Question about Hoover U5144900 / U5146900 / U5147900 Tempo Bagged Upright Vacuum
Overheating vacuum? My Hoover U5134-980 has worked fine for the past year. Lately, however, it has smelled like it is overheating to the point where I can no longer vacuum because of the smell. I opened it up and the belt had melted and become disfigured because the metal part that it attaches to became so hot. I opened it up further and found a large amount of lint on the filter near the light bulb and removed that. I also replaced the belt. Neither of these things has helped. It seems to work okay, but the smell is really awful and seems dangerous. Any ideas?
    Problem Solver:
  • 5 Answers
I agree with the above poss bearings gone in roller.
Posted on Aug 22, 2009
    President:
  • 1,462 Answers
If the belt had melted, the only cause can be the brush roll stiff to turn. remove belt and check bbrush roll turns freely
Posted on Apr 14, 2007
How can I get my DC26 working?!
They can cut out due to overheating. Although you say you have 'cleared' the filters, they should ideally be washed as they can clog with very fine dust and cause overheating due to lack of air flow. Once a machine cuts out due to overheating it can take maybe half an hour (or longer) to cool down enough to work again.
Aug 27, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
My Hoover UH70604 vacuum just quit running.
have u check the cord for frays specially if this is a older unit or the switch for false contacts...hope this help u.thanks
Nov 12, 2013 | Hoover Remedy Multi-Cyclonic Upright...
I have a new hoover steamvac spin scrub. This was the third time I used it in the past ten days. I changed the water and added cleaning solution and when I turned it on it made a weird sound and died. ...
It sounds as if this machine has a defective motor. Usually a bad motor will fail quickly. You should have a 1 year warranty, so I suggest looking on Hoover's website for an authorized service center.
May 02, 2011 | Vacuums
I have two older Filter Queen (brown vacuum cleaners). Besides unclogging the hose area and making sure it is not filled with dirt, what else would cause the machine to run hot and have a high pitched...
High pitched sound is often caused by air leaks in air ducts. This will also cause hoover loosing sucking power and slightly overheating.
If the hoover is overheating a lot, then noise can also come from the motor. In that case the part must be rplaced.
Try replacing the cone filter, the secondary filter, and the insulation at the top of the machine.
If that does not fix the problem, then the hoover must be taken apart to clean or repair the air duct.
Nov 13, 2009 | Filter Queen Majestic Canister Vacuum
HOOVER WINDTUNNEL SELF PROPELLED OVERHEATING AND SHUTTING OFF
It sounds like it is overheating because of a blocked flow of air that keeps the motor cool. Check for a blockage from the area of the
roller brush through the hose to where it goes into the bag.
Tom
Oct 22, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Dyson dc07 works for a bit then switches off all the time
If you used a credit card with extended warranty or its within 1 year, take it back. You are correct about the overheating. We have the same unit and it works fine for over 3 years. I did see rebuilds at Big Lots which worried me for a $500 vacuum to have a reliability problem. Guess the recycled vacuums had bad motors?
Aug 21, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dusty smoking smell, stops working, trips out power in house.
you forgot to say if it is a 3 phase machine
if it is 3 phase then a phase in the unit is overheating and that will stop the machine then blow the breaker as all phases have to draw equal current
if it is a single phase then the start/ run capacitor or centrifugal start run points are not breaking at speed and so the start windings are overheating and causing the breaker to trip
Take it to an electrical motor rewind shop and have it properly tested with test equipment
Oct 21, 2017 | Hoover F6212-900 / F6215-900 SteamVac...
No suction
Sounds like your motor bearings are going bad. This is generally indicated by the motor overheating, and the heat transferring out through the motor pulley, which is where the belt attaches. So, your machine is overheating, melting the belt, and then tripping the thermal cutout. When it cools and you restart it, the belt is no longer functioning due to being melted, and this would make it not pick up on carpet. If you look at the motor pulley and it is turning blue: this is indicative of overheating.
The other possibility is that there is a clog, which is also causing your motor to overheat; so before you throw it away make sure all of your air pathways are clear.
The fact that you've had it 8 years is somewhat remarkable, however, since most vacuums of this type are averaging a 3-5 year lifespan. (And half that for bagless.)
So, check for clogs, and if it's not clogged, you're probably due for a new machine.
-R
Oct 01, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Sensory 2200W Overheating and Shut-Down
Did you ever get to the bottom of your overheating and shut-down problem? Just got the same problem :(
regards,
Mar 31, 2008 | Hoover Vacuums
Hoover U5144900 / U5146900 / U5147900 Tempo Bagged Upright Vacuum Logo
321 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
