Question about Acer AL1714 17" LCD Monitor
Acer AL1714 My monitor flashes the acer logo for less than a second and then goes black, after 10 seconds or so it goes into sleep mode. If I have a video signal going into it, it does not go into sleep mode. The power supply is supposed to have 19VDC, it has 18.8VCD but I suspect that it cannot deliver the required current 51W. Thanks for your input, Shaun
  • Anonymous Mar 12, 2008
    The monitor just flashes the acer logo and does not respond to anything. I turned it off for a few hours and turned it on and it is doing the same thing. I will appreciate any help
OK I have the same monitor, I was given it by a client when I couldnt fix it, I DO have the 19V supply and still getting the same problem.
If you open it and reseat all connections you can reach, I find it starts to work. Unfortunately after less than a few days use it goes off again.
Hopefully this can help someone get further
Posted on Nov 03, 2007
SOURCE:
How to solve acer monitor sleeping issue?
Press left mouse key and wait 10-15 seconds. Black screen and orange light is caused by computer going to sleep. Adjust your power mode.
Apr 30, 2014 | Computers & Internet
Monitor goes black seconds after showing desktop
Does your monitor go black because it went to sleep, does it turn off? Do you have any lights on the monitor to indicate what it is doing?
Also I would boot into safe made by rebooting the computer & tapping F8 when the bios appears. You should be prompted with several options, one of which is "Safe Mode". Choose this & report how the monitor behaves.
Jul 24, 2012 | Acer X193W LCD Monitor
My Acer AL1714 monitor was given to me, the person that gave it to me said last time the last time it was connected it work but the monitor had been stored for about 2 years. So I bought a 19V-2.3A power...
mccampbell71 Probably a failure of inverter circuit(dc to ac 600-1100vac) to light-up (sustain) "cold-cathode-fluorescent lamps" causing the "switch-mode-power-supply" to go into full or partial SHUTDOWN mode. Black Screen of Death strikes again!!! The Question I have is why did you BUY a "black-brick" supply? Did the other one fall out of the car or get run over by a train? Only you will be able to make the decision of to REPAIR or Trade-in for new. You are no different than 5000 others worldwide (all brands) who have monitor's with BSOD! Yes, some (75-90%) can be saved to work 1-3 more years! Read some of my other responses in my profiles (12fixlouie aka louie12fix) to learn of the options you have open to you. Bye for now 12fixlouie If this info was of some use please rate on fixya.
Nov 13, 2009 | Acer AL1714 17" LCD Monitor
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
At power up tv displays Acer logo then goes to black
will not turn off power with out unplugin it
Mar 01, 2009 | Televison & Video
Snooze button on my acer keyboard
To disable the sleep button on the acer keyboard Do the following (Vista home)
Go to control panel (classic view) double click Power options.
left hand margin select Choose what the power buttons do.
This opens a systems settings page
You will see an option :
When I press the sleep button: (Don't worry that the picture of the button is different than the keyboard's Zz)
Select Do Nothing from the dropdown box.
Click the Save changes button at the bottom of the screen.
This will disable the button on the keyboard...
May 28, 2008 | Acer NSK8458AN Keyboard
Acer al1714
The problem may not be the monitor. Acer AL1714 is known for its weak power supply unit. Unplug power supply from monitor. If the green light on monitor comes on but goes out quickly, the power supply is the culprit!
Dec 28, 2007 | Acer AL1714 17" LCD Monitor
Monitor repeatedly flashes Acer logo and computer display in cycles
We had the same problem with the 17" we bought in Aug. Sent it back for repair. Acer sent it back without fixing the problem. Started doing it again in Nov. This time I called a supervisor and they sent me a new monitor. Well yesterday it started doing the same thing. You can fix it temp buy unplugging it and holding down the on-off switch for 30 seconds. Please let me know if you have a better fix.
Dec 13, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Monitor goes dead AL1914
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Acer AL1714 17" LCD Monitor Logo
310 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
