Question about Refrigerators
We have a westinghouse freestyle fridge and the drain is blogged how do you remove the back panel to access the drain tube
    Novelist:
  • 161 Answers
You will have to remove the freezer shelves and Icemaker then you should see the screws which hold the back panel in place. Remove these screws and you should be able to remove the back panel.
Posted on Dec 25, 2008
I have a Westinghouse freestyle fridge and it is collecting up to 500 ml water underneath the crisper bins each day.
remove crisper bins and look for the drain tube . it must be clogged . as water is supposed to drain to the evaporation tray under the fridge .
Dec 17, 2014 | Westinghouse Refrigerators
Where is drainhole in westinghouse freestyle refrigerator
usually located midway of fridge compartment in center its a small one usually covered with a casing or cover sometimes? some are located at center sides or bottom of fridge. if u look under the fridge and see the tubing then follow it up and get an idea where that drain plug is?
Dec 04, 2014 | Westinghouse Refrigerators
Westinghouse freestyle fridge rj532s-r is leaking water inside fridge compartment
You have an obstructed drain in the freezer or within the drain tube itself. You may have to thaw the unit to fix the problem, but it not terminal and you should not need parts, just need to locate why the water is collecting and clear the tube.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Sep 23, 2011 | Refrigerators
Have replaced broken hinge but am stuck getting both fridge and freezer door back on. can do one or the other but not both. westinghouse freestyle fridge/freezer
srack from bottom up- bottom hinge - bottom door- tape door with duck tape- middle hinge- top door- tape top door- top hinge- remove tape- done
May 25, 2011 | Refrigerators
We have a top freezer whirlpool gold refrigerator - the tube for the freezer seems to be frozen solid causing water to leak into the fridge. How do we get at that tube - we can only feel the hole in the...
You must remove items from the freezer and gain access to the rear panel via removing the screws on back panel and in most cases also removal of icemaker is a must. Then once access is gained then most bakers have a turkey baster get hot!! water and squirt water into drain area once water flow get a small flexible tube to insert into drain and then push what could be lodge in the peetrap built in the drain once done you good to go... it is a design issue on some models and the process may need to be done again....
Apr 02, 2011 | Refrigerators
Water is leaking from the inside.
This is the solution to a the same problem in a Westinghouse Freestyle refrigerator which is probably similar in principle. Basically the internal drainage system from the freezer is blocked. Open the fridge door, locate the dial which moderates the temperature located on the 'ceiling' of the fridge. Remove the light cover, remove the globe. Unscrew the two screws which hold the dial housing to the ceiling of the fridge, let this housing hang from the ceiling in the wires. This will expose a red funnel shaped tray, gently lift the tray and pull it out, you will most likely find the tray drain is blocked with gunk, clean and reinstall. Assembly is reverse of removal.
Jan 08, 2011 | Haier Refrigerators
Im after a manual for westinghouse freestyle fridge RJ422T-R
You can go visit onlinand Google.www.manual for westinghouse freestyle fridge RJ422T-R
Oct 23, 2010 | Refrigerators
My westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Nov 08, 2009 | Westinghouse Refrigerators
I have a westinghouse freestyle fridge and it is leaking water seem to be coming from behind the tempreature adjusting knob. Do you have any suggestions. Thanks Michael model RJ452T-R
Nov 03, 2009 | Westinghouse Refrigerators
Westinghouse Aurora Frost free fridge
You need to remove the clog in the drain line from the freezer to the condenser, Look under the fridge for the plastic drain line and blow it out or otherwise clear it, Then insure that the unit is level. Sooner or later you need to clean the freezer drain pan. After using up your frozen food, remove the back panels of the freezer and clean the area well.
Ray
Oct 29, 2008 | Refrigerators
Refrigerators Logo
478 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
