Panasonic Viera TV switiching itself off
My Panasonic Viera TV - Model TH-42PV30 keeps switching itself off. A red light next to the on/off switch blinks 5 times continuously with a opause between each sequence of 5 blinks. While this is happening the remote does not work. I switch off at the wall, and switch on again 30 min later, but it only stays on for around 5 min and switches off again with the 5 blinking lights. Any solution? Thanks, Mike
  • msphotograph Dec 28, 2008
    The TV I am having the trouble with is NOT a "projection" TV (as indicated in your reply to me) It is a Progressive Plasma TV - Model No. TH-37PA30. Panasonic Viera. Thanks, Mike
  • msphotograph Jan 03, 2009
    Thank you. The TV has since righted itself without any action, however your advice will come in handy if the problem occurs again. Mike
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, the "switching itself off" would be a reaction as the unit has kicked into protective mode. The built-in diagnostic has sensed the fault, auto shutdown and displayed the error codes (5 blinks). 5 blinks would indicate possible fault in the:
  • loss of +5VDC at the SOS D board; or
  • SW PC Board P/N TNPA2841AH.
This of course would require opening the unit, perform voltage measurements,determine faulty component and subsequent part(s) replacement. Further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional or claim warranty if the unit is new.
Good luck and Thank you for using FixYa.
Posted on Dec 28, 2008
  • 69 Answers
What type of tv is this, plasma, lcd or flat panel?
  • Stephen Evans Dec 31, 2008
    I did not imply projection
  • 15,935 Answers
Check the 2 main interconnection cables (24pin and 26pin) rear of PDP and Tuner box.
Make sure they are firmly connected. (Loose connection of 24pin will cause no power
on symptom.)
  • 2 more comments
  • blueextc3221
    blueextc3221 Dec 28, 2008
    "Technically speaking, this is part of a protection circuit that shuts down the PDP if any of the working voltages dip below 75% of their nominal value.
    This particular problem is due to the shutdown circuit being too anxious to do its job.
  • blueextc3221
    repair the TV, replacing modules 5 and 7
  • blueextc3221
    A closer inspection will result in you seeing the word proTection... not proJection.
  • blueextc3221
    its a known fault, and any reliable tech will know it right away.
  • 2,326 Answers
The 5 blinks on this model and chassis would be due to a defective "D board". The 5 volts are not working properly causing the TV not to turn ON.
I would suggest to contact Panasonic to see if they can provide you with the board to fix your plasma or if the plasma is less then a year old, still under manufacturers warranty.
How do I view still digital photos from camera to Panasonic Plasma TV TH-42PV30?
Stick camera memory card into memory card slot on tv. If it does not automatically switch to that input use the remote to change to that input.
Nov 22, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
TV switched itself off and will not come on.
try unpluging it and leaving it over night then try again and if not the tv might be stuffed
Sep 02, 2009 | Televison & Video
Model th-42px60u viera panasonic wont power on is there a solution
Had this problem as well. Held down the power button and it seemed to reset itself....powered on fine after that. Still makes me nervous and would like to figure out the cause. In my case, red light flashed 3 times when attemping to power on.
Jun 30, 2009 | Panasonic Viera TH-42PX80U Plasma TV
The TV switches it self off
Sorry to here about your TV problems but it is almost imposable to help someone with technical problems if they don't list a product, model or P/N number.
Either-way, I would try moving the unit in an area where it has more breathing space if poss-able.
Also, is the unit in a air conditioned area or in a Damp basement or Florida room ?
I would also, go on line and see if Panasonic has any call backs on this unit.
This may be a feature which can be reset without to much trouble.
Next time please list the size & model #.
Jun 16, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic Viera TH-42PV30 No picture & Stand-by light flashes 4 t
I would guess a power board failure. The blinking light is an error code.
Nov 17, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Panasonic Viera 42" TH-42PV30
Check the 2 main interconnection cables (24pin and 26pin) rear of PDP and Tuner box. Make sure they are firmly connected. (Loose connection of 24pin will cause no power on symptom.)
Oct 21, 2005 | Panasonic TH-50PV30 50 in. Plasma...
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
