Question about Magic Chef 9522 Electric Double Oven
Looking for owner's manual for model G920-4CKX
The timer, clock and light work just fine, nothing else seems to want to work.  Looking for some steps to take to troubleshoot/fix the problem.
How do I set the clock/timer to make the oven work?
does it have a clock button , if so press it then use the +or- buttons to set the time then press clock again
Dec 06, 2015 | Ovens
Nothing is working in my oven not even the led timer is lighting up
When the timer, clock etc didn't light up my oven stopped working. Replaced the clock display unit and all is now fine. A simple switch over just remove one wire at a time and place it on the new unit, the only difficult part was gaining access to remove the display unit itself.
Sep 08, 2015 | Ovens
Experienced recent power outage in my neighborhood. When power came back on, the display on my Bosch Oven HBL5035 now reads "F03 Err". Tried unplugging, but can't get rid of error code and...
sounds like a power surge occurred when power came on and blew out something on the main board. Try looking up the model and model number online and you can find the owners manual then look up the section that tells what the code means. Try unplugging it and leave unplugged for an hour. then plug it in and see if this helps.
Dec 12, 2017 | Bosch HBL5035AUC Stainless Steel Electric...
Hi.. I have a wall oven fisher & paykel model 600e and after my girlfriend tried to use it pressing all the buttons without knowing what she was doing the element is not heating up anymore :( what...
The electronic timer must be in manual mode for the oven to work. Turn the oven on. Play around with the clock/timer buttons using as many combinations as you can. When the oven indicator light comes on the clock/timer is in manual mode. This could take 5 minutes or more. Be patient.
Mar 01, 2011 | Ovens
Tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
Jun 05, 2010 | Tecnik TKC8522 Electric Double Oven
Oven doesn't work, stove does
If it's a Whirlpool or Kenmore oven (or one of several other brands that are made by Whirlpool) then this error code means:
F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC)
The system believes that the control board has failed and needs to be replaced.
This page has a list of diagnostic codes by brand and model number. You should check there to look up your particular brand to confirm what I just said.
Aug 04, 2009 | Ovens
Just brought a bosch oven and there no life in the bottom oven
If it has a timer, then make sure it is set manual and not auto, or the oven will not work.
Try pressing 2 buttons at the left of timer and one button on right of timer to set it to manual, if it does not work this way, then try another combination of buttons.
Hope this helps.
Plz rate my solution.
Thanks.
Jan 03, 2009 | Bosch HBL 435 Stainless Steel Electric...
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
Oven not heating to proper temp
go to: RepairClinic.com
you'll need make & model #.
Nov 16, 2008 | Frigidaire Ovens
Setting Clock and Timer
Worked it out for myself - no solution needed now thank you.
Jun 21, 2008 | Zanussi ZBS963X Electric Single Oven
Magic Chef 9522 Electric Double Oven Logo
Top Magic Chef Ovens Experts
Sal De
Marvin
Marvin
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
