I am having to click on each mail to delete it completely from my deleted folder. Surely there is a faster way to do them in groups????
Kernel for Outlook Duplicates software allows its users to search duplicate items, mark them using a flag and removes them in order to reduce the PST file size. The software marks duplicate email items as expired. To know more visit http://www.outlookduplicateemails.net/
Hello that should be a easy task: Hold down the control or Ctrl button on the keyboard and mark what you want to delete with the mouse what you have marked should now be blue let go of the control button and right click and click on delete.
Good luck
SOURCE: Deleting emails in outlook 2007
Click on emails you want to select due to holding CTRL botton.
SOURCE: need to delete email w/2 large of attachment after clicking send
1. Go the File menu, then choose Work Offline in order to stop Outlook from trying to send all mails:
2. Switch to the Outbox.
3. You now have two options:
a. Move the message: you can drag-and-drop or use the Edit: Move to Folder menu item to move the e-mail to your drafts folder. This will allow you to re-open the offending e-mail and slim it down by removing the large attachments before attempting to resend it.
b. Delete the message: this will immediately remove the message from the Outbox and put it in Deleted Items.
4.
If you receive an error at this point that says the message is being transmitted, close Outlook, wait for Outlook to exit (you may need to use Task Manager and wait for the Outlook.exe process to exit), and then start Outlook again and repeat steps 2-3. In some cases, the item may not be released until Outlook has restarted.
5. Go to the File menu, deselect Work Offline to start sending and receiving mail again.
SOURCE: I am unable to delete items from e-mail or send e-mail,receive ok
Have you tried the following:
Before you do any of the below steps try these two:
1. Within Outlook, click on Help --> Detect and Repair ( this usually fixes little issues that occur )
2. Also do a repair of the Office installation within Add/Remove Programs
First Backup your email:
1. Within Outlook, click on File --> Import and Export
2. From the list choose "Export to a file" and click Next
3. Choose Personal Folder File or PST and click Next
4. Click on Personal Folder and check "Include Subfolders" to backup everything, click Next
5. Save it somewhere you can find it like your desktop
6. Choose "Do not export duplicate items" and then click Finish
Recreate Outlook Profile
1. Close out of Outlook
2. Click on Start --> Run or tap Windows Key ( between ctrl and alt ) + R
3. Type in the word, "control" and press enter
4. Within the control panel ( make sure to switch to classic view if it is not that view already ) click on the icon that says Mail
5. Click on Show Profiles
6. Click the Remove button ( this will remove all accounts and PST files )
7. Click the Add button ( to create a new Outlook profile and create a brand new PST data file ) and call the new profile whatever you want
8. Click OK
9. Go back into Outlook and you should be prompted to add your email accounts again.
10. Once you have your email accounts added in again, go to File --> Import and Export....
RESTORING EMAIL
1. After clicking on File --> Import and Export
2. Choose "Import from another program or file" and click NEXT
3. Choose Personal Folder File or PST from the list and click NEXT
4. Browse to the file that you exported and click NEXT
5. It should read the file and find the email that you exported, choose Personal Folder Files and select "All SubFolders" to restore everything
6. Make sure that "Import items into the same folder" is selected and click finish to begin the restore process.
Hope that this helps, if not let me know....
Serge C.
SOURCE: my outlook 2007 delete box
Right click on deleted items this should delete the entire folder for you. If not open deleted items click on the very top message and then hit CTRL + A on your keyboard and hit the Delete key on your keyboard
this will also delete the items..
To delete a junk mail folder you simply right click on the folder and choose Delete.
SOURCE: i have 3 mail accounts on my Outlook. two are
With the AOL account you have setup, it will not delete the email until you choose Edit>Purge>Purge Marked Items.
You can chage Outlook Settings so that you only see "undeleted" items by going to View>Current View>Hide Messages Marked for Deletion
You will however, from time to time, Purge the deleted items as advised above otherwise performance may deteriorate.
Hope that helps, Pls rate the solution
Testimonial: "thank you so much!!! i knew it was a simple setting but i just couldn't find it. Thanks again."
