Question about Sharp LC-37D7U 37 in. HDTV LCD Television
Tv switches off
Hi,purchased television last week and all was fine.this morning i switched it on and after fourty seconds the television turned itself off.i have read through the manual and double checked that i have set it up properly.the timer is set to off so that is not the problem.when it turns itself off it does not go to stand goes get the telly to come on again you have to switch it off at the wall and after a minute switch it on at the wall then on at the telly.after fourty seconds pass it turns off states in the manual that it may be overheating but it does not stay on long enough to overheat.just before the television turns off the picture vanishes.the big question is,is my brand new telly goosed.your help in this matter would be very much appreciated.thankyou in advance..hallyboys..
  • 5 Answers
SOURCE: Sharp Aquos turns itself off
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
You can buy the parts online and fix if yourself!!
Posted on Aug 16, 2008
SOURCE: Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Posted on Nov 10, 2008
  • 1077 Answers
SOURCE: Sharp Aquos - switches input modes by itself, only when cold.
I believe your TV needs the latest version software upgrade. The current software may have been corrupted.
There is a USB service port on the side of your TV. You can download the software to a USB memory stick at then upgrade your TV from the service port.
If any problems doing this, call 1-800-BE-SHARP and they will run through the procedure.
Posted on Apr 01, 2009
  • 6 Answers
SOURCE: My Sharpe Aquos TV screen stays black even when switched on!
Call up Sharp, if you are part of the AQUOS Advantage Program, you get FREE in home service along with the repairs for it.
They'll give you a case number, set you up with a technician and BAM!
I called on a Wednesday and got an appt for that Saturday for the technician to come to my house.
I doubted Sharp alot less after that.
Posted on Sep 03, 2009
  • 66 Answers
SOURCE: Sharp LCD TV picture goes off few seconds after
it has problem in picture tube
Posted on Nov 16, 2009
SOURCE: Sharp Aquos 46in LCD AV Mode switching to Dynamic(fixed) by itsel
Sorry I´cant help you, but I´ve got exact the same problem.
I´m from germany. I searched the german web, but nothing.
Did you have an answer right now?
Posted on May 20, 2010
0 characters
1 Points
It takes about 30 seconds or longer to switch stations. I just purchased it last week. Do not have the manual
If you purchased it last week, does that mean that it's under warranty? If so, contact the shop, they will probable provide you with a new one, cause I've never ever heard of a TV set that takes 30 seconds to switch stations. Ever :-'
Sep 01, 2011 | Westinghouse LTV-46w1 HD 46 in. LCD...
Wharfedale TV power problems
the problem occurs in ur main board...check all tge resistor in board...the faulty resistor will; allow high voltage to the main board and affect it
Oct 31, 2008 | Flat Panel Televisions
I have a vizio vu37l tv..about 2 years old. Last night on its own it started switching to av1...comp...hdmi...all by even shut itself off. It also switched this morning....why is it doing this...
Vizio Has a big issue with all models working with each other, if either you have another vizio product in your home or a close neighbor, the remote signal is probably reaching your TV,
Jul 06, 2011 | Vizio VU37L 37 in. LCD TV
I have a Samsung ln46c630 which was purchased in May 2010. For the last few weeks it has started to have a strobing effect. Switching the source sometimes fixes the problem. It will run fine for a while...
Any luck? We bought our tv (same one) in March of last year. It is doing the exact same thing. Time Warner has already came out and switched out the cable box and cables. We have a tv tech coming soon (contracted out from Samsung, of course...) Problem persists...
Feb 06, 2011 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Bought a Toshiba Regza 37rv635d last week.
I have had the same problem today. I think it might be to do with the master power button on the side, as it seems loose on my tv. Did you ever solve the problem on yours?
Apr 06, 2010 | Flat Panel Televisions
LG LCD TV model 42LH70YR switches on and off continuously
Oct 06, 2009 | LG Flat Panel Televisions
Acoustic Solutions TV Fault
I think you are looking at a power board problem. I had the same thing happen to a Vizio and I replaced the power board and it solved the problem. It could also be the input board but most likely the power board.
Jul 13, 2009 | Daewoo DLP3212 32 in. LCD Television
your Tv remort Or Tv Swich service Requied
Sep 18, 2008 | Hisense LHD3204US 32 in. LCD HDTV
Open Questions:
See all Sharp LC-37D7U 37 in. HDTV LCD Television Questions
Sharp LC-37D7U 37 in. HDTV LCD Television Logo
Top Sharp Flat Panel Televisions Experts
Dave Naylor
Dave Naylor
Are you a Sharp Flat Panel Television Expert? Answer questions, earn points and help others
