BDs may cause image distortion, or may cause the image to become lighter or darker. In such cases, connect the system to the TV directly.
  • If the DVD or BD does not match the region code set in the PLAYSTATION®3, it cannot be played.
  • Some DVDs are preset with parental control restrictions. Enter the password that was set in "Security Settings" to temporarily increase the viewer age restriction level.
  • Some BDs are preset with parental control restrictions. Enter the password that was set in "Security Settings" to change the parental control level.
  • The BD may be disc-locked. Enter the password that was set when the disc was created.
if non of that works you need to contact Sony at
1-800-345-7669 (SONY)
Mon - Sat 6:00AM - 8:00PM PST
Sun 7:00AM - 6:30PM PST
Good Luck,
-Rel
Apr 16, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3
when you turn the ps3 on with hd cable connected to tv hold down the power button for 10 seconds and it will run the optimal viewing settings screen. hope this helps
Jan 09, 2008 | Sony Playstation 3 (PS3) Console
Tv sound & surround sound
Go to Settings/SoundSettings/AudioOutputSettings/AudioInputConnector or DigitalOut depending on type of input you are using for surround.
Jan 02, 2008 | Sony Playstation 3 (PS3) Console
Samsung LCD tv
same problem.. i always get the screen: "not supported mode". whatever the hell that means. so the issue is definately with the tv and not the playstation. has anyone tried contacting Samsung?
Nov 03, 2007 | Sony Playstation 3 (PS3) Console
Games run on hdmi, but not Blu-ray movies
You most likely have the updated drivers. You may have to go and change a setting. I found an answer on the PS3 website that may be of some use to you. I hope this helps you: http://boardsus.playstation.com/playstation/board/message?board.id=ps3&message.id=1662191 From the site: "go to bd/dvd setting and set the "108024hz" option off"
Aug 08, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
502 people viewed this question
Top Televison & Video Experts
