Question about Krups FDE3-12 Sandwich Maker
Applianced shut off, most likely from over heating. How do I reset.
Appliance shut itself off do to being on too long I'm assuming and there is no reset button that I can find on the the exterior of this model. Is there one inside? Thank you in advance for any help provided.
Check the thermofuse in line with the red wire, it is most likely "open" resulting in no voltage getting to the heating elements. Replace if found defective.
Posted on Jun 30, 2007
    Genius:
  • 1,074 Answers
The elements of the set is almost defected it is time to buy a new one good luck
Posted on May 07, 2007
Why does my projector keep switching itself off?
This sounds like an overheating issue, with the temperature sensor shutting it off when it gets too hot for safety reasons. Assuming this did not start until after you replaced the lamp, my initial guess would be that either the wrong lamp was used, and it's generating more heat than the unit feels comfortable with, or, the temperature sensor itself is going bad.
Oct 13, 2014 | JVC DLA-HD100
Defrost light (red light) is on in heat mode and unit not working on heat. Has happened since a power outage.
Good Morning Ray,
I understand that the defrost light is on in heat mode on your Electrolux air conditioner, and your appliance is not working on heat. I also see that this has happened since you had a power outage. I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please provide me with the model number of your air conditioner. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Electrolux E23CS75SS Air Conditioner
My fan wonT shut off
Good Morning Judy,
I understand that the fan will not shut off on your Frigidaire air conditioning and heat, air conditioner, model# LRA18HMT2, even when you have turned your appliance completely off. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit break, for 3-5 minutes. When power is restored, turn your air conditioner to any cycle and let it run for 5 minutes before turning it off. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 14, 2014 | Frigidaire Heating & Cooling
Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
Janet McDonald,
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
-Best Regards-
Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
DRYER NOT HEATING UP
Matthew Campbell,
I understand that your Frigidaire electric dryer will run but is not heating up. What I would suggest would be to give the appliance a hard reset.
You can do this by either unplugging it or cutting the power at the Circuit Breaker for 3-5 minutes. After resetting it for the 3-5 minutes, bring power back to the dryer. Run any cycle and see if you are getting heat or not.
If you are not getting any heat to the appliance, it could be either something to do with the heating element or possibly the control board itself. The other possibility would be the wiring going between the heating element and the control board.
I would recommend contacting a local authorized technician to determine what exactly is the root of the dryer not heating.
-Best Regards-
Jan 14, 2014 | Frigidaire Electric Dryer
Why do I have to keep hitting the reset button to get the heat?
If the switch keeps popping, that means there is a problem that the switch is keeping from causing anything from a complete failure to a house fire. As you have asked about a "quick fix", must assume you do not have the required expertise to diagnose the different components. You should call for an appliance maintenance person to come out and fix it instead.
Mar 18, 2012 | Dryers
I have a problem with my sony play station I had this problem for months When I turned on the ps2 it shuts down itself,I can reset it and i start playing but then again it turns off itself,Sometimes i...
The PS2 shuts off automatically when acquiring heat, it might have been cutting off due to excessive heat or overheating. If the system does not power on, well the internal power supply unit might have gone busted and generally a hardware failure causing this issue.
Jun 14, 2010 | Sony PlayStation 2 Slimline Console
My heater will kick on right away but after 3-5mins it stops producing heat then a few mins later it will start heating again. Why?
The furnace could be shutting off on High Limit ...means your furnace is running too hot...check your filter and make sure return air vents are clean and clear....also it can be the Heat anticipator in your thermostat...which controls how many times your furnace cycles...basically your furnace should come on and off 5-6 times/hr ....need more info on your type of furnace and type of thermostat
Oct 19, 2009 | Holmes Products HCH4062 Ceramic Compact...
Overheat trips Asko T721 dryer
If you have a condensate tank that fills up too much the float inside the pump housing will shut the dryer off also.
Jul 24, 2009 | Asko T721 Electric Dryer
Krups FDE3-12 Sandwich Maker Logo
296 people viewed this question
Top Krups Kitchen Appliances - Others Experts
Mike
Irene Tulloch
Don Eagan
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
