Question about Pentax K200D Digital Camera with 18-55mm lens
Pentax K200D Digital SLR - Error Message "f - - "
I have just bought my wife a Pentax K200D Digial SLR Camera, and also bought a Sandisk 4GB High Speed Memory Card.
Put the batteries in and memory card, and get a flashing display "f - -"
Tried to format the memory card, but it does not want to.
Have tried other memory cards, same problem.
Any ideas ?
Thanks
Geoff
  • of_alicia Apr 02, 2009
    i have the same problem. I bought this camera second hand off a really good friend, with a lens has used with the k200D. The first time i tried to use the 100-300mm lens (i have only had the camera for a couple of days now), i got this same message flashing. I have made sure the contacts are clean, and i know my friend would not have given me an incompatible lens.
    Any other ideas?
    Oh and i have an SDHC card so its not that either.
  • krima Jun 08, 2010
    my pentax K200D works fine except the monitor won't display anything until I've actually taken the picture
This can also happen when the lens have an aperture adjustment ring, and it is not set to the "Auto" setting ("A", on my Sigma)/
Posted on Dec 02, 2009
  • tonyleg02 Sep 16, 2010
    Spot on solution. Solved my problem instantly with my Pentax K20D and 100mm f 2.8 macro. Many many thanks!
    Anthony
"f--" is usually happening when you put on a lens that does not communicate with the camera body (like an old manual lens). this has nothing to do with memory card, and the sandisk 4gb you bought is perfect for k200d.
look either what lens you attached and whether the contacts between camera body and lens are clean.
Posted on Mar 28, 2009
    Sergeant:
    Champion:
  • 215 Answers
May be you solved your problem. Those cards are readable only after that you upgrade the firmware of the k200d from the official site:
http://ricoh-imaging.ca/en/support/digital/k200d_s
Posted on Jan 31, 2015
This following solution also worked with my Pentax KM
""f--" is usually happening when you put on a lens that does not communicate with the camera body (like an old manual lens). this has nothing to do with memory card, and the sandisk 4gb you bought is perfect for k200d.
look either what lens you attached and whether the contacts between camera body and lens are clean."
Posted on Dec 04, 2009
You need a different sort of memory card. This camera calls for card format: SD/SDHC, not compact disc.
Posted on Dec 25, 2008
  • Benny Banihit Sep 16, 2013
    I've tried any other sd brand, but it still doesn't work, is my unit have any adjustment?
I have a K200D which continually shows low power, or no power at all even after replacing with newly charged NiMh batteries or new lithium batteries. I have already checked the connections and this has not...
normally cost $199 is the dc-dc converter circuit , but try this put new batteries or the original Pentax battery and see what happen , U can update the firmware in the camera maybe that fix that problem .
Oct 10, 2017 | Pentax K200D 10 Megapixel Digital SLR...
Memory card Sandisk 4GB gives error memory card
The S50 uses SD cards. Your 4GB card is actually an SDHC card, and will not work in the S50. You will have to confine your choices to cards 2GB and smaller.
May 15, 2010 | Pentax Optio S50 Digital Camera
Help me how do i install my webcam
Please open the link below and follow the instructions there to install the camera
http://www.ehow.com/how_2075075_install-webcam.html
Feb 16, 2010 | Pentax K200D 10 Megapixel Digital SLR...
Pentax k200d BATTERY PROBLEM
The battery charge indicator is temperature sensitive. If you switch off and on again, do you still get the low battery warning? Have you tried with a second set of batteries - either rechargeable, or lithium or alkaline. I would do this in a warm room, and try it with new alkaline cells. You lose some of the functions, but if the indicator say charged, and you can take a shot, then the body is OK.
Call me old-fashioned, but I use a multimeter on all NEW batteries to make sure they are functional - I bought a card of cheap LR44s and the first three were either dead or low on voltage.
Oct 25, 2009 | Pentax K200D 10 Megapixel Digital SLR...
PENTAX K200D Manual
I have the same camera and to my knowledge, a 'live' view with the LCD screen is not a feature with this camera. All pictures are taken through the eyepiece and then reviewed on the LCD screen. BC
Jun 08, 2009 | Pentax K200D Digital Camera with 18-55mm...
Disassemble pentax k200d
I have such instruction. Leave your e-mail.
May 31, 2009 | Pentax K200D 10 Megapixel Digital SLR...
Pentax K200D NO LCD just viewfinder visual
Pentax K200D is a SLR Digital Camera..... in SLR you can the images in LCD after it has been taken.... while cliking image you need to use the Viewfinder......
Mar 24, 2009 | Pentax K200D Body only Digital Camera
Washed out pictures using a Bower 724 AFPX flash
This is probably not the camera settings. Pentax k200D wilt only give auto-flash with just three of their own units. Sounds like you have the Bower set on Auto. Set the flash to Manual, and adjust exposure on the aperture setting with the body set to manual as well.
Note that several people have reported problems with Bower units on digital cameras (and not just on Pentax)
Mar 22, 2009 | Pentax K200D 10 Megapixel Digital SLR...
Older Pentax Lenses & Pentax digital SLR cameras
Depending on which series (screwmount, K, M, etc) you have, you'll get different levels of functionality, but yes -- all Pentax lenses for 35mm and DSLR (except for the medium-format digitals) will work with your K200D. Read the manual.
Dec 30, 2017 | Pentax Cameras
Pentax K200D Digital Camera with 18-55mm lens Logo
1,984 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
