Question about Maytag Neptune MDE5500AY Electric Dryer
Follow up on an earlier problem
I posted a problem here about a month ago regarding my Maytag Neptune MDE5500AY Electric Dryer. Simply put, it stopped working. The display shows nothing at all. The drum light works when the door is opened so I know it's getting power. Here's the advice I received: "In such situation the problem could be the bad membrane switch or the bad control board. I need you to check the connection between the membrain switch and the control board. Unplug the power cord. Remove the four screws securing the console to the rear cover plate. Grasp the top of the console and gently rock the top of the console forward away from the rear console back. Note the hooked tabs on bottom of the console, which engage the slots in the top cover. Locate the membrane switch ribbon plugged into the control board. Carefully remove it, inspect for any damages and plug it back into the control board. Visualy inspect the control board for any burned parts. If any, the control board has to be replaced. Reinstall the console back, restore the power and check the dryer." I've done everything advised. No burns on the control board, membrane switch unplugged, replugged. Everything looked clean and unremarkable and yet when reassembled and plugged in nothing had changed - no dryer. So I'm still stuck and need help.
I have had the same problem over the past several months. Typically it would clear itself out (clear 8.8. on display) after several minutes. Today it reoccurred but this time it would not clear. I knew it was a problem with the control board. So I removed the control board and discovered that the capacitor for the 5VDC power had ?popped?. I replaced the capacitor and every thing worked! Hope this helps.
Posted on Apr 23, 2007
Electric went out.now it is beeping,how do I fix it?
unplug it for awhile. Then google " Maytag Neptune MDE5500AY causes for beeping" . Click on appropriate link, and follow what it says
Apr 09, 2015 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag Neptune dryer is showing an error code of 88. I have reset the circuit board, reset the dryer, but it wont turn on. Any help is appreciated.
Who ever posted put a heating pad on the display THANK YOU i put my wife's blow dryer on the back of the display and in 5 minutes its was working again THANKS AGAIN
Dec 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer overheating
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 07, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag mde5500ayw dryer had an oversurge of power earlier, now dryer display is dead but light inside is on. Is there a fuse in dryer?
could be one on the control board, but I will bet if you had an electrical surge theres more than just a fuse gone
Oct 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune dryer is squeaking loudly. Belt was replaced 2-3 years ago. What else could it be?
berring in rear of dryer that the durm ride in. That is where the squeeking is comming from
Sep 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Electric Maytag Neptune Dryer - rattling noise
Your probably going to have to remove the rear panel and take a look to see what is causing the noise.
Disconnect the power cord and exhaust tube, remove the rear panel and check for anything loose.
You can also pop the lid and fold it back to inspect the top of the tub and belt. Roll the drum all the way around and inspect the belt for "chunks" missing.
If you include your model number, I can send you a web site that will show you an exploded view of the dryer.
Regards,
Aug 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer-stopped heating
first, check the exhaust, make sure every inch of it is clean on the inside. if there is any blockage, the heat will build up in the exhaust and a sensor will shut down the heating element.
Oct 27, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer
if your putting liquid softner in the dryer STOP !!!Put liquid softener ONLY in the washer.
May 25, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
181 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
