How can I get this device to read on an xbox 360?
Step 1: Connect your hard drive to your PC.
Step 2: Create a FAT32 partition on your hard drive. If you’re using less than 32 GB, you can use Windows via “Control panel > Administrative tools > Computer Management”. If you’re using more than 32 GB, you’ll have to use an external program, e.g. Partition Magic.
Step 3: Load all the content you want from your PC onto the external drive. This should consist of files that can be read on the Xbox hard drive.
Step 4: Remove the external hard drive from your PC. Plug it into your Xbox 360 console through the USB port.
Step 5: Go to the Media menu on your Xbox screen. Select "Portable Device" from the menu. All the readable files saved on the external drive should be available to read on your Xbox 360.
N.B. Xbox's connection with an external drive is read-only. You can only read files that are already on the drive after connecting. You can't save game files or anything else on the Xbox main drive onto the external hard drive. Also, USB storage devices cannot be used for Xbox live marketplace content.
