Question about GE 3.2 cu. ft. Washer
ECONOMY 7 METER & SYSTEM WONT SWITCH OFF AUTOMATIALLY
MY ECOMONY 7 SYSTEM SWITCHES ON AT 12.30AM & THEN SWITCHES OFF AT 07.30AM VIA RADIO SIGNAL, THIS STILL HAPPENS AT THE METER, BUT ONCE THE METER SWITCHES OVER, ALL MY HEATERS AND WATER TANK IS STILL CHARGING UP ON THE NORMAL ELECTRIC, I KNOW THIS IS HAPPENING FOR SURE, I HAVE NEON SWITCHES ON THE SPURS OF EVERY HEATER & THE LIGHTS NOW ONLY GO OFF IF I MANUALLY SWITCH THE FUSE BOX OFF, OR AT EACH SPURED HEATER, I KNOW THIS IS ALL DEFINATE & HAVE LIVED WITH ECONOMY 7 FOR ALMOST 19 YEARS, I THINK ITS POSSIBLE FUSE BOX NEEDS UPGRADING, THE ECONOMY FUSE BOX HAS A MEMORA 3 100A MAX
    Scholar:
  • 150 Answers
Your appliances will charge up no matter what time of day/night it is if they are turned on unless they are wired so as to only come on during Econ7. Usually this through a separate supply out of the meter to that part of the fuse box [split load type] or to a 2nd box supplying only those appliances. This area is your responsibility.
Try testing the power supply tails with a volt stick. It's a non-contact neon indicator about the size of a thick pen
If during Econ 7 period you appliances are using electricity at the higher [day] rate, - & it doesn't matter how they are wired in [see above] - call the power supplier. The meter belongs to them.& is their responsibility.
Maybe wise to check the meter readings at times both day & night with appliances both on & off
Posted on Dec 23, 2009
Cruse control on 2008 Chevy Suburban stopped working. Changed the brake lamp switch (twice). Any suggestions? Where is the fuse located?
This is a computer controlled system (BCM) supply's power to switch .Voltage is supplied to the cruise control switch via the steering wheel control switch reference voltage circuit supplied by the BCM.
The following are the main components of the Cruise Control System:
• The accelerator pedal
• The stop lamp switch
• The body control module (BCM)
• The cruise control switches
• The engine control module (ECM)
• The throttle actuator control (TAC) motor
• The vehicle speed sensor (VSS)
Taking your vehicle to a quailfied repair shop would be your best option . Using a factory scan tool to view input data from switches and sensors is the only way to diagnose the cruise control on your vehicle . Just replacing parts does not cut it .
The body control module (BCM) monitors the signal circuit of the cruise control switches. The BCM relays the cruise control switch status to the engine control module (ECM) via the GMLAN serial data circuit. The ECM uses the status of the cruise control switch to determine when to capture and maintain the vehicle speed. The ECM monitors the vehicle speed signal circuit in order to determine the desired vehicle speed. The ECM uses the throttle actuator control (TAC) motor in order to maintain the vehicle speed. For further information on the TAC System, refer to Throttle Actuator Control (TAC) System Description .
This is not a fuse problem !!!!!!!!!
You probably don't know what GMLAN serial data is ,do you ? It's GM 's version of C.A.N. How to Diagnose Controller Area Network CAN
Feb 12, 2017 | Cars & Trucks
Cruise control wont engage unless i flick on turn signal
check fuses. (test them) use a meter.
check the switches for proper operation. a meter.
replace the switch is bad.
Feb 11, 2014 | 1994 Jeep Grand Cherokee
Creda storage heater manual
I'm not a heating expert, but according to the information I could find, Economy 7 utilizes cheap electricty at night, during off-peak hours (7 hours) between midnight and 7AM. Economy 7 costs about 4p per unit compared to peak electricity, which is about 10 to 15p per unit. If you do not have Economy 7, you can request it FREE of charge from your electricity provider. You will either have one meter with two readings or two separate meters. A two tariff electric meter will record the electricity used during off peak times, so it can be billed, separately, at a lower rate. If you have two meters, one meter controls on peak daytime electricity and the other controls your night time economy 7 electricity.
