Question about GPX ML848B Digital Media Player
Can not get started comes on and then freeze
don
  • demoosh Dec 27, 2008
    my computer does not recognize my gpx ml848b at all. I plug it in and nothing happens. What the heck? Somebody help!
Help its frozen
Posted on Dec 25, 2008
Slow ice production
that could be one solution. I would look at how long the freeze cycle is lasting. The machine could be cycling off and on via bin stat. Average cycles from start of freeze cycle to start of freeze cycle is usually around 25 minutes or so. If it is taking longer than that, you may have to dig deeper. let me know. Don't overlook a leaking water valve.
Aug 23, 2012 | Hoshizaki Freezer Commercial Ice Machines...
How do you eat freeze dried food?
You don't need to do any cooking to prepare freeze dried food. You just add hot water and wait 10 minutes. If you don't have any hot water you can use cold water to prepare cold food.
Aug 13, 2012 | Camping, Backpacking & Hiking
I have a galaxy DX 44 that on the AM side after it been on for like 10mins the AM side goes out but the FM side don't
you probably have a thermal problem.Get some mr.freeze and try it again .when the radio goes out spray some Mr.Freeze onto the final area.Just a dash will do,don't want to freeze the parts just want to cool the down quick to see if the radio comes back on. If it does go to the final when it goes back out and spray a little on it .If it comes on then change the final and problem almost solved. Now wait to see if it goes out again , If it does then you have to get a block diagram to work from and spray some Mr.Freeze on the main IC while you're at it. If it comes on then it should be changed .Now that everything is new it had better be working but if not start spraying other componants until the radio comes on and stays on .
Mar 25, 2012 | Galaxy Radios DX-44V 40-Channels Base CB...
I have water pouring from the side of the engine
Look for a crack in the block or head, a blown gasket, or a bad expansion plug*. I assume the water is your coolant. If that is the case, the level in the radiator will be low.
The coolant leak could be up higher - perhaps it's coming from the thermostat plumbing or the temperature sensor. It could even be a crack in one of the heater hoses. The worst case is the cracked block - in that case the engine is essentially junk. A leaky hose connection is the easiest to fix.
*Note on expansion plugs (AKA freeze plugs). These look like inverted jar lids pressed into the block and are designed to be pushed out if the coolant freezes so the expansion of the ice doesn't crack the block (freezing can happen if you don't have a proper anti-freeze/water mix in cold weather). If you don't replace your anti-freeze according to the maintenance schedule, they may rust out and cause a leak.
Nov 02, 2011 | 2003 Ford Ranger Regular Cab
I a 16 user L230. my problem is that the terminals freezes. At logon, they are fine but they start to freeze after about 20mins after i switch the system on. its not particular stations athat freezes but...
The terminals never actually freeze as they are getting desktop sessions from the host. What can happen is the desktop session can lock up and thus any corresponding user input doesn't happen due to the session being locked up. Next time this happens, see if the server/host is responsive. Assuming it is, launch Performance Monitor(Provided as part of the Windows OS) by going to Start ' Run ' Perfmon. Monitor your CPU performance. See what's taking all the CPU resources. It's not uncommon to see unncessary programs running, i.e. jusched.exe (Java Scheduler update), qttask.exe (Quick Time updater), etc. All these programs and other unnecessary programs run at startup and run for EVERY single user so in your case, the jusched.exe runs 16 times and can take valuable system resources. Disable these by going to Start ' Run ' msconfig, press enter, the farthest tab on the right labled STARTUP is where you can disable these programs. After deselecting the ones you don't need, reboot the host and tell the dialog box to NEVER tell you again so that it doesn't alarm you're users that you've messed with the startup config. Lastly, don't overlook that fact that you need 1GB NIC and backbone to the server, each device can take up to 15MB/s of network bandwidth.
Jul 05, 2011 | NComputing L230 Network Terminal
Freezer not freezing - can hear a clicking noise coming from areond the th.ermostat / motor area
My freezer has a light that says "high temp" but the freezer isn't freezing my products.....what can I do? It also says that the temp has been 23 degrees or higher for more than 1 hour. I really don't think that the problem is being in hot weather
Apr 22, 2011 | Freezers
Fridge lights are on,fan blows,but compressor don`t start
Freezer is freezing up, Refrigerator is cool, but not enough to cool food. Replaced the condeser fan. Lights are blinking on the front panel and wondering if any knows how to re-set or any other solutions?
Mar 12, 2009 | Westinghouse Refrigerators
GPX ML848B  Digital Media Player Logo
67 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
