Question about Apple iPhone Smartphone
Cect i9 Battery Won't Charge
I just got a replacement cect i9 phone. When I try to connect it to my PC or charge it at an outlet, it will not charge at all. The screen immeadiately goes black and shuts off when its connected to a computer or plugged in. The phone does not charge at all. I have just read somewhere that its a firmware issue or something? but I have no idea how to fix this!!!
Can someone help me??????????
  • coffeegirl7 Jan 13, 2009
    I have the exact same problem...someone please help!
I have a very similar problem. what i found is the battery does not fit tight in the phone, and the contact is lost at times. i solved my issue by placing a piece of paper, folded once, at the top of the battery, not the end where the three contacts are at. by placing the folded paper against the battery, as i place it in the phone, it makes a tighter fit, and the battery does not move inside the phone. i also think you could use clear christmas tape as well, just keep adding layers, untill you get a snug fit. i hope this helps, it's not a techinal solution, but it worked for me.
Posted on Feb 15, 2009
MY fake iphone cect i9 3g won't turn on
It's the phone, that is the problem with these phones, use your warranty on it. I have to return, and my own i68+ also had the same problem, but they exchange it and now is working fine.
Sep 21, 2009 | Dual Electronics CECT P168 Cellular Phone
I hace a cect i9 phone still in box, but will not turn ON. It worked the first day I bougth it cause I tested it.I have charged the battery but still will not turn on. Is there a service location in...
you should have 2 batteries with it ...take battery out put other one in making sure in correctly seated...plug into pc via usb see if charging icon comes on ...once enough charge in to startup phone try other battery ...when charging you can press and hold top button on phone to startup if enough power...
Sep 11, 2009 | Dual Electronics CECT P168 Cellular Phone
CECT i9 stopped communicating with PC
Is it the same computer you've always used? It could be the OS not recognizing your phone or a bad USB port, if it is the same computer, most likely it's your phone. Try doing a firmware update and see if that helps. You'll have to use a microSD adapter to save it to your card since the cable doesn't work.
Aug 06, 2009 | Dual Electronics CECT P168 Cellular Phone
My usb for cect i9 does charge phone
my cect i9 was not charging from usb I though it was the cable but after I took out battery and scrapped the 3 contacts on the batttery with my fingernail it started to charge and be recognized by computer again
Jul 13, 2009 | Dual Electronics CECT P168 Cellular Phone
Cect i9 not working
Take the battery out, towards the bottom left are 2 slits (sim one and two)
The **** closest to the back is sim2 which the card goes in with the gold chip facing you, the other **** next to it is sim one, with chip facing away from you
Jun 23, 2009 | Dual Electronics CECT P168 Cellular Phone
Where do I put the sim card in and how do I charge the battery
Kindly go to the following link and download the user manual for the device
http://www.scribd.com/doc/4614820/cect-p168-english-manual?autodown=pdf
The SIM card slot is located beneath the battery pack. To access the same , you would have to remove the back cover of the device and remove the battery . The instruction for the same are given on page 14 of the user manual.
To charge the battery, you need a compatible charger.
Thanks
proton
Apr 22, 2009 | Motorola Mobility MOTOZINE ZN5 Cell Phone
How does the CECT i9 work when it comes to load info or files?
i9 has many different manufacturers. Some are good and others are not. i9's from www.i-buy-iphone.com are of competitive price and good quality
When connected to PC (windows XP or above), i9 is auto recognized as hard drive and you can drag and drop files there just as a hard drive.
You can find lots of java applications for i9 (do google on it). Not all java apps work on i9. It is a test and trial thing.
No sure about Mac.
Jan 19, 2009 | Dual Electronics CECT P168 Cellular Phone
My i9 will not turnon
right no1 the phone comes with 2 batterys which have charge try the other battery if that doesent work connect the phne via usb to a computor it should turn on automaticaly and start to charge then you should after a few min be able to turn phone on fully keep you battery fully charged dont let it completly run down as these phones are prone to this problem
Jan 13, 2009 | Dual Electronics CECT P168 Cellular Phone
CECT i9 GET WARNING WHEN CHARGING
Sounds like a bad charger you might need to get a replacement unit I had the same issue with one of my phones and it was a bad connector on the charger
Jan 06, 2009 | Dual Electronics CECT P168 Cellular Phone
Cect i9 wont charge battery is fine
the issue is with the wall usb ac adapter just replace it (with a better quality one) and it should work, you can also charge the phone using your computer. Well... this fix worked for me.
Dec 10, 2008 | Dual Electronics CECT P168 Cellular Phone
Apple iPhone Smartphone Logo
274 people viewed this question
Top Apple Cell Phones Experts
David
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