I would need to know what model Creda heater you have installed in order to determine how energy efficient it may be. I also will need the model so I can determine operating instructions. If you need further assistance, please post back and let me know. I hope this helps.
Nov 15, 2011 | Heating & Cooling
Galaxy DX 959. SSB doesn't seem to work. The power meter needle moves in AM but not in SSB. I tried adjusting the bias between test points 7 & 9 to 50 mA via VR12, but can only get it down to 90...
on ssyou are some what familiar with working on radio's. just make sure before you pull your hair out aligning the radio that you made sure it definitely is not tx on ssb. b the.Mic gain will increase the modulation. it could just be a meter issue. confirm this by having some one on another radio on ssb the same channel listen for you. if he cannot hear you then the ssb is blown out.sounds likelike
Jun 19, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
I have an 07 cobalt that wont start.the trip meter shows dashes.the dealer said no ignition 1 voltage and replaced the ignition switch. there is no communication with the pcm. i can jumper the starter and...
Your system is very complex and requires troubleshooting by an expert. I would trace the start signal from the switch then out of the bcm to the starter relay. See diagram below. I would also trace power from the park/neutral fuse thru the park/neutral switch.
Jun 12, 2017 | 2007 Chevrolet Cobalt Coupe
O2 Dodge Dakota Brake lights wont work but bulbs r good.
If the bulbs are good I would suspect the Brake light switch.
Brake Light Switch: Testing and Inspection
The brake lamp switch can be tested with an ohmmeter. The ohmmeter is used to check continuity between the pin terminals.
Switch Circuit Identification
- Terminals 1 and 2: brake lamp circuit
- Terminals 3 and 4: RWAL/ABS module and Powertrain Control Module (PCM) circuit
- Terminals 5 and 6: speed control circuit
Switch Continuity Test
NOTE: Disconnect switch harness before testing switch continuity.
With switch plunger extended, attach test leads to pins 1 and 2. Replace switch if meter indicates no continuity.
With switch plunger retracted, attach test leads to pins 3 and 4. Replace switch if meter indicates no continuity.
With switch plunger retracted, attach test leads to pins 5 and 6. Replace switch if meter indicates no continuity.
Sep 11, 2009 | 2002 Dodge Dakota Club Cab
GDI ecomony mode
There is normally no way you can turn it on or off. It is automatically managed by the coputer and it will normally tell you when the engine is running on a lean mode or not.
Try to test the car on a straight flat road @ 80Kms/hr with very constant slight acceleration and see whether the light comes on. If not then you might have the light bulb on the dash blown.
Cheers.
Dec 20, 2008 | 2002 Mitsubishi Lancer
New codes 25/7
TELEPEST 23/07/08 PM
Key 00 = DD BE E3 62 30 D9 2F 25 THIS THE NEW
Key 01 = OA D2 24 A5 A6 8O CO EE
TELEPEST 25/07/08 PM
KEY 00 7E 42 DC 21 A5 C2 98 CA THIS NEW TODAY
Jul 25, 2008 | StarTech.com StarView SV211K 2-port KVM...
Starview codes 07 07 08
00-07 97 B3 F2 89 EC 8D B6
01-FC 5B D3 21 C4 EO 7A FE
TEL***WE*** 9/7/08
Jul 07, 2008 | StarTech.com StarView SV431USB 4-port KVM...
Starview codes
NTL 7 JULY
00:98 8C 76 DA 61 4B 34 B5
01: F9 04 B6 14 68 9B 07 D1 NEW
GOOD LUCK
Jul 07, 2008 | StarTech.com StarView SV211K 2-port KVM...
GE 3.2 cu. ft. Washer Logo
344 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
