Dvd burring I recently got a new computer and it has a dvd bunner.But i dont know how to use it . Its not new but its new to me.I have a dell inspiron. I am useing windows vista. Can you help me please.
  • 48 Answers
There should be software on the pc to burn cd/dvd's, check in the start menu for either Sonic or Roxio that is usually when Dell pcs come with for burning discs.
Posted on Dec 26, 2008
Hi there i am unable to insert any cd/disk in the cd slot of my dell precision m6400, can u assist me?
If this isn't loading cd or dvds then your problem is the drive itself. You need to replace it. You can order parts on line or from dell. Or you can use a external usb drive. All are about the same price.
If it loads dvd but not cd then this is a new one. Usually it has problems with dvds first then cd later on. That means the heads are out of alignment and don't have the fine control for dvds while it can still do the coarse cd .
Sep 02, 2011 | Dell Precision M6400 Slot Loading 8x SATA...
I recently acquired a used Dell Optiplex 320 desktop computer. When I lay the computer flat, the dvd drawer will open and function. When I stand the computer upright, the dvd drawer will not open. I am...
Sounds like there's something stuck inside the DVD drawer that blocks the drawer from opening if it's not its side. Try turning it over onto the other side, just for a minute, and see if it opens. If it does, there's something blocking the drawer. If it doesn't, you'll probably need a new drive, as that one's literally worn out...which I've only seen twice.
Jul 04, 2011 | Dell Drive for Dell OptiPlex 320...
Dvd will not burn cds just says connect bunner and re try bunner was there
go to start and then go to control panel. Look for the icon for System.
double click on system and click the Hardware tab and the button for Device Manager.
Expand the listing for DVD/CD drives and right click on your dvd or cd drive and select Uninstall.
Once uninstalled, then close out the window and then reboot the machine.
Click on Start, Turn off Computer or the little arrow bottom right corner of the menu and select Restart.
This will reinstall the drive hardware drivers, and then try it again.
If that does not work, go to start and click on My Computer or Computer, depending on your system. Right click on the DVD drive and select Properties. Look for a tab for Recording and make sure the option to enable recording is enabled with a check mark.
If that is enabled and it still does not get recognized, then it could be a problem with the mechanics of the drive and should be replaced.
Apr 10, 2011 | Dell DVD±RW Dual Layer Burner
Can i take abunner from one dell computer out and put a bunner from a nother dell computer
Hello, there is no problem on switching similar burners if the destination computer has a free interface connector for the type of connector of the replacement burner since they are plug and play. The form factor is the only thing that could cause problems after that.
Jan 11, 2011 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
No edrive no dvd cant burn
Windows native drivers should be enough for your DVD drive. With the PC powered on, push the eject button on the drive to see if it is getting power. Check the cables inside the case. If it won't eject and/or the cables are all in place and seated, but it still won't work, then you probably have a bad drive.
Apr 23, 2010 | Dell Inspiron 530 Desktop Computer
I got a new compter the same one as i got now how do i put the old bunner in the new one
Open the case. then you will an power cable (red,black,yellow) remove it. You will an large flat type cable remove it, ther might be small audio cable remove it, Remove the screws on the sides of cd unit. Rev. the process to put in new computer. if you have make model of units might be able to go more detailed.
Feb 26, 2010 | Computers & Internet
How do i know if my computer can bur dvds?
If you have Vista, it most likely can burn Dvd's only because most of the new computers come with DVD burners. But another way you can check is click on the start icon, go to Computer and under Devices and Removal Storage you should see DVD RW Drive(E.). The (E) could be different depending on what the drive letter is. Hope this helps.
Apr 10, 2009 | Dell Inspiron 531s Desktop Computer
Does the dell dimension 2400 burn dvds?
Hi budliteman36
Dell Dimension 2400 series will not bur DVD, see the link blow for specifications.
http://reviews.cnet.com/desktops/dell-dimension-2400-pentium/4507-3118_7-30824846.html?tag=mncol;rnav
You can replace the CD-RW drive with a DVD writer. Here is a list od DVD-R-RW writers.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=89&name=DVD-Burners&
Cheers!
Mike
Mar 31, 2009 | Dell Dimension 2400 PC Desktop
Dmr-ex77eb-k
The Panasonics are very picky about the media ie brand and quality of the DVD blank. Try a different brand and see if that helps.
Nov 23, 2007 | Panasonic DMR-E80H DVD Recorder
Computers & Internet Logo
151 people viewed this question
Alun Cox
David Payne
David Payne
