Question about Microsoft Windows XP Media Center Edition 2005 for PC
Copy cd to windows xp media center library
Trying to download cd's to microsoft media xp media center to the library. When media center is opened an error message appears "messenger cannot be found or opened" not sure exact wording. Cannot find library to determine if cd has downloaded either.
  • 1 more comment
  • Anonymous Dec 25, 2008
    need help to fix media center receiver
  • GailDorine Jan 02, 2009
    I have the same exact problem and I've spent weeks on it. Can't even play a CD much less copy it. Can't use my new IPOD because everything goes through Media Center.
  • Anonymous Mar 23, 2014
    cant open downloads from websites, or emails states virus but no virus found and wont let windows security center to be turned on
Model no compaq c700
sound driver download
Posted on Dec 25, 2008
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Can't download free music and videos on a sa3025 gogear mp3player
You have to use Windows Media Player to trnasfe rsongs/the Philips Media Converter for videos:
The instructions in these pages, which are largely links, pertain to Windows Media Player 10 and 11 only.
Windows Media Player is made by Microsoft. The general help page for Windows Media Player is:
http://www.microsoft.com/windows/windowsmedia/default.mspx
Through this link, you can enter a variety of search terms that will help you find what you are looking for (exs.: “add files to my mp3 player”; “delete files from my mp3 player,” etc.)
Important Vocabulary:
The code word for “mp3 player” in Windows Media Player is “DEVICE” or “portable device”
The code word for adding files is “SYNC,” “syncing,” or “synchronizing”
The code word for copying files from CD is “RIP,” or “ripping”
The code word for files stored on both My Computer and my Mp3 player (when it is connected to the computer) is “LIBRARY”
To add files (SYNC) to your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/wmp10/harrison_wmp10.mspx
To add files (SYNC) to your mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/player/faq/sync.mspx
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
To copy (RIP) files from CD to Mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/getstarted/ripcd.mspx
To copy (RIP) files from CD to Mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/easystart/mp11guide.aspx#RippingCopySsongsfromCDstoYyourCcomputer
Dec 29, 2008 | Philips GoGear HDD1830 MP3 Player
Download music to Tevion MP3
Use Windows Media Player:
My Directions:
Jul 05, 2008 | Audio Players & Recorders
Mp3 version 3
Use Windows Media Player to locate the Limewrire downloads folder, then see these useful help pages:
My Directions:
Mar 28, 2008 | iLO MP3 Player
Music loading
The songs you are trying to transfer are in the wrong format.
My Directions:
Mar 27, 2008 | iLO MP3 Player
Please help
Use Windows Media Player, search for Limewire downloads folder:
My Directions:
Mar 16, 2008 | iRiver iFP-895 MP3 Player
Cannot download music to ilo mp3 player
My Directions:
Sep 01, 2007 | iLO (2 GB) MP3 Player
Downloading music to mp3 player
My Directions:
May 16, 2007 | iLO (2 GB) MP3 Player
Microsoft Windows XP Media Center Edition 2005 for PC Logo
275 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
